Incus / zfs - mountpoint=legacy - snapshots get not mounted
Hello everyone,
I’m trying to setup shadow_copy2 in my samba server for the “earlier versions” feature in my shares and i like to use my snapshots for that. With a workaround (2nd drive with a copy of the snapshots, mountet in a directory) it’s working. But It’s not working with the “incus datasets”…
usually, when a zfs dataset is mounted, it is possible to access the snapshots via /mountpoint/.zfs/snapshot/snapshotname. Afaik, the snapshot gets mounted as soon as you access the snapshot directory.
When you let incus handle your zfs datasets, the mountpoint for the datasets is set to legacy and that seems to prevent the automount of the snapshots:
Does somebody know, if there is a way, to get these snapshots mouted when the mountpoint is legacy? Or, can i simply set the mountpoint of this dataset to the stadard incus directory? Which impact does that maybe have?
I’m looking forward to your feedback.
Best regards
Jan
Also interested in this. I have large number of sub-datasets with each their snapshots, and it seems it doesn’t auto-mount them (as would have been the case with zfs inherit).
Also tried this from inside the container:
# zfs inherit -r mountpoint \
    backup1/incus/custom/projectname_users
cannot inherit mountpoint for 'backup1/incus/custom/projectname_users': dataset is used in a non-global zone
cannot inherit mountpoint for 'backup1/incus/custom/projectname_users/testuser': dataset is used in a non-global zone
I’ve also been checking this, and tried the following from within a container on an Ubuntu 22.04 server.
First create a snapshot:
$ sudo zfs snapshot lake/incus/custom/default_nextcloud@2025-10-01_0017_restic
And then manually mount it:
$ sudo mkdir /mnt/nextcloud-dataset-snapshot
$ sudo mount -t zfs lake/incus/custom/default_nextcloud@2025-10-17_0017_restic /mnt/nextcloud-dataset-snapshot
filesystem 'lake/incus/custom/default_nextcloud@2025-10-17_0017_restic' cannot be mounted, unable to open the dataset
Do you have any tips @stgraber ?
P.D.
This and this seem related.
Thanks!
