I’d like to use Incus on laptop with Ubuntu and Wi-Fi as the only interface to host few VMs. VMs should be able to access Internet. I should be able to access VMs from the host via ssh. What’s recommended networking setup for this use-case?
Seems like bridge will fail due to Wi-Fi driver’s limitations. The macvlan will fail to obtain IP from Wi-Fi Access Point via DHCP due to macvlan limitations. Should I use some kind of NAT? Static addresses?
I use OpenWRT as AP which has some OVN packages so perhaps OVN is also an option?
If you have made similar setup working - would love to read about it: seems like most of the folks use Ethernet so information is surprisingly scarce.
I have such a configuration on a raspberry pi. It works OK. I am using managed bridge without nat. Connections to vms and containers work over routing. I announce incus bridge network via builtin bgp, tho static routing would also work perfectly fine.
