Hi all,
following the hint provided by @stgraber closing #475 issue on github I have finally started a vm in Voidlinux x86 platform.
I can’t do the same on a Raspberry PI4.
Since Voidlinux doesn’t have the ovmf package for aarch64 platform I tried Fedora
To setup incus I followed instructions found at ‘Start your first virtual machine’ here, but i got the same QEMU error “Failed instance creation: Failed creating instance record: Instance type “virtual-machine” is not supported on this server: QEMU failed to run feature checks” even skipping the, to me unknown, cloud-init section.
Libvirtd.service is active (is that enough to run vm on Fedora??) and it looks like qemu is working.
@stgraber suggested to look into journalctl (no clues at all), and incusd log (no incusd log at all), so I ran out of options.
May anyone who started succesfully vm through incus on a Raspberry PI4 point me in the right direction?
My kind regards
P.S. Linux distribution doesn’t matter, I want only a working one
Simulating a VM detection failure on Fedora 39 here:
[root@f39 ~]# rm /dev/kvm
[root@f39 ~]# systemctl restart incus
[root@f39 ~]# journalctl -u incus.
Mar 12 23:42:54 f39 systemd[1]: Starting incus.service - Incus - Daemon...
Mar 12 23:42:54 f39 incusd[1130]: time="2024-03-12T23:42:54Z" level=error msg="Unable to parse system idmap" err="No map found for user"
Mar 12 23:42:54 f39 incusd[1130]: time="2024-03-12T23:42:54Z" level=warning msg="AppArmor support has been disabled because of lack of kernel support"
Mar 12 23:42:54 f39 incusd[1130]: time="2024-03-12T23:42:54Z" level=warning msg=" - AppArmor support has been disabled, Disabled because of lack of kernel support"
Mar 12 23:42:54 f39 incusd[1130]: time="2024-03-12T23:42:54Z" level=warning msg="Instance type not operational" driver=qemu err="KVM support is missing (no /dev/kvm)" type=virtual-machine
Mar 12 23:42:55 f39 systemd[1]: Started incus.service - Incus - Daemon.
[root@f39 ~]#
This shows the expected error:
