Incus container in Bridge-mode with local IP-addr dont gets dhcp leases directly
Hello community,
I plan to change from lxc to incus, but I have actually big network issues in my fresh incus installations.
Both are using fresh debian 13 systems (one headless[server] + one as testsystem@laptop).
My actually main issue is dropped when I try to use new containers with a bridged network.
Generally is my goal to use a bridge to directly get a dhcp release from the local network.
Ive installed incus with the following commands:
apt install incus incus-client bridge-utils
adduser $user incus-admin
reboot now
incus admin init
ufw rules
sudo ufw allow in on incusbr0
sudo ufw route allow in on incusbr0
sudo ufw route allow out on incusbr0
# set incus firewall to false
    incus network set incusbr-001 ipv6.firewall false
    incus network set incusbr-001 ipv4.firewall false
config host
ip a:
lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
inet6 ::1/128 scope host noprefixroute
2: eno1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether alias_for_macaddr brd ff:ff:ff:ff:ff:ff
altname enp3s0
altname enx0cc47a869ff6
inet 192.168.28.10/24 brd 192.168.28.255 scope global dynamic noprefixroute eno1
valid_lft 5483sec preferred_lft 4583sec
inet6 alias_for_addr scope link
3: eno2: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
altname enp4s0
altname enx0cc47a869ff7
4: incusbr-001: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
inet 10.140.64.1/24 scope global incusbr-001
inet6 alias_for_addr/64 scope global
inet6 alias_for_addr/64 scope link proto kernel_ll
20: vethb52e2c7c@if19: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master incusbr-001 state UP group default qlen 1000
link/ether alias_for_macaddr brd ff:ff:ff:ff:ff:ff link-netnsid 0
23: tap091611b5: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq master incusbr-001 state UP group default qlen 1000
25: veth9d773da3@if24: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master incusbr-001 state UP group default qlen 1000
link/ether alias_for_macaddr brd ff:ff:ff:ff:ff:ff link-netnsid 2
incus network show incusbr-001
ipv4.address: 10.140.64.1/24
ipv4.firewall: “false”
ipv4.nat: “true”
ipv6.address: alias_for_addr::1/64
ipv6.firewall: “false”
ipv6.nat: “true”
description: “”
type: bridge
* /1.0/instances/001-smb
* /1.0/instances/002-test
* /1.0/instances/003-test
* /1.0/profiles/default
  managed: true
  status: Created
  locations:
* none
  project: default
incus profile show default
config: {}
eno1:
network: incusbr-001
pool: 001_sys-rel
create two test containers
incus launch images:debian/13 001-smb # debian
incus launch images:ubuntu/noble 002-test # ubuntu
incus console 002-test --type=console
On containers side
1st try - systemd-networkd:
ip a gives:
24: eno1@if25: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
inet6 alias_for_addr:6aff:fee5:3c2f/64 scope global dynamic mngtmpaddr
inet6 falias_for_addr/64 scope link
there are in both containers a vth created like above one: eno1@if22,
but only the network name eno1 with commands link ip are excepted
default there is only systemd-networkd installed => config are:
default are only /etc/systemd/network/eth0.network:
\[Match\]
Name=eth0
    [Network]
    DHCP=true
    [DHCPv4]
    UseDomains=true
    UseMTU=true
    [DHCP]
    ClientIdentifier=mac
I tryed to create
    /etc/systemd/network/eno1.network
or
    /etc/systemd/network/eno@if22.network
with same content (tryed it also with “eno1” only):
 [Match]
    Name=eno1@if25
    [Network]
    DHCP=true
    [DHCPv4]
    UseDomains=true
    UseMTU=true
    [DHCP]
restart
systemctl restart systemd-networkd
config dns
nano /etc/resolv.conf
nano /etc/systemd/resolv.conf
set ip from local network + briged incus network
restart
systemctl restart systemd-resoveconf
but I dont get an dhcp release / ip
2nd try - setup manually with ip link:
with local network
link set eno1 down
ip addr add 192.168.28.12/24 dev eno1
link set eno1 up
with bridged network
link set eno1 down
ip addr add 10.140.64.12/24 dev eno1
link set eno1 up
But all my tries are without an geting an ip address.
But if i using a fresh installed VM from incus, it get directly an ip address.
Can anyone explain where are my fallacies and how can i fix these issue?
3rd try - manual packages install with networkmanager + ifupdown
systemctl disable systemd-networkd
systemctl disable systemd-networkd.socket
systemctl stop systemd-networkd
systemctl stop systemd-networkd.socket
dpkg -i networkmanager.deb # + fucking dependencies
dpkg -i networkmanager.deb # after some trys, i figure out, network manager needs ifupdown => see network manager config, for working
be sure all are enabled and started
systemctl enable NetworkManager
systemctl enable ifupdown
systemctl start NetworkManager
systemctl start ifupdown
config
nano /etc/network/interfaces
auto eno1
allow-hotplug eno1
iface eno1 inet dhcp
setup
ifup eno1
tada => connection is established
I am really irritated…
But the containers are only gets its IPs from the virtual incusbr-001 bridged network.
Is it only possible to get an address from the local network If I use the “physical” mode?
Generraly its not a problem for me, but its good to know If i will use one ethernet port for both, the brige with localaddr + connection(like ssh) to the server [dhcp leases for containers and one for the server on the same physical port].
Is there a way to do this?
Is there a good book or pdf available to understanding possible configurations with incus?
I only can find multiple virtualization books, but these are handle a bunch of virt technics like libvirt, quemu, and so on, but no book goes directly deep into the incus configurations.
Thank you for your help.
Edit 1-2: letter corrections
You were totally wrong. You should create a bridge in host without incus involved. Read this post:
More specifically:
  • if you create an incus managed bridge, then it will have its own subnet with routing and NAT, and its own DHCP service managed by incus
  • if you use an existing bridge (“unmanaged”) then the instances will just connect directly to that bridge, and any router and DHCP will be whatever is upstream on that bridge
I think the second option is what you want. In that case, it should look like this:
brian@lxd1:~$ incus network list
| NAME  |   TYPE   | MANAGED | IPV4 | IPV6 | DESCRIPTION | USED BY | STATE |
| br0   | bridge   | NO      |      |      |             | 14      |       |
brian@lxd1:~$ incus profile show default
    nictype: bridged
    parent: br0
    pool: zfs
... etc
Or you can create a different named profile, say “br0”, and assign this to instances you want to be attached directly to the bridge.
Either way, br0 is a bridge you already created, e.g. using netplan or ifupdown configs.
