Today was en incus update on ubuntu 22. after update, missing network. it’s not possible to get ip to incus. i don’t now what update was? HELP
it was that one : Upgrade: incus-client:amd64 (6.0-202404040310-ubuntu22.04, 1:6.0-202404162314-ubuntu22.04), incus:amd64 (6.0-202404040310-ubuntu22.04, 1:6.0-202404162314-ubuntu22.04), incus-base:amd64 (6.0-202404040310-ubuntu22.04, 1:6.0-202404162314-ubuntu22.04)
End-Date: 2024-04-17 08:43:50
here is my incus network.
ipv4.address: 10.9.71.1/24
ipv4.nat: “true”
description: “”
type: bridge
- /1.0/profiles/default
- /1.0/profiles/windows
- /1.0/instances/zabbix
- /1.0/instances/graylog
- /1.0/instances/graylog2
- /1.0/instances/min11
- /1.0/instances/ubuntu22
managed: true
status: Created
locations: - none
Do you have Docker installed on your system?
no.
Okay, please show:
- sudo iptables -L -n -v
- sudo ip6tables -L -n -v
- sudo nft list ruleset
- cat /var/log/incus/incusd.log
Chain INPUT (policy DROP 7 packets, 2224 bytes)
pkts bytes target prot opt in out source destination
301K 449M ufw-before-logging-input all – * * 0.0.0.0/0 0.0.0.0/0
301K 449M ufw-before-input all – * * 0.0.0.0/0 0.0.0.0/0
563 97502 ufw-after-input all – * * 0.0.0.0/0 0.0.0.0/0
23 3408 ufw-after-logging-input all – * * 0.0.0.0/0 0.0.0.0/0
23 3408 ufw-reject-input all – * * 0.0.0.0/0 0.0.0.0/0
23 3408 ufw-track-input all – * * 0.0.0.0/0 0.0.0.0/0
Chain FORWARD (policy DROP 0 packets, 0 bytes)
0 0 ufw-before-logging-forward all – * * 0.0.0.0/0 0.0.0.0/0
0 0 ufw-before-forward all – * * 0.0.0.0/0 0.0.0.0/0
0 0 ufw-after-forward all – * * 0.0.0.0/0 0.0.0.0/0
0 0 ufw-after-logging-forward all – * * 0.0.0.0/0 0.0.0.0/0
0 0 ufw-reject-forward all – * * 0.0.0.0/0 0.0.0.0/0
0 0 ufw-track-forward all – * * 0.0.0.0/0 0.0.0.0/0
Chain OUTPUT (policy ACCEPT 122 packets, 6660 bytes)
224K 86M ufw-before-logging-output all – * * 0.0.0.0/0 0.0.0.0/0
224K 86M ufw-before-output all – * * 0.0.0.0/0 0.0.0.0/0
17814 3704K ufw-after-output all – * * 0.0.0.0/0 0.0.0.0/0
17814 3704K ufw-after-logging-output all – * * 0.0.0.0/0 0.0.0.0/0
17814 3704K ufw-reject-output all – * * 0.0.0.0/0 0.0.0.0/0
17814 3704K ufw-track-output all – * * 0.0.0.0/0 0.0.0.0/0
Chain ufw-after-forward (1 references)
Chain ufw-after-input (1 references)
265 24054 ufw-skip-to-policy-input udp – * * 0.0.0.0/0 0.0.0.0/0 udp dpt:137
225 54951 ufw-skip-to-policy-input udp – * * 0.0.0.0/0 0.0.0.0/0 udp dpt:138
0 0 ufw-skip-to-policy-input tcp – * * 0.0.0.0/0 0.0.0.0/0 tcp dpt:139
0 0 ufw-skip-to-policy-input tcp – * * 0.0.0.0/0 0.0.0.0/0 tcp dpt:445
45 14276 ufw-skip-to-policy-input udp – * * 0.0.0.0/0 0.0.0.0/0 udp dpt:67
0 0 ufw-skip-to-policy-input udp – * * 0.0.0.0/0 0.0.0.0/0 udp dpt:68
5 813 ufw-skip-to-policy-input all – * * 0.0.0.0/0 0.0.0.0/0 ADDRTYPE match dst-type BROADCAST
Chain ufw-after-logging-forward (1 references)
0 0 LOG all – * * 0.0.0.0/0 0.0.0.0/0 limit: avg 3/min burst 10 LOG flags 0 level 4 prefix "[UFW BLOCK] "
Chain ufw-after-logging-input (1 references)
7 2224 LOG all – * * 0.0.0.0/0 0.0.0.0/0 limit: avg 3/min burst 10 LOG flags 0 level 4 prefix "[UFW BLOCK] "
Chain ufw-after-logging-output (1 references)
Chain ufw-after-output (1 references)
Chain ufw-before-forward (1 references)
0 0 ACCEPT all – * * 0.0.0.0/0 0.0.0.0/0 ctstate RELATED,ESTABLISHED
0 0 ACCEPT icmp – * * 0.0.0.0/0 0.0.0.0/0 icmptype 3
0 0 ACCEPT icmp – * * 0.0.0.0/0 0.0.0.0/0 icmptype 11
0 0 ACCEPT icmp – * * 0.0.0.0/0 0.0.0.0/0 icmptype 12
0 0 ACCEPT icmp – * * 0.0.0.0/0 0.0.0.0/0 icmptype 8
0 0 ufw-user-forward all – * * 0.0.0.0/0 0.0.0.0/0
Chain ufw-before-input (1 references)
33486 17M ACCEPT all – lo * 0.0.0.0/0 0.0.0.0/0
265K 431M ACCEPT all – * * 0.0.0.0/0 0.0.0.0/0 ctstate RELATED,ESTABLISHED
1348 1210K ufw-logging-deny all – * * 0.0.0.0/0 0.0.0.0/0 ctstate INVALID
1348 1210K DROP all – * * 0.0.0.0/0 0.0.0.0/0 ctstate INVALID
0 0 ACCEPT udp – * * 0.0.0.0/0 0.0.0.0/0 udp spt:67 dpt:68
1319 189K ufw-not-local all – * * 0.0.0.0/0 0.0.0.0/0
763 91052 ACCEPT udp – * * 0.0.0.0/0 224.0.0.251 udp dpt:5353
9 1944 ACCEPT udp – * * 0.0.0.0/0 239.255.255.250 udp dpt:1900
547 96318 ufw-user-input all – * * 0.0.0.0/0 0.0.0.0/0
Chain ufw-before-logging-forward (1 references)
Chain ufw-before-logging-input (1 references)
Chain ufw-before-logging-output (1 references)
Chain ufw-before-output (1 references)
33490 17M ACCEPT all – * lo 0.0.0.0/0 0.0.0.0/0
173K 65M ACCEPT all – * * 0.0.0.0/0 0.0.0.0/0 ctstate RELATED,ESTABLISHED
17797 3703K ufw-user-output all – * * 0.0.0.0/0 0.0.0.0/0
Chain ufw-logging-allow (0 references)
0 0 LOG all – * * 0.0.0.0/0 0.0.0.0/0 limit: avg 3/min burst 10 LOG flags 0 level 4 prefix "[UFW ALLOW] "
Chain ufw-logging-deny (2 references)
736 663K RETURN all – * * 0.0.0.0/0 0.0.0.0/0 ctstate INVALID limit: avg 3/min burst 10
292 264K LOG all – * * 0.0.0.0/0 0.0.0.0/0 limit: avg 3/min burst 10 LOG flags 0 level 4 prefix "[UFW BLOCK] "
Chain ufw-not-local (1 references)
6 2188 RETURN all – * * 0.0.0.0/0 0.0.0.0/0 ADDRTYPE match dst-type LOCAL
773 93032 RETURN all – * * 0.0.0.0/0 0.0.0.0/0 ADDRTYPE match dst-type MULTICAST
540 94094 RETURN all – * * 0.0.0.0/0 0.0.0.0/0 ADDRTYPE match dst-type BROADCAST
0 0 ufw-logging-deny all – * * 0.0.0.0/0 0.0.0.0/0 limit: avg 3/min burst 10
0 0 DROP all – * * 0.0.0.0/0 0.0.0.0/0
Chain ufw-reject-forward (1 references)
Chain ufw-reject-input (1 references)
Chain ufw-reject-output (1 references)
Chain ufw-skip-to-policy-forward (0 references)
Chain ufw-skip-to-policy-input (7 references)
540 94094 DROP all – * * 0.0.0.0/0 0.0.0.0/0
Chain ufw-skip-to-policy-output (0 references)
Chain ufw-track-forward (1 references)
Chain ufw-track-input (1 references)
Chain ufw-track-output (1 references)
4544 273K ACCEPT tcp – * * 0.0.0.0/0 0.0.0.0/0 ctstate NEW
13135 3424K ACCEPT udp – * * 0.0.0.0/0 0.0.0.0/0 ctstate NEW
Chain ufw-user-forward (1 references)
Chain ufw-user-input (1 references)
0 0 ACCEPT tcp – * * 0.0.0.0/0 0.0.0.0/0 tcp dpt:5140
0 0 ACCEPT udp – * * 0.0.0.0/0 0.0.0.0/0 udp dpt:5140
Chain ufw-user-limit (0 references)
0 0 LOG all – * * 0.0.0.0/0 0.0.0.0/0 limit: avg 3/min burst 5 LOG flags 0 level 4 prefix "[UFW LIMIT BLOCK] "
0 0 REJECT all – * * 0.0.0.0/0 0.0.0.0/0 reject-with icmp-port-unreachable
Chain ufw-user-limit-accept (0 references)
Chain ufw-user-logging-forward (0 references)
Chain ufw-user-logging-input (0 references)
Chain ufw-user-logging-output (0 references)
Chain ufw-user-output (1 references)
Chain INPUT (policy DROP 0 packets, 0 bytes)
86 12491 ufw6-before-logging-input all * * ::/0 ::/0
86 12491 ufw6-before-input all * * ::/0 ::/0
0 0 ufw6-after-input all * * ::/0 ::/0
0 0 ufw6-after-logging-input all * * ::/0 ::/0
0 0 ufw6-reject-input all * * ::/0 ::/0
0 0 ufw6-track-input all * * ::/0 ::/0
0 0 ufw6-before-logging-forward all * * ::/0 ::/0
0 0 ufw6-before-forward all * * ::/0 ::/0
0 0 ufw6-after-forward all * * ::/0 ::/0
0 0 ufw6-after-logging-forward all * * ::/0 ::/0
0 0 ufw6-reject-forward all * * ::/0 ::/0
0 0 ufw6-track-forward all * * ::/0 ::/0
Chain OUTPUT (policy ACCEPT 20 packets, 2060 bytes)
118 16509 ufw6-before-logging-output all * * ::/0 ::/0
118 16509 ufw6-before-output all * * ::/0 ::/0
108 15861 ufw6-after-output all * * ::/0 ::/0
108 15861 ufw6-after-logging-output all * * ::/0 ::/0
108 15861 ufw6-reject-output all * * ::/0 ::/0
108 15861 ufw6-track-output all * * ::/0 ::/0
Chain ufw6-after-forward (1 references)
Chain ufw6-after-input (1 references)
0 0 ufw6-skip-to-policy-input udp * * ::/0 ::/0 udp dpt:137
0 0 ufw6-skip-to-policy-input udp * * ::/0 ::/0 udp dpt:138
0 0 ufw6-skip-to-policy-input tcp * * ::/0 ::/0 tcp dpt:139
0 0 ufw6-skip-to-policy-input tcp * * ::/0 ::/0 tcp dpt:445
0 0 ufw6-skip-to-policy-input udp * * ::/0 ::/0 udp dpt:546
0 0 ufw6-skip-to-policy-input udp * * ::/0 ::/0 udp dpt:547
Chain ufw6-after-logging-forward (1 references)
0 0 LOG all * * ::/0 ::/0 limit: avg 3/min burst 10 LOG flags 0 level 4 prefix "[UFW BLOCK] "
Chain ufw6-after-logging-input (1 references)
Chain ufw6-after-logging-output (1 references)
Chain ufw6-after-output (1 references)
Chain ufw6-before-forward (1 references)
0 0 DROP all * * ::/0 ::/0 rt type:0
0 0 ACCEPT all * * ::/0 ::/0 ctstate RELATED,ESTABLISHED
0 0 ACCEPT icmpv6 * * ::/0 ::/0 ipv6-icmptype 1
0 0 ACCEPT icmpv6 * * ::/0 ::/0 ipv6-icmptype 2
0 0 ACCEPT icmpv6 * * ::/0 ::/0 ipv6-icmptype 3
0 0 ACCEPT icmpv6 * * ::/0 ::/0 ipv6-icmptype 4
0 0 ACCEPT icmpv6 * * ::/0 ::/0 ipv6-icmptype 128
0 0 ACCEPT icmpv6 * * ::/0 ::/0 ipv6-icmptype 129
0 0 ufw6-user-forward all * * ::/0 ::/0
Chain ufw6-before-input (1 references)
0 0 ACCEPT all lo * ::/0 ::/0
0 0 ufw6-logging-deny all * * ::/0 ::/0 ctstate INVALID
0 0 DROP all * * ::/0 ::/0 ctstate INVALID
0 0 ACCEPT icmpv6 * * ::/0 ::/0 ipv6-icmptype 133 HL match HL == 255
0 0 ACCEPT icmpv6 * * ::/0 ::/0 ipv6-icmptype 134 HL match HL == 255
0 0 ACCEPT icmpv6 * * ::/0 ::/0 ipv6-icmptype 135 HL match HL == 255
0 0 ACCEPT icmpv6 * * ::/0 ::/0 ipv6-icmptype 136 HL match HL == 255
0 0 ACCEPT icmpv6 * * ::/0 ::/0 ipv6-icmptype 141 HL match HL == 255
0 0 ACCEPT icmpv6 * * ::/0 ::/0 ipv6-icmptype 142 HL match HL == 255
0 0 ACCEPT icmpv6 * * fe80::/10 ::/0 ipv6-icmptype 130
0 0 ACCEPT icmpv6 * * fe80::/10 ::/0 ipv6-icmptype 131
0 0 ACCEPT icmpv6 * * fe80::/10 ::/0 ipv6-icmptype 132
0 0 ACCEPT icmpv6 * * fe80::/10 ::/0 ipv6-icmptype 143
0 0 ACCEPT icmpv6 * * ::/0 ::/0 ipv6-icmptype 148 HL match HL == 255
0 0 ACCEPT icmpv6 * * ::/0 ::/0 ipv6-icmptype 149 HL match HL == 255
0 0 ACCEPT icmpv6 * * fe80::/10 ::/0 ipv6-icmptype 151 HL match HL == 1
0 0 ACCEPT icmpv6 * * fe80::/10 ::/0 ipv6-icmptype 152 HL match HL == 1
0 0 ACCEPT icmpv6 * * fe80::/10 ::/0 ipv6-icmptype 153 HL match HL == 1
0 0 ACCEPT icmpv6 * * ::/0 ::/0 ipv6-icmptype 144
0 0 ACCEPT icmpv6 * * ::/0 ::/0 ipv6-icmptype 145
0 0 ACCEPT icmpv6 * * ::/0 ::/0 ipv6-icmptype 146
0 0 ACCEPT icmpv6 * * ::/0 ::/0 ipv6-icmptype 147
0 0 ACCEPT udp * * fe80::/10 fe80::/10 udp spt:547 dpt:546
86 12491 ACCEPT udp * * ::/0 ff02::fb udp dpt:5353
0 0 ACCEPT udp * * ::/0 ff02::f udp dpt:1900
0 0 ufw6-user-input all * * ::/0 ::/0
Chain ufw6-before-logging-forward (1 references)
Chain ufw6-before-logging-input (1 references)
Chain ufw6-before-logging-output (1 references)
Chain ufw6-before-output (1 references)
0 0 ACCEPT all * lo ::/0 ::/0
6 288 ACCEPT icmpv6 * * ::/0 ::/0 ipv6-icmptype 133 HL match HL == 255
1 72 ACCEPT icmpv6 * * ::/0 ::/0 ipv6-icmptype 135 HL match HL == 255
3 288 ACCEPT icmpv6 * * fe80::/10 ::/0 ipv6-icmptype 143
108 15861 ufw6-user-output all * * ::/0 ::/0
Chain ufw6-logging-allow (0 references)
0 0 LOG all * * ::/0 ::/0 limit: avg 3/min burst 10 LOG flags 0 level 4 prefix "[UFW ALLOW] "
Chain ufw6-logging-deny (1 references)
0 0 RETURN all * * ::/0 ::/0 ctstate INVALID limit: avg 3/min burst 10
Chain ufw6-reject-forward (1 references)
Chain ufw6-reject-input (1 references)
Chain ufw6-reject-output (1 references)
Chain ufw6-skip-to-policy-forward (0 references)
Chain ufw6-skip-to-policy-input (6 references)
Chain ufw6-skip-to-policy-output (0 references)
Chain ufw6-track-forward (1 references)
Chain ufw6-track-input (1 references)
Chain ufw6-track-output (1 references)
0 0 ACCEPT tcp * * ::/0 ::/0 ctstate NEW
88 13801 ACCEPT udp * * ::/0 ::/0 ctstate NEW
Chain ufw6-user-forward (1 references)
Chain ufw6-user-input (1 references)
0 0 ACCEPT tcp * * ::/0 ::/0 tcp dpt:5140
0 0 ACCEPT udp * * ::/0 ::/0 udp dpt:5140
Chain ufw6-user-limit (0 references)
0 0 LOG all * * ::/0 ::/0 limit: avg 3/min burst 5 LOG flags 0 level 4 prefix "[UFW LIMIT BLOCK] "
0 0 REJECT all * * ::/0 ::/0 reject-with icmp6-port-unreachable
Chain ufw6-user-limit-accept (0 references)
Chain ufw6-user-logging-forward (0 references)
Chain ufw6-user-logging-input (0 references)
Chain ufw6-user-logging-output (0 references)
Chain ufw6-user-output (1 references)
table ip filter {
chain ufw-before-logging-input {
chain ufw-before-logging-output {
chain ufw-before-logging-forward {
chain ufw-before-input {
iifname "lo" counter packets 33689 bytes 17600426 accept
ct state related,established counter packets 269716 bytes 440144604 accept
ct state invalid counter packets 1355 bytes 1216498 jump ufw-logging-deny
ct state invalid counter packets 1355 bytes 1216498 drop
meta l4proto icmp icmp type destination-unreachable counter packets 0 bytes 0 accept
meta l4proto icmp icmp type time-exceeded counter packets 0 bytes 0 accept
meta l4proto icmp icmp type parameter-problem counter packets 0 bytes 0 accept
meta l4proto icmp icmp type echo-request counter packets 0 bytes 0 accept
meta l4proto udp udp sport 67 udp dport 68 counter packets 0 bytes 0 accept
counter packets 1321 bytes 189811 jump ufw-not-local
meta l4proto udp ip daddr 224.0.0.251 udp dport 5353 counter packets 763 bytes 91052 accept
meta l4proto udp ip daddr 239.255.255.250 udp dport 1900 counter packets 9 bytes 1944 accept
counter packets 549 bytes 96815 jump ufw-user-input
chain ufw-before-output {
oifname "lo" counter packets 33693 bytes 17600574 accept
ct state related,established counter packets 177074 bytes 65485095 accept
counter packets 17880 bytes 3721985 jump ufw-user-output
chain ufw-before-forward {
ct state related,established counter packets 0 bytes 0 accept
counter packets 0 bytes 0 jump ufw-user-forward
chain ufw-after-input {
meta l4proto udp udp dport 137 counter packets 265 bytes 24054 jump ufw-skip-to-policy-input
meta l4proto udp udp dport 138 counter packets 227 bytes 55448 jump ufw-skip-to-policy-input
meta l4proto tcp tcp dport 139 counter packets 0 bytes 0 jump ufw-skip-to-policy-input
meta l4proto tcp tcp dport 445 counter packets 0 bytes 0 jump ufw-skip-to-policy-input
meta l4proto udp udp dport 67 counter packets 45 bytes 14276 jump ufw-skip-to-policy-input
meta l4proto udp udp dport 68 counter packets 0 bytes 0 jump ufw-skip-to-policy-input
fib daddr type broadcast counter packets 5 bytes 813 jump ufw-skip-to-policy-input
chain ufw-after-output {
chain ufw-after-forward {
chain ufw-after-logging-input {
limit rate 3/minute burst 10 packets counter packets 7 bytes 2224 log prefix "[UFW BLOCK] "
chain ufw-after-logging-output {
chain ufw-after-logging-forward {
limit rate 3/minute burst 10 packets counter packets 0 bytes 0 log prefix "[UFW BLOCK] "
chain ufw-reject-input {
chain ufw-reject-output {
chain ufw-reject-forward {
chain ufw-track-input {
chain ufw-track-output {
meta l4proto tcp ct state new counter packets 4562 bytes 273720 accept
meta l4proto udp ct state new counter packets 13200 bytes 3441901 accept
chain ufw-track-forward {
chain INPUT {
type filter hook input priority filter; policy drop;
counter packets 306097 bytes 459152523 jump ufw-before-logging-input
counter packets 306097 bytes 459152523 jump ufw-before-input
counter packets 565 bytes 97999 jump ufw-after-input
counter packets 23 bytes 3408 jump ufw-after-logging-input
counter packets 23 bytes 3408 jump ufw-reject-input
counter packets 23 bytes 3408 jump ufw-track-input
chain OUTPUT {
type filter hook output priority filter; policy accept;
counter packets 228664 bytes 86808878 jump ufw-before-logging-output
counter packets 228664 bytes 86808878 jump ufw-before-output
counter packets 17897 bytes 3723209 jump ufw-after-output
counter packets 17897 bytes 3723209 jump ufw-after-logging-output
counter packets 17897 bytes 3723209 jump ufw-reject-output
counter packets 17897 bytes 3723209 jump ufw-track-output
chain FORWARD {
type filter hook forward priority filter; policy drop;
counter packets 0 bytes 0 jump ufw-before-logging-forward
counter packets 0 bytes 0 jump ufw-before-forward
counter packets 0 bytes 0 jump ufw-after-forward
counter packets 0 bytes 0 jump ufw-after-logging-forward
counter packets 0 bytes 0 jump ufw-reject-forward
counter packets 0 bytes 0 jump ufw-track-forward
chain ufw-logging-deny {
ct state invalid limit rate 3/minute burst 10 packets counter packets 743 bytes 669334 return
limit rate 3/minute burst 10 packets counter packets 292 bytes 263854 log prefix "[UFW BLOCK] "
chain ufw-logging-allow {
limit rate 3/minute burst 10 packets counter packets 0 bytes 0 log prefix "[UFW ALLOW] "
chain ufw-skip-to-policy-input {
counter packets 542 bytes 94591 drop
chain ufw-skip-to-policy-output {
chain ufw-skip-to-policy-forward {
counter packets 0 bytes 0 drop
chain ufw-not-local {
fib daddr type local counter packets 6 bytes 2188 return
fib daddr type multicast counter packets 773 bytes 93032 return
fib daddr type broadcast counter packets 542 bytes 94591 return
limit rate 3/minute burst 10 packets counter packets 0 bytes 0 jump ufw-logging-deny
chain ufw-user-input {
meta l4proto tcp tcp dport 5140 counter packets 0 bytes 0 accept
meta l4proto udp udp dport 5140 counter packets 0 bytes 0 accept
chain ufw-user-output {
chain ufw-user-forward {
chain ufw-user-logging-input {
chain ufw-user-logging-output {
chain ufw-user-logging-forward {
chain ufw-user-limit {
limit rate 3/minute counter packets 0 bytes 0 log prefix "[UFW LIMIT BLOCK] "
counter packets 0 bytes 0 reject
chain ufw-user-limit-accept {
table ip6 filter {
chain ufw6-before-logging-input {
chain ufw6-before-logging-output {
chain ufw6-before-logging-forward {
chain ufw6-before-input {
iifname "lo" counter packets 0 bytes 0 accept
rt type 0 counter packets 0 bytes 0 drop
meta l4proto ipv6-icmp icmpv6 type echo-reply counter packets 0 bytes 0 accept
ct state invalid counter packets 0 bytes 0 jump ufw6-logging-deny
ct state invalid counter packets 0 bytes 0 drop
meta l4proto ipv6-icmp icmpv6 type destination-unreachable counter packets 0 bytes 0 accept
meta l4proto ipv6-icmp icmpv6 type packet-too-big counter packets 0 bytes 0 accept
meta l4proto ipv6-icmp icmpv6 type time-exceeded counter packets 0 bytes 0 accept
meta l4proto ipv6-icmp icmpv6 type parameter-problem counter packets 0 bytes 0 accept
meta l4proto ipv6-icmp icmpv6 type echo-request counter packets 0 bytes 0 accept
meta l4proto ipv6-icmp icmpv6 type nd-router-solicit ip6 hoplimit 255 counter packets 0 bytes 0 accept
meta l4proto ipv6-icmp icmpv6 type nd-router-advert ip6 hoplimit 255 counter packets 0 bytes 0 accept
meta l4proto ipv6-icmp icmpv6 type nd-neighbor-solicit ip6 hoplimit 255 counter packets 0 bytes 0 accept
meta l4proto ipv6-icmp icmpv6 type nd-neighbor-advert ip6 hoplimit 255 counter packets 0 bytes 0 accept
meta l4proto ipv6-icmp icmpv6 type ip6 hoplimit 255 counter packets 0 bytes 0 accept
meta l4proto ipv6-icmp ip6 saddr fe80::/10 icmpv6 type counter packets 0 bytes 0 accept
meta l4proto ipv6-icmp ip6 saddr fe80::/10 icmpv6 type ip6 hoplimit 1 counter packets 0 bytes 0 accept
meta l4proto ipv6-icmp icmpv6 type counter packets 0 bytes 0 accept
meta l4proto udp ip6 saddr fe80::/10 ip6 daddr fe80::/10 udp sport 547 udp dport 546 counter packets 0 bytes 0 accept
meta l4proto udp ip6 daddr ff02::fb udp dport 5353 counter packets 86 bytes 12491 accept
meta l4proto udp ip6 daddr ff02::f udp dport 1900 counter packets 0 bytes 0 accept
counter packets 0 bytes 0 jump ufw6-user-input
chain ufw6-before-output {
oifname "lo" counter packets 0 bytes 0 accept
meta l4proto ipv6-icmp icmpv6 type nd-router-solicit ip6 hoplimit 255 counter packets 6 bytes 288 accept
meta l4proto ipv6-icmp icmpv6 type nd-neighbor-solicit ip6 hoplimit 255 counter packets 1 bytes 72 accept
meta l4proto ipv6-icmp ip6 saddr fe80::/10 icmpv6 type counter packets 3 bytes 288 accept
counter packets 108 bytes 15861 jump ufw6-user-output
chain ufw6-before-forward {
counter packets 0 bytes 0 jump ufw6-user-forward
chain ufw6-after-input {
meta l4proto udp udp dport 137 counter packets 0 bytes 0 jump ufw6-skip-to-policy-input
meta l4proto udp udp dport 138 counter packets 0 bytes 0 jump ufw6-skip-to-policy-input
meta l4proto tcp tcp dport 139 counter packets 0 bytes 0 jump ufw6-skip-to-policy-input
meta l4proto tcp tcp dport 445 counter packets 0 bytes 0 jump ufw6-skip-to-policy-input
meta l4proto udp udp dport 546 counter packets 0 bytes 0 jump ufw6-skip-to-policy-input
meta l4proto udp udp dport 547 counter packets 0 bytes 0 jump ufw6-skip-to-policy-input
chain ufw6-after-output {
chain ufw6-after-forward {
chain ufw6-after-logging-input {
chain ufw6-after-logging-output {
chain ufw6-after-logging-forward {
chain ufw6-reject-input {
chain ufw6-reject-output {
chain ufw6-reject-forward {
chain ufw6-track-input {
chain ufw6-track-output {
meta l4proto tcp ct state new counter packets 0 bytes 0 accept
meta l4proto udp ct state new counter packets 88 bytes 13801 accept
chain ufw6-track-forward {
chain INPUT {
counter packets 86 bytes 12491 jump ufw6-before-logging-input
counter packets 86 bytes 12491 jump ufw6-before-input
counter packets 0 bytes 0 jump ufw6-after-input
counter packets 0 bytes 0 jump ufw6-after-logging-input
counter packets 0 bytes 0 jump ufw6-reject-input
counter packets 0 bytes 0 jump ufw6-track-input
chain OUTPUT {
counter packets 118 bytes 16509 jump ufw6-before-logging-output
counter packets 118 bytes 16509 jump ufw6-before-output
counter packets 108 bytes 15861 jump ufw6-after-output
counter packets 108 bytes 15861 jump ufw6-after-logging-output
counter packets 108 bytes 15861 jump ufw6-reject-output
counter packets 108 bytes 15861 jump ufw6-track-output
chain FORWARD {
counter packets 0 bytes 0 jump ufw6-before-logging-forward
counter packets 0 bytes 0 jump ufw6-before-forward
counter packets 0 bytes 0 jump ufw6-after-forward
counter packets 0 bytes 0 jump ufw6-after-logging-forward
counter packets 0 bytes 0 jump ufw6-reject-forward
counter packets 0 bytes 0 jump ufw6-track-forward
chain ufw6-logging-deny {
ct state invalid limit rate 3/minute burst 10 packets counter packets 0 bytes 0 return
chain ufw6-logging-allow {
chain ufw6-skip-to-policy-input {
chain ufw6-skip-to-policy-output {
chain ufw6-skip-to-policy-forward {
chain ufw6-user-input {
chain ufw6-user-output {
chain ufw6-user-forward {
chain ufw6-user-logging-input {
chain ufw6-user-logging-output {
chain ufw6-user-logging-forward {
chain ufw6-user-limit {
chain ufw6-user-limit-accept {
table inet lxd {
chain pstrt.lxdbr0 {
type nat hook postrouting priority srcnat; policy accept;
ip saddr 10.72.248.0/24 ip daddr != 10.72.248.0/24 masquerade
ip6 saddr fd42:9fc7:1f00:52d6::/64 ip6 daddr != fd42:9fc7:1f00:52d6::/64 masquerade
chain fwd.lxdbr0 {
type filter hook forward priority filter; policy accept;
ip version 4 oifname "lxdbr0" accept
ip version 4 iifname "lxdbr0" accept
ip6 version 6 oifname "lxdbr0" accept
ip6 version 6 iifname "lxdbr0" accept
chain in.lxdbr0 {
type filter hook input priority filter; policy accept;
iifname "lxdbr0" tcp dport 53 accept
iifname "lxdbr0" udp dport 53 accept
iifname "lxdbr0" icmp type { destination-unreachable, time-exceeded, parameter-problem } accept
iifname "lxdbr0" udp dport 67 accept
iifname "lxdbr0" icmpv6 type { destination-unreachable, packet-too-big, time-exceeded, parameter-problem, nd-router-solicit, nd-neighbor-solicit, nd-neighbor-advert, mld2-listener-report } accept
iifname "lxdbr0" udp dport 547 accept
chain out.lxdbr0 {
oifname "lxdbr0" tcp sport 53 accept
oifname "lxdbr0" udp sport 53 accept
oifname "lxdbr0" icmp type { destination-unreachable, time-exceeded, parameter-problem } accept
oifname "lxdbr0" udp sport 67 accept
oifname "lxdbr0" icmpv6 type { destination-unreachable, packet-too-big, time-exceeded, parameter-problem, echo-request, nd-router-advert, nd-neighbor-solicit, nd-neighbor-advert, mld2-listener-report } accept
oifname "lxdbr0" udp sport 547 accept
table inet incus {
time=“2024-04-17T10:08:24+02:00” level=warning msg=“Failed getting exec control websocket reader, killing command” PID=593640 err=“websocket: close 1006 (abnormal closure): unexpected EOF” instance=graylog interactive=true project=default
time=“2024-04-17T10:08:54+02:00” level=warning msg=“Failed shutting down instance, forcefully stopping” err=“Failed shutting down instance, status is "Running": context deadline exceeded” instance=min11 project=default
time=“2024-04-17T10:43:44+02:00” level=warning msg=“Failed shutting down instance, forcefully stopping” err=“Failed shutting down instance, status is "Running": context deadline exceeded” instance=min11 project=default
Your firewall is blocking dhcp traffic, and the fix is documented here:
sudo ufw allow in on incusbr0
sudo ufw route allow in on incusbr0
sudo ufw route allow out on incusbr0
EDIT: I use ufw and not nft. I see you have nft rules for lxdbr0, but not incusbr0. I don’t know why iptables and nft are inconsistent on your system.
i don’t know what happened but incus ls give me
incus ls
Error: The incus daemon doesn’t appear to be started (socket path: /var/lib/incus/unix.socket)
and i have following in incus.log:
i install incus one more time and it’e working. thank you it was firewall issue.
i never enable nftables. i had a problem for port 5140/tcp my server not answer for that port i just active firewall and enable port 5140/tcp.
