Hi!
With incus-user, I am trying to attach a custom volume to a profile, but I am running into a permission issue.
~ $ incus storage volume list default
| TYPE | NAME | DESCRIPTION | CONTENT-TYPE | USED BY |
| custom | binpkgs | | filesystem | 0 |
~ $ incus profile device add gentoo binpkgs disk pool=default source=binpkgs path=/var/cache/binpkgs
Error: Failed checking if profile update allowed: Invalid device "binpkgs" on profile "gentoo" of project "user-1000": Disk source path "binpkgs" not allowed
I’ve tried to add the source into restricted.devices.disk.paths
for my project, but this only seems to take in absolute paths.
~ # incus project get user-1000 restricted.devices.disk.paths
/home/matt,/other/paths
~ # incus project set user-1000 restricted.devices.disk.paths=/home/matt,/other/paths,binpkgs
Error: Invalid project configuration key "restricted.devices.disk.paths" value: Item "binpkgs": Must be absolute file path
In the docs for project configuration, I can’t see any specific syntax for mentioning a managed custom volume instead of a filesystem path. (Project configuration - Incus documentation)
Setting restricted.devices.disk.paths
to an empty string works in that I can now attach my volume, but this is not ideal as now any path is allowed. What is the correct way to solve this?
