Good morning,
I am trying to replicate with OpenVSwitch with what this user is doing here.
I am running into the issue below, if anyone could point me in a direction that I should look I would greatly appreciate it. Thank you.
Issue:
Creating a vSwitch, then creating a profile with vlan tag in the profile. However, when starting the VM I get the following error
Launching test
Error: Failed to start device "eth0": 1 ovsdb operations failed
Tagged Profile
config: {}
nictype: bridged
parent: br0
vlan: "5"
pool: dev-pool
- /1.0/instances/test
ovs-vsctl show
ab0cde48-d9bc-4c46-8856-3b379384d587
Bridge br0
Port enp42s0
Interface enp42s0
Port br0
Interface br0
type: internal
ovs_version: "3.2.2"
OpenVSwitch Logs
2024-05-26T14:34:03.768Z|00072|bridge|INFO|bridge br0: added interface tap24685326 on port 18
2024-05-26T14:34:03.772Z|00073|bridge|INFO|bridge br0: deleted interface tap24685326 on port 18
