Incus and restic
I wrote a simple script to backup one incus instance with restic:
#!/bin/sh
POOL=/var/lib/incus/storage-pools/default
if [ "x$2" = "x" ]
then
  echo "usage: incus-backup <instance> <target>"
  exit 1
fi
. /backup/.secret.$2
INSTANCE=$1
cd $POOL
if [ -d containers/$INSTANCE ]
then
  echo "$INSTANCE is container"
  SUB=containers
elif [ -d virtual-machines/$INSTANCE ]
then
  echo "$INSTANCE is virtual machine"
  SUB=virtual-machines
else
  echo "not found"
  exit 2
fi
incus snapshot create $INSTANCE backup.$$
proot -b $POOL/${SUB}-snapshots/$INSTANCE/backup.$$:/$SUB/$INSTANCE \
		restic backup --one-file-system /$SUB/$INSTANCE
incus snapshot delete $INSTANCE backup.$$
Basically it create a new snapshot of the instance and send this snapshot to restic.
So far, this works fine.
Recovery is then a simple
restic restore <ID> --target $POOL
In case of a total system crash and restoring to a fresh system, this just restore the directories/files in the storage pool. So I need an
incus admin recover
And here is my problem/question.
If there are snapshots present, all the snapshots are listed in the backup.yaml and the recover fails, since in the fresh system the snapshots are not there. I now know, how to remove the snapshots from the backup.yaml manually, but in a desater recovery situation I do not want to do this operations on all the instances by hand.
Is there the possibillity to add a parameter like “–instance-only” to the recover command ?
Thanks,
Patrick
