Okay, found default options. All I was missing was the --group incus-admin option.
Output on crash:
panic: runtime error: invalid memory address or nil pointer dereference
[signal SIGSEGV: segmentation violation code=0x1 addr=0x8 pc=0x561f15fc06b9]
goroutine 704 [running]:
github.com/lxc/incus/v6/internal/server/instance/drivers.(*lxc).findIdmap(0xc000badb00)
/var/tmp/portage/app-containers/incus-6.10.1/work/incus-6.10.1/internal/server/instance/drivers/driver_lxc.go:491 +0x439
github.com/lxc/incus/v6/internal/server/instance/drivers.lxcCreate(_, {0x13, {0xc00189e4bc, 0x4}, 0x0, 0x0, {0xc00189e4b0, 0x7}, {0x0, 0x0}, ...}, ...)
/var/tmp/portage/app-containers/incus-6.10.1/work/incus-6.10.1/internal/server/instance/drivers/driver_lxc.go:272 +0x1045
github.com/lxc/incus/v6/internal/server/instance/drivers.create(_, {0x13, {0xc00189e4bc, 0x4}, 0x0, 0x0, {0xc00189e4b0, 0x7}, {0x0, 0x0}, ...}, ...)
/var/tmp/portage/app-containers/incus-6.10.1/work/incus-6.10.1/internal/server/instance/drivers/load.go:146 +0x16e
github.com/lxc/incus/v6/internal/server/instance.CreateInternal(_, {0x13, {0xc00189e4bc, 0x4}, 0x0, 0x0, {0xc00189e4b0, 0x7}, {0x0, 0x0}, ...}, ...)
/var/tmp/portage/app-containers/incus-6.10.1/work/incus-6.10.1/internal/server/instance/instance_utils.go:1023 +0x1435
main.instanceCreateFromImage({_, _}, _, _, _, {0x0, {0x0, 0x0}, 0x0, 0x0, ...}, ...)
/var/tmp/portage/app-containers/incus-6.10.1/work/incus-6.10.1/cmd/incusd/instance.go:161 +0x297
main.createFromImage.func1(0xc00111a280)
/var/tmp/portage/app-containers/incus-6.10.1/work/incus-6.10.1/cmd/incusd/instances_post.go:139 +0x585
github.com/lxc/incus/v6/internal/server/operations.(*Operation).Start.func1(0xc00111a280)
/var/tmp/portage/app-containers/incus-6.10.1/work/incus-6.10.1/internal/server/operations/operations.go:286 +0x26
created by github.com/lxc/incus/v6/internal/server/operations.(*Operation).Start in goroutine 638
/var/tmp/portage/app-containers/incus-6.10.1/work/incus-6.10.1/internal/server/operations/operations.go:285 +0x105
I also see this output running incusd (pre-crash):
ERROR [2025-03-12T21:37:16-07:00] Unable to parse system idmap err="No map found for user"
WARNING[2025-03-12T21:37:16-07:00] AppArmor support has been disabled because of lack of kernel support
WARNING[2025-03-12T21:37:16-07:00] - AppArmor support has been disabled, Disabled because of lack of kernel support
WARNING[2025-03-12T21:37:16-07:00] - Couldn't find the CGroup memory swap accounting, swap limits will be ignored
I’m not using AppArmor, but the idmap error might be related.
