Incus Default size Fixed as 30Gb and unable to increase size incus 6.0 & Rocky Linux 9.5 incus 6.4 Problem
Dear Inucs Team,
Greetings , i have faced two different issues as below
  1. Incus Default size Fixed as 30Gb and unable to increase size incus 6.0 in debian 12 with zabbly based 6.0 LTS repository , during incus admin init not set any storage size and using btrfs , not able to edit and change fixed disk size 30Gb, but have 256 GB ssd originally used by host machine (used as physical x86_64 amd based machine , some time vm’s stopped working without any error logs .
  2. Faced Issues on Rocky linux 9.5 with below details need to resolve issues
    physical machine AMD ryzen 7 iwth 64gb ram
  • Distribution:NAME=“Rocky Linux”
    VERSION=“9.5 (Blue Onyx)”
  • Distribution version: 9.5
  • The output of “incus info” or if that fails:
    • Kernel version:5.14.0-503.16.1.el9_5.x86_64
    • LXC version: Not Shown
    • Incus version:6.4
    • Storage backend in use:[root@jgccloudch1 ~]# incus storage list
      | NAME | DRIVER | DESCRIPTION | USED BY | STATE |
      | default | dir | | 1 | CREATED |
Issue description
installed using Making sure you're not a bot! after installation done show errors
result
[root@jgccloudch1 ~]# lsmod | grep kvm
kvm_amd 241664 0
kvm 1400832 1 kvm_amd
ccp 163840 1 kvm_amd
[root@jgccloudch1 ~]# qemu-system-x86_64 -machine accel=kvm -cpu host
qemu-system-x86_64: warning: Machine type ‘pc-i440fx-rhel7.6.0’ is deprecated: machine types for previous major releases are deprecated
VNC server running on ::1:5900
[root@jgccloudch1 ~]# lscpu | grep Virtualization
Virtualization: AMD-V
[root@jgccloudch1 ~]# qemu-system-x86_64 --version
QEMU emulator version 9.0.0 (qemu-kvm-9.0.0-10.el9_5)
Copyright (c) 2003-2024 Fabrice Bellard and the QEMU Project developers
Rocky Linux 9.5 incus installed with qemu-kvm and linked with sudo ln -s /usr/libexec/qemu-kvm /usr/bin/qemu-system-x86_64 but face error as below:
[root@jgccloudch1 ~]# incus launch images:ubuntu/22.04 test-vm --vm
Launching test-vm
Error: Failed instance creation: Failed creating instance record: Instance type “virtual-machine” is not supported on this server: QEMU failed to run feature checks
incus info not have QEMU true , details incus information as below
[root@jgccloudch1 ~]# incus info
core.https_address: :8443
images.auto_update_interval: “0”
api_extensions:
  • storage_zfs_remove_snapshots
  • container_host_shutdown_timeout
  • container_stop_priority
  • container_syscall_filtering
  • auth_pki
  • container_last_used_at
  • etag
  • patch
  • usb_devices
  • https_allowed_credentials
  • image_compression_algorithm
  • directory_manipulation
  • container_cpu_time
  • storage_zfs_use_refquota
  • storage_lvm_mount_options
  • network
  • profile_usedby
  • container_push
  • container_exec_recording
  • certificate_update
  • container_exec_signal_handling
  • gpu_devices
  • container_image_properties
  • migration_progress
  • id_map
  • network_firewall_filtering
  • network_routes
  • storage
  • file_delete
  • file_append
  • network_dhcp_expiry
  • storage_lvm_vg_rename
  • storage_lvm_thinpool_rename
  • network_vlan
  • image_create_aliases
  • container_stateless_copy
  • container_only_migration
  • storage_zfs_clone_copy
  • unix_device_rename
  • storage_lvm_use_thinpool
  • storage_rsync_bwlimit
  • network_vxlan_interface
  • storage_btrfs_mount_options
  • entity_description
  • image_force_refresh
  • storage_lvm_lv_resizing
  • id_map_base
  • file_symlinks
  • container_push_target
  • network_vlan_physical
  • storage_images_delete
  • container_edit_metadata
  • container_snapshot_stateful_migration
  • storage_driver_ceph
  • storage_ceph_user_name
  • resource_limits
  • storage_volatile_initial_source
  • storage_ceph_force_osd_reuse
  • storage_block_filesystem_btrfs
  • resources
  • kernel_limits
  • storage_api_volume_rename
  • network_sriov
  • console
  • restrict_dev_incus
  • migration_pre_copy
  • infiniband
  • dev_incus_events
  • proxy
  • network_dhcp_gateway
  • file_get_symlink
  • network_leases
  • unix_device_hotplug
  • storage_api_local_volume_handling
  • operation_description
  • clustering
  • event_lifecycle
  • storage_api_remote_volume_handling
  • nvidia_runtime
  • container_mount_propagation
  • container_backup
  • dev_incus_images
  • container_local_cross_pool_handling
  • proxy_unix
  • proxy_udp
  • clustering_join
  • proxy_tcp_udp_multi_port_handling
  • network_state
  • proxy_unix_dac_properties
  • container_protection_delete
  • unix_priv_drop
  • pprof_http
  • proxy_haproxy_protocol
  • network_hwaddr
  • proxy_nat
  • network_nat_order
  • container_full
  • backup_compression
  • nvidia_runtime_config
  • storage_api_volume_snapshots
  • storage_unmapped
  • projects
  • network_vxlan_ttl
  • container_incremental_copy
  • usb_optional_vendorid
  • snapshot_scheduling
  • snapshot_schedule_aliases
  • container_copy_project
  • clustering_server_address
  • clustering_image_replication
  • container_protection_shift
  • snapshot_expiry
  • container_backup_override_pool
  • snapshot_expiry_creation
  • network_leases_location
  • resources_cpu_socket
  • resources_gpu
  • resources_numa
  • kernel_features
  • id_map_current
  • event_location
  • storage_api_remote_volume_snapshots
  • network_nat_address
  • container_nic_routes
  • cluster_internal_copy
  • seccomp_notify
  • lxc_features
  • container_nic_ipvlan
  • network_vlan_sriov
  • storage_cephfs
  • container_nic_ipfilter
  • resources_v2
  • container_exec_user_group_cwd
  • container_syscall_intercept
  • container_disk_shift
  • storage_shifted
  • resources_infiniband
  • daemon_storage
  • instances
  • image_types
  • resources_disk_sata
  • clustering_roles
  • images_expiry
  • resources_network_firmware
  • backup_compression_algorithm
  • ceph_data_pool_name
  • container_syscall_intercept_mount
  • compression_squashfs
  • container_raw_mount
  • container_nic_routed
  • container_syscall_intercept_mount_fuse
  • container_disk_ceph
  • virtual-machines
  • image_profiles
  • clustering_architecture
  • resources_disk_id
  • storage_lvm_stripes
  • vm_boot_priority
  • unix_hotplug_devices
  • api_filtering
  • instance_nic_network
  • clustering_sizing
  • firewall_driver
  • projects_limits
  • container_syscall_intercept_hugetlbfs
  • limits_hugepages
  • container_nic_routed_gateway
  • projects_restrictions
  • custom_volume_snapshot_expiry
  • volume_snapshot_scheduling
  • trust_ca_certificates
  • snapshot_disk_usage
  • clustering_edit_roles
  • container_nic_routed_host_address
  • container_nic_ipvlan_gateway
  • resources_usb_pci
  • resources_cpu_threads_numa
  • resources_cpu_core_die
  • api_os
  • container_nic_routed_host_table
  • container_nic_ipvlan_host_table
  • container_nic_ipvlan_mode
  • resources_system
  • images_push_relay
  • network_dns_search
  • container_nic_routed_limits
  • instance_nic_bridged_vlan
  • network_state_bond_bridge
  • usedby_consistency
  • custom_block_volumes
  • clustering_failure_domains
  • resources_gpu_mdev
  • console_vga_type
  • projects_limits_disk
  • network_type_macvlan
  • network_type_sriov
  • container_syscall_intercept_bpf_devices
  • network_type_ovn
  • projects_networks
  • projects_networks_restricted_uplinks
  • custom_volume_backup
  • backup_override_name
  • storage_rsync_compression
  • network_type_physical
  • network_ovn_external_subnets
  • network_ovn_nat
  • network_ovn_external_routes_remove
  • tpm_device_type
  • storage_zfs_clone_copy_rebase
  • gpu_mdev
  • resources_pci_iommu
  • resources_network_usb
  • resources_disk_address
  • network_physical_ovn_ingress_mode
  • network_ovn_dhcp
  • network_physical_routes_anycast
  • projects_limits_instances
  • network_state_vlan
  • instance_nic_bridged_port_isolation
  • instance_bulk_state_change
  • network_gvrp
  • instance_pool_move
  • gpu_sriov
  • pci_device_type
  • storage_volume_state
  • network_acl
  • migration_stateful
  • disk_state_quota
  • storage_ceph_features
  • projects_compression
  • projects_images_remote_cache_expiry
  • certificate_project
  • network_ovn_acl
  • projects_images_auto_update
  • projects_restricted_cluster_target
  • images_default_architecture
  • network_ovn_acl_defaults
  • gpu_mig
  • project_usage
  • network_bridge_acl
  • warnings
  • projects_restricted_backups_and_snapshots
  • clustering_join_token
  • clustering_description
  • server_trusted_proxy
  • clustering_update_cert
  • storage_api_project
  • server_instance_driver_operational
  • server_supported_storage_drivers
  • event_lifecycle_requestor_address
  • resources_gpu_usb
  • clustering_evacuation
  • network_ovn_nat_address
  • network_bgp
  • network_forward
  • custom_volume_refresh
  • network_counters_errors_dropped
  • metrics
  • image_source_project
  • clustering_config
  • network_peer
  • linux_sysctl
  • network_dns
  • ovn_nic_acceleration
  • certificate_self_renewal
  • instance_project_move
  • storage_volume_project_move
  • cloud_init
  • network_dns_nat
  • database_leader
  • instance_all_projects
  • clustering_groups
  • ceph_rbd_du
  • instance_get_full
  • qemu_metrics
  • gpu_mig_uuid
  • event_project
  • clustering_evacuation_live
  • instance_allow_inconsistent_copy
  • network_state_ovn
  • storage_volume_api_filtering
  • image_restrictions
  • storage_zfs_export
  • network_dns_records
  • storage_zfs_reserve_space
  • network_acl_log
  • storage_zfs_blocksize
  • metrics_cpu_seconds
  • instance_snapshot_never
  • certificate_token
  • instance_nic_routed_neighbor_probe
  • event_hub
  • agent_nic_config
  • projects_restricted_intercept
  • metrics_authentication
  • images_target_project
  • images_all_projects
  • cluster_migration_inconsistent_copy
  • cluster_ovn_chassis
  • container_syscall_intercept_sched_setscheduler
  • storage_lvm_thinpool_metadata_size
  • storage_volume_state_total
  • instance_file_head
  • instances_nic_host_name
  • image_copy_profile
  • container_syscall_intercept_sysinfo
  • clustering_evacuation_mode
  • resources_pci_vpd
  • qemu_raw_conf
  • storage_cephfs_fscache
  • network_load_balancer
  • vsock_api
  • instance_ready_state
  • network_bgp_holdtime
  • storage_volumes_all_projects
  • metrics_memory_oom_total
  • storage_buckets
  • storage_buckets_create_credentials
  • metrics_cpu_effective_total
  • projects_networks_restricted_access
  • storage_buckets_local
  • loki
  • acme
  • internal_metrics
  • cluster_join_token_expiry
  • remote_token_expiry
  • init_preseed
  • storage_volumes_created_at
  • cpu_hotplug
  • projects_networks_zones
  • network_txqueuelen
  • cluster_member_state
  • instances_placement_scriptlet
  • storage_pool_source_wipe
  • zfs_block_mode
  • instance_generation_id
  • disk_io_cache
  • amd_sev
  • storage_pool_loop_resize
  • migration_vm_live
  • ovn_nic_nesting
  • oidc
  • network_ovn_l3only
  • ovn_nic_acceleration_vdpa
  • cluster_healing
  • instances_state_total
  • auth_user
  • security_csm
  • instances_rebuild
  • numa_cpu_placement
  • custom_volume_iso
  • network_allocations
  • zfs_delegate
  • storage_api_remote_volume_snapshot_copy
  • operations_get_query_all_projects
  • metadata_configuration
  • syslog_socket
  • event_lifecycle_name_and_project
  • instances_nic_limits_priority
  • disk_initial_volume_configuration
  • operation_wait
  • image_restriction_privileged
  • cluster_internal_custom_volume_copy
  • disk_io_bus
  • storage_cephfs_create_missing
  • instance_move_config
  • ovn_ssl_config
  • certificate_description
  • disk_io_bus_virtio_blk
  • loki_config_instance
  • instance_create_start
  • clustering_evacuation_stop_options
  • boot_host_shutdown_action
  • agent_config_drive
  • network_state_ovn_lr
  • image_template_permissions
  • storage_bucket_backup
  • storage_lvm_cluster
  • shared_custom_block_volumes
  • auth_tls_jwt
  • oidc_claim
  • device_usb_serial
  • numa_cpu_balanced
  • image_restriction_nesting
  • network_integrations
  • instance_memory_swap_bytes
  • network_bridge_external_create
  • network_zones_all_projects
  • storage_zfs_vdev
  • container_migration_stateful
  • profiles_all_projects
  • instances_scriptlet_get_instances
  • instances_scriptlet_get_cluster_members
  • instances_scriptlet_get_project
  • network_acl_stateless
  • instance_state_started_at
  • networks_all_projects
  • network_acls_all_projects
  • storage_buckets_all_projects
  • resources_load
  • instance_access
  • project_access
  • projects_force_delete
  • resources_cpu_flags
  • disk_io_bus_cache_filesystem
  • instance_oci
  • clustering_groups_config
  • instances_lxcfs_per_instance
  • clustering_groups_vm_cpu_definition
  • disk_volume_subpath
  • projects_limits_disk_pool
  • network_ovn_isolated
    api_status: stable
    api_version: “1.0”
    auth: trusted
    public: false
    auth_methods:
  • tls
    auth_user_name: root
    auth_user_method: unix
    environment:
    addresses:
    • 192.168.0.23:8443
    • 10.54.248.1:8443
    • ‘[fd42:f3e8:95bc:4087::1]:8443’
    • 10.88.0.1:8443
    • 192.168.122.1:8443
      architectures:
    • x86_64
    • i686
      certificate: |
      -----BEGIN CERTIFICATE-----
      MIICDDCCAZKgAwIBAgIQKub42izFwM+Ycgy87nZ8DDAKBggqhkjOPQQDAzA2MRkw
      FwYDVQQKExBMaW51eCBDb250YWluZXJzMRkwFwYDVQQDDBByb290QGpnY2Nsb3Vk
      Y2gxMB4XDTI0MTIxNDIxNTcxMloXDTM0MTIxMjIxNTcxMlowNjEZMBcGA1UEChMQ
      TGludXggQ29udGFpbmVyczEZMBcGA1UEAwwQcm9vdEBqZ2NjbG91ZGNoMTB2MBAG
      ByqGSM49AgEGBSuBBAAiA2IABPJL1TvqaZBoBBrorIrYG8DtMgrcejPFfH+rivIY
      oL7FJFJSYTX92fHqz+TEB/Gb7FPLaFCDGIn8uHIEIwXghmONZIcQPmz8XUlbtZbc
      FAJI4PxUHsxHzUbabbyUhWuUgaNlMGMwDgYDVR0PAQH/BAQDAgWgMBMGA1UdJQQM
      MAoGCCsGAQUFBwMBMAwGA1UdEwEB/wQCMAAwLgYDVR0RBCcwJYILamdjY2xvdWRj
      aDGHBH8AAAGHEAAAAAAAAAAAAAAAAAAAAAEwCgYIKoZIzj0EAwMDaAAwZQIxAOfX
      RloMJ/iPxDKAkzlMqfB3CcxW0VmOwCnqt2fFU69mB8qwGjmrgCXFpi4Xn/gnCAIw
      Fphf5p9iyQ/TBWPWs0KFVBq+Rj2AVB6Jst2g4LU9PsTohliZzMDDU0wEkDEPPz+f
      -----END CERTIFICATE-----
      certificate_fingerprint: 149096ee6fb16825180cd3985a8be6bd8c1a30d0af3b9ce4f1869bee289c96d0
      driver: lxc
      driver_version: 4.0.12
      firewall: nftables
      kernel: Linux
      kernel_architecture: x86_64
      kernel_features:
      idmapped_mounts: “true”
      netnsid_getifaddrs: “true”
      seccomp_listener: “true”
      seccomp_listener_continue: “true”
      uevent_injection: “true”
      unpriv_binfmt: “false”
      unpriv_fscaps: “true”
      kernel_version: 5.14.0-503.16.1.el9_5.x86_64
      lxc_features:
      cgroup2: “true”
      core_scheduling: “true”
      devpts_fd: “true”
      idmapped_mounts_v2: “true”
      mount_injection_file: “true”
      network_gateway_device_route: “true”
      network_ipvlan: “true”
      network_l2proxy: “true”
      network_phys_macvlan_mtu: “true”
      network_veth_router: “true”
      pidfd: “true”
      seccomp_allow_deny_syntax: “true”
      seccomp_notify: “true”
      seccomp_proxy_send_notify_fd: “true”
      os_name: Rocky Linux
      os_version: “9.5”
      project: default
      server: incus
      server_clustered: false
      server_event_mode: full-mesh
      server_name: jgccloudch1
      server_pid: 1179
      server_version: “6.4”
      storage: dir
      storage_version: “1”
      storage_supported_drivers:
    • name: dir
      version: “1”
      remote: false
    • name: lvm
      version: 2.03.24(2)-RHEL9 (2024-05-16) / 1.02.198-RHEL9 (2024-05-16) / 4.48.0
      remote: false
    • name: lvmcluster
      remote: true
Need resolution , if incus server works for Rocky linux 9.5 or not any official gudie or tutorials for creating containers and VM inside bare metal(physical amd based machine)
incus storage set default size=100GiB or something like that should work fine.
As already mentioned on Github, this is a known issue.
Dear stgraber ,
Thanks for your fast response, storage size command which works perfectly with incus 6.0 in Debian 12 issue resolved.
As per the issue addressed in github ie Better support RHEL build of QEMU · Issue #1301 · lxc/incus · GitHub , based on that spice is not supported that is now clear and understood , but need to clarify that incus works in Rocky Linux 9.5
Exact problems faced as below
  1. under Rocky Linux 9.5 after everything installed properly faced problem after enabled incus as root user as
    #systemctl enable --now incus.service , which will not starts after reboot and any files to be created for enable under /etc/systemd/…
  2. Exact Problem Faced is: After symbolic linking done and qemu version check and commands work in host , libvirt installed completely but tried many bug fixings faced repeated error as below:
    Launching test-vm
Thanks
That’s exactly what’s covered in this issue I keep linking.
QEMU in RHEL derivatives, including Rocky Linux doesn’t have the required SPICE support.
Without SPICE supported, QEMU cannot run and you are therefore unable to create virtual machines.
Thanks for immediate Response.
