Hey all, trying to get started using app containers with Incus. I’ve managed to get them launched without anything extra, e.g. storage but now I’m looking to keep persistent data and allow me to update the containers in the future so I can run applications like VaultWarden without worrying about losing my passwords on upgrade. I’ve been testing this with the inductive automation ignition container running latest 8.1.47. Here are my configs:
ignition0 container:
gage@dl380g10:~$ incus config show ignition0 --expanded
environment.HOME: /home/ignition
environment.IGNITION_INSTALL_LOCATION: /usr/local/bin/ignition
environment.LANG: en_US.UTF-8
environment.LANGUAGE: en_US
environment.LC_ALL: en_US.UTF-8
environment.PASS_THROUGH: both
environment.PATH: /usr/local/bin/ignition/lib/runtime/jre/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
environment.TERM: xterm
image.architecture: x86_64
image.description: docker.io/inductiveautomation/ignition (OCI)
image.id: inductiveautomation/ignition
image.type: oci
limits.cpu: "4"
limits.memory: 4GiB
security.privileged: "false"
volatile.base_image: fa81e8cac62d743bfa42f61973abd91cb1b255b2aeda6b128f0801d37fd932f3
volatile.cloud-init.instance-id: 9cd000cb-5c20-4cbb-809d-6966e2950274
volatile.container.oci: "true"
volatile.eth30.hwaddr: 00:16:3e:ac:48:84
volatile.eth30.name: eth0
volatile.idmap.base: "0"
volatile.uuid: e5c6fd9e-b380-403f-9aaa-bed220def196
volatile.uuid.generation: e5c6fd9e-b380-403f-9aaa-bed220def196
data:
path: /usr/local/bin/ignition/data
pool: default
source: ignition0-data
eth30:
mtu: "1500"
nictype: bridged
parent: br10
vlan: "30"
pool: default
- defaultContainer
- vlan30
ignition0-data
security.shifted: "true"
volatile.idmap.last: '[]'
volatile.idmap.next: '[]'
type: custom
- /1.0/instances/ignition0
content_type: filesystem
project: default
created_at: 2025-03-27T14:42:13.381621056Z
I’ve passed security.shifted true in the volume config, but it appears to not have any effect on the errors that I receive.
incus info ignition0 --show-log
gage@dl380g10:~$ incus info ignition0 --show-log
Description:
Status: STOPPED
Type: container (application)
Created: 2025/03/27 14:41 UTC
Last Used: 2025/03/27 15:54 UTC
Log:
lxc ignition0 20250327155416.741 WARN cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:747 - File exists - Creating the final cgroup 10(lxc.monitor.ignition0) failed
lxc ignition0 20250327155416.741 WARN cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_create:807 - File exists - Failed to create monitor cgroup 10(lxc.monitor.ignition0)
lxc ignition0 20250327155416.741 WARN cgfsng - ../src/lxc/cgroups/cgfsng.c:__cgroup_tree_create:747 - File exists - Creating the final cgroup 10(lxc.monitor.ignition0-1) failed
lxc ignition0 20250327155416.741 WARN cgfsng - ../src/lxc/cgroups/cgfsng.c:cgroup_tree_create:807 - File exists - Failed to create monitor cgroup 10(lxc.monitor.ignition0-1)
lxc ignition0 20250327155417.167 ERROR af_unix - ../src/lxc/af_unix.c:lxc_abstract_unix_recv_fds_iov:218 - Connection reset by peer - Failed to receive response
lxc ignition0 20250327155417.167 ERROR commands - ../src/lxc/commands.c:lxc_cmd_rsp_recv_fds:128 - Failed to receive file descriptors for command "get_state"
I think it’s more the errors with cgroups. I’ve tried setting it as a privileged container but that didn’t help either.
I’ll happily provide information that is requested.
Thank you,
Gage
