Incus + cloudflared (cli, manual tunnels)
Hi, Has anyone succeeded in exposing the incus daemon/api through cloudflared?
/etc/cloudflared/config.yml
tunnel: <redacted>
credentials-file: /etc/cloudflared/<redacted>.json
ingress:
  - hostname: incus.example.xyz
    service: unix:/var/lib/incus/unix.socket
  - service: http_status:404
This seems to work, but only partially. for example:
the following command incus ls works without issues but incus start ct responds with Error: Failed to fetch https://incus.example.xyz:443/1.0/events: 502 Bad Gateway although the operation seems actually go through still so in this case the container would be started.
Sounds like some issue with the proxy and websocket handling.
Maybe there’s some configuration you need to do to correctly handle websocket?
So the way I got it working for me was by forcing the cloudflared daemon to use the quic protocol instead of http2. Also, I haven’t tested this but it doesn’t hurt to enable Websockets under Websites → <domain> → Network:
protocol: quic
tunnel: <redacted>
ingress:
OR
cloudflared tunnel --protocol quic run
