I started the Ubuntu mantic amd64 desktop VM on the incus server. But last night a power cut caused the incus server to shut down and now after restarting the incus server I found that the VM status is wrong.
incus restart vm
Error: The instance cannot be cleanly shutdown as in Error status
incus info vm --show-log
Status: ERROR
Type: virtual-machine
PID: 34193
Created: 2024/03/14 14:01 CST
Last Used: 2024/03/18 16:03 CST
Resources:
Processes: 0
Disk usage:
root: 701.28MiB
Log:
incus rebuild vm-image vm
Error: Failed rebuilding instance from image: Error deleting storage volume: Failed to run: zfs destroy -r default/virtual-machines/vm.block: exit status 1 (cannot destroy ‘default/virtual-machines/vm.block’: dataset is busy)
incus console --show-log vm
Error: Instance is not container type
