Incus move zfs backend snapshot gone
Hi All,
When i move a container from one incus server to another all my zfs snapshots of that machine are gone?
I use syncoid/sanoid.
Why is incus not moving the snapshots together with the container?
This sounds interesting. Please help me understand:
Are you using incus move to transfer instances between hosts, or do you use syncoid/sanoid to transfer the snapshots? In case of the latter, it would depend on your synchronisation strategy what is transferred.
How are you transferring the Incus metadata of an instance, that is what does your restore procedure look like? Did you play with incus move --instance-only in combination with your syncoid/sanoid setup?
I have read that Incus itself on its own will always replicate the last snapshot first, also when using --refresh*.
This is potentially to safe transfer costs, only looking to move forward.
With “other instances” here, could “earlier snapshots” have been meant as well?
