Incus move fails on XFS dir and Apparmor
I’m trying to simply move container from one directory storage to another (both on same server, both XFS filesystem). There are already running containers on “new” storage.
I run: incus move vm1 vm1 -s storage2
Rsync copies everything but at the end fails with: rsync_xal_set: lsetxattr("/var/lib/incus/storage-pools/storage2/containers/move-of-11695087510962713635/rootfs/var/log/journal","trusted.SGI_ACL_DEFAULT") failed: Operation not permitted (1)
there is log in dmesg:
audit: type=1400 audit(1748525443.986:1650): apparmor="DENIED" operation="capable" class="cap" profile="incus_rsync-e05184bd-5877-4ac1-913e-9e36d5d23fd9" pid=1035284 comm="rsync" capability=21  capname="sys_admin"
incus --version: 6.12
system: Ubuntu 24.04
I tried to find solution but with no success. Any idea how to solve this issue?
Thank you,
Pavel
I have got the same problem, also with XFS on both hosts but on Debian 12 with Incus 6.0.4.
I did some tests and adding the sys_admin capability to internal/server/apparmor/rsync.go allows the XFS trusted.SGI_ACL_DEFAULT attribute to be set by rsync. @stgraber would this be a valid way to fix this problem?
It’s certainly not ideal because that’s not the kind of capability we like giving a sub-process, but in this case if we want to conserve the capability, that’s basically the only way to do it.
