ckruijntjens
(Chris Kruijntjens)
February 2, 2024, 10:49am
1
Hi All,
I migrated from lxd to incus. everything went smooth. However i can not seem to launch a new container.
any help would be appreciated.
Blockquote
root@esx:~# incus launch images:debian/12/cloud controller-new
Launching controller-new
Error: Failed instance creation: Failed getting remote image info: Failed getting image: The requested image couldn’t be found
simos
(Simos Xenitellis)
February 2, 2024, 11:30am
3
If you run the following, it should give you the full list of available images that are currently available, along with their hash/fingerprint.
incus image list images:
If something goes wrong, you can save the output of that command, in order to be able to diagnose later.
Also, you can run the following to get information on a specific image,
$ incus image info images:debian/12/cloud
Fingerprint: bfa74da4e61b55cc620a5d0f897d3ce95cbb30e39773777bcd0cf9159d91c0cb
Type: container
Public: yes
Timestamps:
Created: 2024/02/02 00:00 UTC
Uploaded: 2024/02/02 00:00 UTC
Expires: never
Last used: 0001/01/01 00:00 UTC
Properties:
architecture: amd64
variant: cloud
type: squashfs
os: Debian
release: bookworm
description: Debian bookworm amd64 (20240202_05:24)
serial: 20240202_05:24
Aliases:
- debian/bookworm/cloud
- debian/bookworm/cloud/amd64
- debian/12/cloud
- debian/12/cloud/amd64
Cached: no
Auto update: disabled
Profiles: []
I do not know the mechanics of image creation. Perhaps you tried to launch an image at the exact moment that it was being updated?
stgraber
(Stéphane Graber)
February 2, 2024, 2:27pm
4
Incus has a built-in cache for the image list, it’s quite possible that your system somehow accessed bad data which was kept in cache for a few minutes, then on re-try things worked properly.
