Incus launch errors with "Error: Failed instance creation: Unsupported protocol: oci"
Hi, I’m attempting to run incus launch docker:jellyfin/jellyfin on a server running Incus 6.7 but I receive the error from the title. I have the required packages on my server for OCI.
Any ideas? Thanks!
Editing to add context to the solution: I had updated the client version but the server itself needed to be updated. I didn’t realize that there was a difference between incus --version, which shows the version of the client tool itself, and incus version, which shows both the client and server versions.
Please post output from
incus remote list
Here’s the output. docker was added via incus remote add docker https://docker.io --protocol=oci
|      NAME       |                URL                 |   PROTOCOL    |  AUTH TYPE  | PUBLIC | STATIC | GLOBAL |
| docker          | https://docker.io                  | oci           | none        | YES    | NO     | NO     |
| images          | https://images.linuxcontainers.org | simplestreams | none        | YES    | NO     | NO     |
| local (current) | unix://                            | incus         | file access | NO     | YES    | NO     |
Try removing and re-adding:
incus remote remove docker
No dice.
# incus remote add docker https://docker.io --protocol=oci
# incus launch docker:jellyfin/jellyfin
Launching the instance
# incus remote list
Are you running the commands as root? If so, try running the commands as a non-root user in the incus-admin group.
Yes, I was running as root. Running it all again as a non-root user in that group results in the same outcome:
[eric@homelab01:~]$ groups
users wheel incus-admin
[eric@homelab01:~]$ incus remote remove docker
To start your first container, try: incus launch images:ubuntu/22.04
Or for a virtual machine: incus launch images:ubuntu/22.04 --vm
Error: Remote docker doesn't exist
[eric@homelab01:~]$ incus remote list
[eric@homelab01:~]$ incus remote add docker https://docker.io --protocol=oci
[eric@homelab01:~]$ incus launch docker:jellyfin/jellyfin
Post the result of
incus version
$ incus --version
6.7
Please run the command without the hyphens.
Ah, what a fun UX choice:
$ incus version
Client version: 6.7
Server version: 6.0.2
Looks like my server is out of date
incus --version shows you the version of just the tool you’re using, incus version is instead an actual command we implemented which not only shows the version of the tool but also of the server you’re talking to.
And indeed Incus 6.0.2 does not support OCI, so that’d be the problem here.
Hey everyone,
Just sharing a few notes in case others land on this thread and run into the same issue I did:
  • Support for OCI (Open Container Initiative) images was introduced in Incus 6.3 (July 2024), so make sure to check your installed version using the incus version command.
  • Also, ensure you’re using the stable repository for installation and updates, since the LTS repository only covers the 6.0.x series.
Hope this helps!
