Incus migrate with qcow2 - unsupported protocol scheme
Seeing error when using the incus-migrate wizard. Following instructions similar to Home Assistant OS in Incus 101 - ScottiByte's Discussion Forum
unsupported protocol scheme “”
current directory has file: haos_ova-17.1.qcow2
$ wget https://github.com/home-assistant/operating-system/releases/download/17.1/haos_ova-17.1.qcow2.xz
$ unxz haos_ova-17.1.qcow2.xz
$ sudo incus-migrate
The local Incus server is the target [default=yes]:
What would you like to create?
Container
Virtual Machine
Virtual Machine (from .ova)
Custom Volume
Please enter the number of your choice: 2
Name of the new instance: haos
Please provide the path or URL to a disk, partition, or qcow2/raw/vmdk image file: /home/gurpal/haos_ova-17.1.qcow2
Error: Get “/home/gurpal/haos_ova-17.1.qcow2”: unsupported protocol scheme “”
relative path, absolute path - neither work. file:// doesn’t work either
$ uname -a
Linux appserver2 6.1.0-42-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.159-1 (2025-12-30) x86_64 GNU/Linux
$ incus version
Client version: 6.21
Server version: 6.21
$ unxz --version
xz (XZ Utils) 5.4.1
liblzma 5.4.1
Oops, I must have caused that regression when adding URL support…
You should be able to download the static incus-migrate from the 6.21 release on Github to avoid that problem for now.
thx, i did manage a workaround manually for now via ‘image import’
