Hi all,
I want to passtrough my coral tpu usb device to a container. How can this be done? Do i need to passtrough the full device?
After that i want to passtrough the device from incus to docker. How could that be done?
This all has to work with frigate.
stgraber
(Stéphane Graber)
2
coral-early:
productid: 089a
required: "false"
type: usb
vendorid: 1a6e
coral-late:
productid: "9302"
required: "false"
type: usb
vendorid: 18d1
That’s how I do it here with Frigate.
Thanks for the reply. Can i just put inlt in the config of the container?
stgraber
(Stéphane Graber)
4
Yep, should work fine, that’s what I’m using here.
So unless your Coral is somehow a different revision than mine, it should just work.
Perfect,
Tomorow im recieving my coral tpu and will try this.
Thanks again for your reply.
