Incus admin recover fails on custom storage volume
I try to recover the default pool from a broken incus server. The zpool is fine but when incus tries to recover the found containers it fails due to a missing custom volume although the volume is in the found volumes:
The recovery process will be scanning the following storage pools:
 - EXISTING: "pool1" (backend="zfs", source="pool1")
 - NEW: "default" (backend="zfs", source="/dev/sdd")
Would you like to continue with scanning for lost volumes? (yes/no) [default=yes]:
Scanning for unknown volumes...
The following unknown storage pools have been found:
 - Storage pool "default" of type "zfs"
The following unknown volumes have been found:
 - Container "alf-test" on pool "default" in project "default" (includes 0 snapshots)
 - Container "dms" on pool "default" in project "default" (includes 22 snapshots)
 - Container "dms-test" on pool "default" in project "default" (includes 5 snapshots)
 - Container "rproxy" on pool "default" in project "default" (includes 22 snapshots)
 - Volume "alfdata-20160428" on pool "default" in project "default" (includes 0 snapshots)
 - Volume "alfdata-20160516" on pool "default" in project "default" (includes 0 snapshots)
 - Volume "var" on pool "default" in project "default" (includes 0 snapshots)
 - Volume "alfdata" on pool "default" in project "default" (includes 30 snapshots)
 - Volume "images" on pool "default" in project "default" (includes 0 snapshots)
 - Container "alf-appliance-5" on pool "default" in project "archive" (includes 0 snapshots)
 - Container "alf-appliance-74" on pool "default" in project "archive" (includes 0 snapshots)
Would you like those to be recovered? (yes/no) [default=no]: yes
Starting recovery...
Error: Failed import request: Failed creating instance "alf-appliance-5" record in project "archive": Failed creating instance record: Failed initializing instance: Failed add validation for device "alfdata": Failed loading custom volume: Storage volume not found
Has anyone an idea how to work around this? Maybe this is a side effect of the new dependant volumes?
Is there a way to overwrite/bypass/manipulate that config, so I could just import as it is?
You mention dependent volumes. Is that something you’re using in this scenario?
The container dms uses the custom storage volume alfdata as additional disk device, but it’s not marked as dependent.
I wonderered if there is not a way to modify the instance config before retrying the restore.
Since we only need that custom volume to recover: There is no way to only restore parts from the zpool, right?
I first tried to import the zpool with a different name not to conflict with the running incus, but then the recover for the containers failed to name mismatch of the pool name (still expecting pool default)
Can you file an issue about this? It may just be some ordering issue we need to sort out.
sure. In this case I fiddled the data directly from the zfs volume but I will keep the vm for some time to test any changes later and additionally will create a more simplified testcase.
It would be a nice feature add something like a filter and/or an overwrite to the recover command
Thanks!
#3429: Incus admin recover fails on custom storage volume
work around is to mount the mentioned instance zfs filesystem and to remove the disk device from the backup.yaml and then try again.
