daveb
(David Burke)
December 30, 2023, 12:19am
1
Hi, I’m keen to use Incus and the only thing stopping me at the moment is the ability to run a VM using multiple monitors. I’m using KVM at the moment and virt-viewer gives me 2 displays by setting the video qxl heads=“2”.
<video>
<model type="qxl" ram="8192" vram="65536" vgamem="32768" heads="2" primary="yes"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x0"/>
</video>
I notice that Incus also uses virt-viewer so I was hoping there is somewhere I can set the number of heads. Thanks
stgraber
(Stéphane Graber)
December 30, 2023, 12:32am
2
Those kinds of less common QEMU configs can often be done through raw.qemu
or raw.qemu.conf
, in this case:
stgraber@castiana:~$ incus config show v1
image.architecture: amd64
image.description: Ubuntu jammy amd64 (20231229_07:42)
image.os: Ubuntu
image.release: jammy
image.serial: "20231229_07:42"
image.type: disk-kvm.img
image.variant: default
raw.qemu.conf: |-
[device "qemu_gpu"]
max_outputs = 4
volatile.base_image: d2ca6c67d52667e2417482de0053e45958503754545634810780c536eeff0f38
volatile.cloud-init.instance-id: 77052993-dde0-4588-a187-043422e1390c
volatile.eth0.host_name: tap213eb341
volatile.eth0.hwaddr: 00:16:3e:fb:ae:6d
volatile.uuid: c05cb6af-2d61-4529-9a8d-3b1a2546fd2c
volatile.uuid.generation: c05cb6af-2d61-4529-9a8d-3b1a2546fd2c
volatile.vsock_id: "2765354766"
devices: {}
stgraber
(Stéphane Graber)
3
Above example uses 4 different heads, so you’d want to set the option to 2 instead in your case.
daveb
(David Burke)
December 30, 2023, 2:55am
4
Thanks so much Stéphane! I was hoping that there would be a raw qemu solution
