kiv
July 19, 2024, 7:04am
1
Hi all,
Using incus-migrate
, would a privileged LXC container be migrated to an unprivileged incus container ?
Edit : self answer : security.privileged
option is false
by default, see below.
Sorry for this dumb question but I didn’t find a clear answer in the doc or forum.
After a first test I noticed that :
ls /proc
inside the incus container prints nobody
owner
adding a path on the host without shift=true
gives ownership to nobody
inside the container
but from host : sudo ls -n /var/lib/incus/containers/my-container/rootfs
shows 0:0
as owner. shouldn’t it show 100000:100000
or something ?
kiv
July 19, 2024, 8:56am
2
Well, I did my homework :
incus config get my-migrated-container security.privileged
gives an empty output, as with a fresh “image launched” container.
security.privileged
option default value is false
, so I guess my migrated containers are unprivileged.
Just to be (less un-) sure :
incus stop my-migrated-container
incus config set my-migrated-container security.privileged=false
incus start my-migrated-container
It seems that nothing change in the container, the services still work flawlessly.
Out of subject :
Again, sorry for my dumb questions. I manage a dedicated server for family use, I have not much time to maintain it but I do my best.
I started about ten years ago with LXC, and did not updated myself about LXC usage and LXD afterwards, I am learning. Not sure this forum is a place for guys like me, hopefully my posts may help some people.
simos
(Simos Xenitellis)
July 19, 2024, 10:17am
3
The security.privileged=false
is a flag that you can assign to a container.
When you change the value of this flag to a container, you need to then restart the container so that it takes effect on that container.
In that respect, you can switch on or off, then restart.
Normally, you do not need privileged containers. In the majority of cases you can use unprivileged containers.
kiv
July 19, 2024, 11:18am
4
Thank you for the details.
That’s what I did : I expected more difficulties, but the only trick I needed was to add shift=true
to my host mounts.
The more I learn about incus, the more I love it! versatile, robust, easy to use… (once you understand the logic behind it)
