Hi
I am trying to install incusOS as a VM in incus for testing. The VM has the config “security.secureboot = false” and the web gui also shows that. But the incusOS installer claims the following error “System Check Error: Secure Boot is enabled, but install seed expects it to be disabled”.
Who is the culprit? Is it the incus host, who doesn’t disable secure boot, or is it the installer of incusOS?
incus config show incusOS --expanded
limits.cpu: "2"
limits.memory: 4GiB
security.secureboot: "false"
volatile.cloud-init.instance-id: 16c71ca8-6929-4868-a6fa-3ca9c88e950c
volatile.eth0.host_name: tapac3e9df9
volatile.eth0.hwaddr: 10:66:6a:ed:2b:89
volatile.uuid: f1b4900f-73f4-4eb3-bc4f-162efca5d6cd
volatile.uuid.generation: f1b4900f-73f4-4eb3-bc4f-162efca5d6cd
volatile.vm.definition: pc-q35-10.1
volatile.vm.rtc_adjustment: "-1"
volatile.vm.rtc_offset: "-1"
volatile.vsock_id: "4031541588"
nictype: bridged
parent: vmbr0
vlan: "200"
iso-volume:
boot.priority: "10"
pool: default
source: IncusOS-202603081756.iso
pool: default
- test
