Incus OS Secrets Management
I plan to use use Incus OS in the future. I am using a current version of Incus today. I want to be able to reason about container secrets. Here are my thoughts:
Does anyone actively manage secrets related to the following? If so, will you offer a quick/bulleted description of your process? A quick dive into the Incus docs did not uncover anything obvious.
In Incus today:
  • I can write/execute a host script to temporarily add a secret is a root-only location in a container/guest.
  • I can then do things in the container that require secrets
  • Something somewhere will remove the secret (host/guest/etc…)
In Incus OS tomorrow:
  • I will not have the above ability
  • I will need an api call to allow me to inject a collection of secrets to a known location.
I ignorantly believe the following:
  • age would be the preferred encryption tool (either age or ed25519) for simple scenarios
  • openbao would be the better solution for more advanced scenarios
Note: I use nixos to deploy production resources. This is not really relevant to the topic; however, I wanted to mention just in case.
Thank you for your time and attention!
Chuck
Can’t you use incus file push to directly push a file into the container, then read it from there and delete it either from inside the container or through incus file delete?
Thank you! That makes sense! I may have been over thinking it a bit.
Thinking out loud… I still have to think about the services devops coordination tasks:
  • What tool to deliver and delete the secrets (github actions for example)
  • I currently use the incus host to perform management ops.
  • Is it possible to have a guest container have management capabilities over the host?
    • I am asking because I am thinking about incus os
    • This scenario creates a self contained system
Chuck
