incus exec mycontainer bash
shows nothing, not even throws error.
What could go wrong ?
- It works on my other containers
- It used to work
Hi!
When you run incus exec mycontainer bash
, then Incus will spawn (run) the process bash
in that container. Not /bin/bash
, nor /usr/bin/bash
, but bash
. This means that somehow the container should figure out if there is a bash
and where it is.
Some images like Alpine do not come with bash
and in that case you do get a suitable error message.
$ incus launch images:alpine/edge mycontainer
Launching mycontainer
$ incus exec mycontainer bash
Error: Command not found
In the case of Alpine, you would exec the sh
executable (it is in /bin/sh
$ incus exec mycontainer sh
~ # exit
$ incus shell mycontainer
mycontainer:~# exit
What’s this incus shell
command? It’s an alias that does su -l
for you (login shell). Note that you need to add --
when the command in the shell happens to have parameters. --
means that the shell on the host should stop processing parameters.
$ incus exec mycontainer su -l
Error: unknown shorthand flag: 'l' in -l
$ incus exec mycontainer -- su -l
mycontainer:~# exit
And now let’s answer your question. If a command that is incus exec
-ed into an instance fails, then that command was indeed found in the container, but failed to produce any output. Somehow it crashed or something. In such a case, you try with other commands. You aim is to get any output from a command, as in incus exec mycontainer -- /bin/cat /etc/issue
. If you do not get any output at all, then either the instance is messed up (and requires rebuilding), or something rare is happening and it’s specific to your system. Create a new container and check in there.
I should have say it before: no command is working on this container, which is running (it’s a jupyter notebook server I can reach by http).
Thanks for this instructive answer btw.
You can also get a shell through incus console
. Does that work for you?
incus console mycontainer
didn’t show a prompt up.incus console mycontainer --show-log
showed last lines of what I guess is some standard error. Enough to get that token I was looking for to log in in jupyter.Still, I can’t log into that container.
just use :
incus exec mycontainer – login -p -f root
work on alpine ubuntu archlinux fedora
