Incus 7.4 can not copy vm to other pool
Hallo Team,
We have an issue when we will copy vm to other pool, we get error
Create instance from copy: Create instance volume from copy failed: Failed to run: qemu-nbd --connect=/dev/nbd0 --discard=unmap --detect-zeroes=unmap --format=qcow2 /dev/dm-27: exit status 1 (qemu-nbd: Failed to set NBD socket)
fs_progress: "Staging_myvm: 328B (62B/s)"
We used 7.4 new version.
Best Regards
Dwi
What’s the storage driver on the source and target storage pools?
Can you also confirm that /dev/nbd0 exists on your system?
NBD existed in all computes
root@incus-01:/home/xxxxx# ls /dev/nbd0
/dev/nbd0
root@incus-01:/home/xxxxxx# file /dev/nbd0
/dev/nbd0: block special (43/0)
Storage Driver Source : LVM Cluster
Storage Driver Destination : LVM Cluster
 incus storage list
│          NAME          │   DRIVER   │ DESCRIPTION │ USED BY │  STATE  │
│ pool-iso-and-templates │ dir        │             │ 2       │ CREATED │
│ pool-qnap-hdd-01       │ lvmcluster │             │ 26      │ CREATED │
│ pool-qnap-ssd-01       │ lvmcluster │             │ 10      │ CREATED │
Fom pool-qnap-ssd-01 to pool-qnap-hdd-01
