I have a question. I now have opnsense as a virtual machine inside incus. (bridged nic adapters) now i want create some vlans. is it enough to create vlans inside opensens and my switches to make it work? or do i need to do some configuration on incus to?
Can you show how the bridge was defined on the host system?
Linux can do VLAN filtering which could explain what you’re seeing, but that’s generally not done by default for regular bridges created by the usual distro-level tools.
When i add a vlan to my host true systemd and add a vlan in my opensense i can ping al vlan ip adresses ij the hosts. Now i am configuring a vlan in my virtual unify controller. In the software. Do i need to add a vlan nic to the controller? Pr should ot work without it? What i am trying to do is setup a extra wifi ssid in a different vlan. However i see the extra wifi but i never get an ip adres in this vlan from my opense box. Dhcp is enable for this vlan.
