Incus 7.0.1 replication error on vm, zd device not exist, bad handshake
I’m doing incus replications on my lab, 2 clusters, 3 nodes each. incus version 7.0.1. I use incus copy --refresh --stateless …
replication 1 : from sdcxlab02 > sdcxlab03 , same cluster, local, 10G network. copy to different incus project
replication 2 : from sdcxlab02 cluster1 to srdrlab02 cluster2. cluster 2 is remote DR cluster. 500 Mpbs network.
both replications are controlled by a lock file, both run in one cycle. no such thing as local and DR are trying to do incus copy the same instance simultaneously.
I run some containers and one vm1, nothing fancy on them, just generate 10MB file every 10 minutes. disks capacity are fine. the replication is on 10-minute cadence using cron.
now I get error like this below in my logfile, that happens only to vm1, all containers are ok. I find this on sdcxlab02, as source , where vm1 resides, error occured, something about /dev/zd272. all subsequent cycles are error.
root@sdcxlab02:~# cat /var/log/repl/repl-20260929.log | grep WARN
2026-09-29 02:50:44 [WARN] (247241) sdcxlab02 standard: default/vm1 (virtual-machine): DR refresh FAILED (exit=1) — Error: Failed instance creation: Error transferring instance data: Failed migration on target: Failed receiving migration offer from source: Failed migration on source: open /dev/zd272: no such device or address
2026-09-29 03:00:12 [WARN] (252324) sdcxlab02 standard: default/vm1 (virtual-machine): local refresh FAILED — Error: Error transferring instance data: Failed migration on target: Failed getting migration target filesystem connection: websocket: bad handshake
2026-09-29 03:00:12 [WARN] (252324) sdcxlab02 standard: default/vm1 (virtual-machine): DR refresh FAILED (exit=1) — Error: Failed migration on source: The instance is already being migrated
2026-09-29 03:10:10 [WARN] (254257) sdcxlab02 standard: default/vm1 (virtual-machine): local refresh FAILED — Error: Error transferring instance data: Failed migration on target: Failed getting migration target filesystem connection: websocket: bad handshake
2026-09-29 03:10:11 [WARN] (254257) sdcxlab02 standard: default/vm1 (virtual-machine): DR refresh FAILED (exit=1) — Error: Failed migration on source: The instance is already being migrated
2026-09-29 03:20:11 [WARN] (256318) sdcxlab02 standard: default/vm1 (virtual-machine): local refresh FAILED — Error: Error transferring instance data: Failed migration on target: Failed getting migration target filesystem connection: websocket: bad handshake
2026-09-29 03:20:12 [WARN] (256318) sdcxlab02 standard: default/vm1 (virtual-machine): DR refresh FAILED (exit=1) — Error: Failed migration on source: The instance is already being migrated
it started at 2026-09-29 02:50, it was ok at 02:40
the next error doesn’t say anything about any zd devices, just error like this :
root@sdcxlab02:~# /opt/repl/run-repl.sh standard
2026-09-30 13:42:56 [DEBUG] (412645) sdcxlab02 standard: Lock acquired: standard (PID 412645)
2026-09-30 13:42:56 [INFO] (412645) sdcxlab02 standard: === Cycle start ===
2026-09-30 13:42:57 [DEBUG] (412645) sdcxlab02 standard: Snapshot name: repl-20260930-1342
2026-09-30 13:42:57 [DEBUG] (412716) sdcxlab02 standard: default/vm1 (virtual-machine): CMD: incus copy vm1 vm1 --refresh --stateless --project default --target-project standby-default --target sdcxlab03
2026-09-30 13:42:57 [DEBUG] (412716) sdcxlab02 standard: default/vm1 (virtual-machine): CMD FAILED (exit=1): Error: Error transferring instance data: Failed migration on target: Failed getting migration target filesystem connection: websocket: bad handshake
2026-09-30 13:42:57 [WARN] (412716) sdcxlab02 standard: default/vm1 (virtual-machine): local refresh FAILED — Error: Error transferring instance data: Failed migration on target: Failed getting migration target filesystem connection: websocket: bad handshake
2026-09-30 13:42:57 [DEBUG] (412716) sdcxlab02 standard: default/vm1 (virtual-machine): DR refresh → srdrlab02:srdrlab02 (project default, timeout 900s)
2026-09-30 13:42:58 [WARN] (412716) sdcxlab02 standard: default/vm1 (virtual-machine): DR refresh FAILED (exit=1) — Error: Failed migration on source: The instance is already being migrated
2026-09-30 13:42:59 [INFO] (412716) sdcxlab02 standard: default/vm1 (virtual-machine): done (local=FAIL dr=FAIL)
2026-09-30 13:42:59 [INFO] (412645) sdcxlab02 standard: === Cycle complete (1 instances processed) ===
2026-09-30 13:42:59 [DEBUG] (412645) sdcxlab02 standard: Lock released: standard
on srdrlab02, which is the node2 on dr, I find something like this :
root@srdrlab02:~# incus operation list --format compact
ID TYPE DESCRIPTION STATE CANCELABLE CREATED LOCATION
2d6d9f46-e1e3-4bca-9dd7-7fbdbd96d177 TOKEN Executing operation RUNNING YES 2026/09/28 09:30 WIB srdrlab02
it’s clean on sdcxlab02 and sdcxlab03.
I try and delete the operation on srdrlab02, run the replication script again, and get the same error.
I can clear the error only after I do systemctl restart incus.service (and incus.socket) on sdcxlab02
several cycles go by and done ok, then it happens again. I do the incus restart again.
what is possibly the cause?
/dev/zd* vanishing mid refresh usually means the zvol got torn down or renumbered while migrate still held the old minor. vms on zfs do that more than containers for me.
on the source while its idle:
-ls -l /dev/zd*
-zfs list -t volume | rg vm1
-incus config show default/vm1 | rg -i ‘root|pool|size’
-incus storage volume list YOURPOOL | rg vm1
-dmesg | rg -i ‘zd|zvol’
the “already being migrated” + bad handshake means a previous refresh never finished clean. before the next cron tick:
-incus operation list
-incus operation delete OPERATION_ID
10 min cadence on a vm that keeps writing can leave the last refresh still open. stretch the interval or skip the cycle if operation list still shows a migrate.
