I am probably doing something unordinary:
I create a privileged Alpine container, installed docker in it and made /var/lib/docker/volumes a btrfs subvolume.
I created as well a docker container using a volume, which I changed to a btrfs subvolume too (so created the subvol and rsynced all data from the original docker volume) .
I do all this to use it in a cluster setup, so I can sync the cluster data using btrfs snapshots. So far so good and all runs fine.
Now when I want to copy the incus container to another host to form the cluster, I get:
incus copy --refresh <remote_host>:rtr1 local: -v
Error: Failed instance creation: Error transferring instance data: Failed migration on target: Failed creating instance on target: Failed to run: btrfs receive -e /var/lib/incus/storage-pools/ssd/containers/migration.724019367: exit status 1 (At subvol router ERROR: creating subvolume router failed: File exists)
The docker volume (btrfs subvolume) name is router in this case
Exporting the container works fine, but get the same error on importing. Both incus hosts run their storage on btrfs. Both incus versions are on 6.7
As workaround I create a new incus container on the second host and just import all data/docker images…after that the cluster runs fine…just weird that copying the container (to be lazy ;-)) doesn’t seem to work…
