I’m having issues with reaching the outside world from my containers (ping google.com, Git, etc).
I’ve done hours of searching and reading various other forum posts, and tried the various suggestions, but have not been able to fix the issue.
I’d be very grateful for some assistance in getting this working.
Below are some of the debug commands that seem to be useful from the other similar posts!
Please let me know of any other details that may be required.
Many thanks!
Hetzner Cloud.
Host and container both Ubuntu 24.04, container via:
incus launch images:ubuntu/24.04 rpc
Incus version:
testhost@testhost-one:~$ incus --version
6.3
Host
Firewall / rules status:
testhost@testhost-one:~$ sudo ufw status
Status: inactive
testhost@testhost-one:~$ sudo iptables -t nat -L -n -v --line-numbers
Chain PREROUTING (policy ACCEPT 0 packets, 0 bytes)
num pkts bytes target prot opt in out source destination
Chain INPUT (policy ACCEPT 0 packets, 0 bytes)
Chain OUTPUT (policy ACCEPT 0 packets, 0 bytes)
Chain POSTROUTING (policy ACCEPT 0 packets, 0 bytes)
testhost@testhost-one:~$ ps aux | grep dnsmasq
incus 19195 0.0 0.1 14472 5248 ? Ss Aug04 0:00 dnsmasq --keep-in-foreground --strict-order --bind-interfaces --except-interface=lo --pid-file= --no-ping --interface=incusbr0 --dhcp-rapid-commit --no-negcache --quiet-dhcp --quiet-dhcp6 --quiet-ra --listen-address=10.185.39.1 --dhcp-no-override --dhcp-authoritative --dhcp-leasefile=/var/lib/incus/networks/incusbr0/dnsmasq.leases --dhcp-hostsfile=/var/lib/incus/networks/incusbr0/dnsmasq.hosts --dhcp-range 10.185.39.2,10.185.39.254,1h --listen-address=fd42:5ea3:6855:6e02::1 --enable-ra --dhcp-range ::,constructor:incusbr0,ra-stateless,ra-names -s incus --interface-name _gateway.incus,incusbr0 -S /incus/ --conf-file=/var/lib/incus/networks/incusbr0/dnsmasq.raw -u incus -g incus
wonders+ 21621 0.0 0.0 6544 2304 pts/0 S+ 12:59 0:00 grep --color=auto dnsmasq
testhost@testhost-one:~$ ip -4 route show
10.0.0.0/16 via 10.0.0.1 dev enp7s0 proto dhcp src 10.0.0.6 metric 1003 mtu 1450
10.0.0.1 dev enp7s0 proto dhcp scope link src 10.0.0.6 metric 1003 mtu 1450
10.185.39.0/24 dev incusbr0 proto kernel scope link src 10.185.39.1
169.254.169.254 via 172.31.1.1 dev eth0 proto dhcp src 100.65.193.187 metric 100
172.31.1.1 dev eth0 proto dhcp scope link src 100.65.193.187 metric 100
Pinging google.com (working):
testhost@testhost-one:~$ ping google.com
PING google.com (2a00:1450:4001:812::200e) 56 data bytes
64 bytes from fra16s52-in-x0e.1e100.net (2a00:1450:4001:812::200e): icmp_seq=1 ttl=115 time=6.38 ms
64 bytes from fra16s52-in-x0e.1e100.net (2a00:1450:4001:812::200e): icmp_seq=2 ttl=115 time=6.77 ms
Incus info:
testhost@testhost-one:~$ incus info --show-log rpc
Status: RUNNING
Type: container
PID: 18217
Created: 2024/08/04 23:16 UTC
Last Used: 2024/08/04 23:16 UTC
Started: 2024/08/04 23:16 UTC
Resources:
Processes: 12
CPU usage:
CPU usage (in seconds): 19
Memory usage:
Memory (current): 438.85MiB
Network usage:
Type: broadcast
State: UP
Host interface: veth5f2c0c8a
MAC address: 00:16:3e:2a:d6:0d
MTU: 1500
Bytes received: 15.92MB
Bytes sent: 742.17kB
Packets received: 8568
Packets sent: 6736
IP addresses:
inet: 10.185.39.39/24 (global)
inet6: fd42:5ea3:6855:6e02:216:3eff:fe2a:d60d/64 (global)
inet6: fe80::216:3eff:fe2a:d60d/64 (link)
lo:
Type: loopback
State: UP
MTU: 65536
Bytes received: 10.69kB
Bytes sent: 10.69kB
Packets received: 84
Packets sent: 84
IP addresses:
inet: 127.0.0.1/8 (local)
inet6: ::1/128 (local)
Log:
Incus list:
| first | RUNNING | 10.185.39.190 (eth0) | fd42:5ea3:6855:6e02:216:3eff:fe0c:a71f (eth0) | CONTAINER | 0 |
| rpc | RUNNING | 10.185.39.39 (eth0) | fd42:5ea3:6855:6e02:216:3eff:fe2a:d60d (eth0) | CONTAINER | 0 |
Incus network list:
testhost@testhost-one:~$ incus network list
| NAME | TYPE | MANAGED | IPV4 | IPV6 | DESCRIPTION | USED BY | STATE |
| enp7s0 | physical | false | | | | 0 | |
| eth0 | physical | false | | | | 0 | |
| incusbr0 | bridge | true | 10.185.39.1/24 | fd42:5ea3:6855:6e02::1/64 | | 3 | CREATED |
| lo | loopback | false | | | | 0 | |
resolvectl:
testhost@testhost-one:~$ resolvectl
Global
Protocols: -LLMNR -mDNS -DNSOverTLS DNSSEC=no/unsupported
resolv.conf mode: stub
Link 2 (eth0)
Current Scopes: DNS
Protocols: +DefaultRoute -LLMNR -mDNS -DNSOverTLS DNSSEC=no/unsupported
Current DNS Server: 2a01:4ff:ff00::add:1
DNS Servers: 2a01:4ff:ff00::add:1 2a01:4ff:ff00::add:2
Link 3 (enp7s0)
Current Scopes: none
Protocols: -DefaultRoute -LLMNR -mDNS -DNSOverTLS DNSSEC=no/unsupported
Link 4 (incusbr0)
Link 6 (vethc20fe739)
Link 8 (veth5f2c0c8a)
Container
Pinging sibling container (working):
root@rpc:~# ping 10.0.0.5
PING 10.0.0.5 (10.0.0.5) 56(84) bytes of data.
64 bytes from 10.0.0.5: icmp_seq=1 ttl=62 time=5.91 ms
64 bytes from 10.0.0.5: icmp_seq=2 ttl=62 time=0.568 ms
From the container - pinging google.com (not working):
root@rpc:~# ping google.com
PING google.com (142.250.181.238) 56(84) bytes of data.
From _gateway.incus (10.185.39.1) icmp_seq=1 Destination Net Unreachable
From _gateway.incus (10.185.39.1) icmp_seq=2 Destination Net Unreachable
Other details from the container:
root@rpc:~# ip a
inet6 ::1/128 scope host
7: eth0@if8: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 00:16:3e:2a:d6:0d brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet 10.185.39.39/24 metric 100 brd 10.185.39.255 scope global dynamic eth0
valid_lft 2490sec preferred_lft 2490sec
inet6 fd42:5ea3:6855:6e02:216:3eff:fe2a:d60d/64 scope global mngtmpaddr noprefixroute
inet6 fe80::216:3eff:fe2a:d60d/64 scope link
root@rpc:~# ip r
default via 10.185.39.1 dev eth0 proto dhcp src 10.185.39.39 metric 100
10.185.39.0/24 dev eth0 proto kernel scope link src 10.185.39.39 metric 100
10.185.39.1 dev eth0 proto dhcp scope link src 10.185.39.39 metric 100
resolvectl:
root@rpc:~# resolvectl
Global
Link 7 (eth0)
Current Scopes: DNS
Current DNS Server: 10.185.39.1
DNS Servers: 10.185.39.1 fd42:5ea3:6855:6e02::1 fe80::216:3eff:fea9:18cf
DNS Domain: incus
