incus 6.14: After importing an iso volume:
incus storage volume import default debian-12.11.0-amd64-netinst.iso debian12-netinst --type=iso
Trying to delete it:
incus storage volume delete default custom/debian12-netinst
Gives the following error:
Error: Failed deleting subvolume "/var/lib/incus/storage-pools/default/custom/default_debian12-netinst.iso": Failed to run: btrfs subvolume delete /var/lib/incus/storage-pools/default/custom/default_debian12-netinst.iso: exit status 1 (ERROR: Not a Btrfs subvolume: Invalid argument)
root@dakara:~# incus storage create foo btrfs
Storage pool foo created
root@dakara:~# incus storage volume import foo /home/stgraber/Downloads/virtio-win-0.1.271.iso virtio --type=iso
root@dakara:~# incus storage volume delete foo virtio
Storage volume virtio deleted
root@dakara:~# incus storage delete foo
Storage pool foo deleted
I know we fixed a volume naming issue related to ISO recently so there’s a good chance that your issue was already fixed in the main branch and that will be in 6.15 next week.
Thanks. That sounds positive.
I’ll look out 6.15, test and get back to you.
Apologies for the delay in reply. Alas, I still have the same error.
$ incus storage volume delete default debian12-netinst
No files are in the directory shown in the error message although there is a root.img file in
/var/lib/incus/storage-pools/default/custom/default_iso-volume.iso
Supporting information below.
$ incus --version
6.20
$ incus storage volume list default
| TYPE | NAME | DESCRIPTION | CONTENT-TYPE | USED BY |
| custom | debian12-netinst | | iso | 0 |
$ incus storage volume show default custom/debian12-netinst
type: custom
used_by: []
content_type: iso
project: default
created_at: 2025-07-24T16:16:06.506036644+02:00
# ls -lR /var/lib/incus/storage-pools/default/custom/
/var/lib/incus/storage-pools/default/custom/:
total 0
drwx------ 1 root root 0 Jul 24 16:36 default_debian12-netinst.iso
drwx--x--x 1 root root 16 Jul 24 16:16 default_iso-volume.iso
total 0
/var/lib/incus/storage-pools/default/custom/default_iso-volume.iso:
total 686080
-rw------- 1 root root 702545920 Jul 24 16:16 root.img
The problem persists also with incus v6.22.
What distribution and kernel is that running on?
Also, can you show the incus storage show default output for good measure?
cat /proc/version
Linux version 6.1.0-44-amd64 (debian-kernel@lists.debian.org) (gcc-12 (Debian 12.2.0-14+deb12u1) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1 SMP PREEMPT_DYNAMIC Debian 6.1.164-1 (2026-03-09)
source: /var/lib/incus/disks/default.img
driver: btrfs
- /1.0/instances/deb01
- /1.0/instances/u1
- /1.0/instances/win11dev
- /1.0/profiles/default
- /1.0/storage-pools/default/volumes/custom/debian12-netinst
status: Created
locations:
- none
Thanks @stgraber
