That lexar usb stick is actually is quite old and slow. Turns out it booted to a state where IncusOS expected a seed and would not operate. I put the exact same image on a much newer sandisk (like the one I used for the ubuntu live), and that actually does work just fine. Booted and operational.
I was having issues booting from the ISO provided by the IncusOS image downloader, which I had written to a USB stick to install on a NUC. I tried multiple different USB sticks but none worked. I gave up and installed Proxmox VE.
Today I tried again but chose the USB version instead of the ISO, and it worked and I was able to successfully install IncusOS, replacing Proxmox.
Yeah, if you’re going to be booting from a USB drive, you need to download the image that’s listed for use with USB drives.
There are some systems out there that are extra smart and detect an ISO (2048 bytes alignment) having been written to a USB stick and will handle conversion on the fly for you, but that’s somewhat rare.
Ah, I see the instructions for installation on a physical system mentions USB and a raw image but the download side just mentions USB, not raw. I’ll send a small documentation tweak to make it clearer to use the USB image instead of that “raw” which doesn’t appear anywhere.
On a tangentially related note, is there any possibility of reducing the size of the image so that it could fit on to say, a 2 GB USB stick? I recall from watching your videos that there is only 500 MB of data in the image, and the rest is padding.
The data size of the downloaded image is indeed around 550MB, but once the target system boots, it will download another 200MB or so for Incus, then double the whole thing for the A/B storage and that’s before it allocates any space to store its own data.
The actual minimum target disk size is around 35GB though we usually say 50GB of space is needed on the target.
Partitioning scheme - IncusOS documentation has more details on the partition table
**RESOLVED BY BOOTING FROM SATA ATTACHED SSD (USB FAILED).
STEPS THAT FIXED THIS:
- downloaded (and configured) USB image
- attached old (small) SATA drive to system, directly on SATA bus (not USB)!
- boot into std. linux, “dd” downloaded image to disk (find device using i.e. “lsblk”, doublecheck this is the right device, then tripplecheck, then “dd” image to disk something like “sudo dd if=IncusOS_202511100256.img of=/dev/sda bs=1m”, “sync”, reboot)
- properly enable secure boot, boot from SATA
- IncusOS installs
- waited some time to give system time to sync, then rebooted using Ctrl-Alt-Del (its not USB so can’t really remove - well, maybe, but didn’t dare)
——– ORIGINAL PROBLEM (and System) DESCRIPTION ——-**
I seem to be having same/similar issue on one of my systems: System boots into “IncusOS is starting…” screen, then hits timeout after about 10min (“You are in emergency mode…”) EDIT: changed this from original post - tweaking BIOS brought me to this, probably had secureboot(?) or something not configured correctly
Gigabyte GA-B150M-D3H (B150 chipset, so not very new, flashed with latest BIOS though) with INTEL i5-6400T, 0.5TB NVMe (970 EVO Plus), 16GB RAM
- a dual INTEL GbE plugged (I’m however using the onboard)
- hardware TPM in 20pin header (seems to be working, BIOS shows new config options for Trusted Computing, linux shows TPM dmesgs and TPM device, but did not test further)
What I did:
1.) created installer (initially selected ISO, but did not boot, then changed for USB which seemed to boot)
2.) initially booted BIOS in setup mode, booted, IncosOS printed count down and seemed to install keys
=> seems this worked, I do see e.g. /sys/firmware/efi/efivars/KEK-8be4df61-93ca-11d2-aa0d-00e098032b8c in linux which is “Incus OS - Secure Boot KEK R110U”
3.) reboot, system booted again
4.) system boots into blank screen with “IncusOS is starting…” message, then timeout after about 10min with “You are in emergency mode…” message (EDIT)
What I tried:
- removed all other drives besides NVMe (and boot USB)
- waited for 20 minutes
- trolled through BIOS settings a couple of times attempting to change some of the storage related settings
- removed the dual INTEL GbE NIC (so literarely only mainboard+CPU+RAM+NVMe)
- later found my BIOS also supports firmware TPM, so tried this as well (might have improved behaviour - now hitting timeout)
Note: I did verify my CPU supports x86-64-v3.
lsmod
$ lsmod
Module Size Used by
xt_tcpudp 16384 0
xt_conntrack 12288 1
nft_chain_nat 12288 5
xfrm_user 69632 1
xfrm_algo 16384 1 xfrm_user
xt_addrtype 12288 2
nft_compat 24576 9
overlay 245760 1
vhost_net 36864 0
nf_log_syslog 24576 2
nft_log 12288 1
nft_ct 28672 1
nft_fib_inet 12288 1
nft_fib_ipv4 12288 1 nft_fib_inet
nft_fib_ipv6 12288 1 nft_fib_inet
nft_fib 12288 3 nft_fib_ipv6,nft_fib_ipv4,nft_fib_inet
nf_tables 397312 174 nft_ct,nft_compat,nft_log,nft_fib_ipv6,nft_fib_ipv4,nft_chain_nat,nft_fib,nft_fib_inet
snd_hda_codec_hdmi 98304 1
snd_hda_codec_realtek 225280 1
snd_hda_codec_generic 118784 1 snd_hda_codec_realtek
snd_hda_scodec_component 20480 1 snd_hda_codec_realtek
intel_rapl_msr 20480 0
snd_soc_avs 245760 0
snd_soc_hda_codec 28672 1 snd_soc_avs
i915 4657152 5
snd_hda_ext_core 36864 2 snd_soc_avs,snd_soc_hda_codec
sch_fq_codel 24576 2
snd_soc_core 466944 2 snd_soc_avs,snd_soc_hda_codec
ppdev 24576 0
ee1004 16384 0
snd_compress 36864 2 snd_soc_avs,snd_soc_core
iTCO_wdt 16384 0
intel_rapl_common 53248 1 intel_rapl_msr
intel_pmc_bxt 16384 1 iTCO_wdt
tls 159744 11
ac97_bus 12288 1 snd_soc_core
atkbd 40960 0
libps2 24576 1 atkbd
intel_tcc_cooling 12288 0
watchdog 49152 1 iTCO_wdt
x86_pkg_temp_thermal 16384 0
intel_powerclamp 20480 0
serio 28672 1 atkbd
vivaldi_fmap 12288 1 atkbd
snd_pcm_dmaengine 16384 1 snd_soc_core
coretemp 20480 0
loop 45056 0
mei_hdcp 28672 0
crct10dif_pclmul 12288 1
mei_pxp 20480 0
snd_hda_intel 69632 0
crc32_pclmul 12288 0
polyval_clmulni 12288 0
polyval_generic 12288 1 polyval_clmulni
ghash_clmulni_intel 16384 0
snd_intel_dspcfg 40960 2 snd_soc_avs,snd_hda_intel
sha512_ssse3 53248 0
sha256_ssse3 36864 0
snd_intel_sdw_acpi 16384 1 snd_intel_dspcfg
intel_wmi_thunderbolt 16384 0
sha1_ssse3 32768 0
snd_hda_codec 221184 6 snd_hda_codec_generic,snd_soc_avs,snd_hda_codec_hdmi,snd_soc_hda_codec,snd_hda_intel,snd_hda_codec_realtek
nls_iso8859_1 12288 1
aesni_intel 126976 0
nls_cp437 16384 1
gf128mul 16384 2 polyval_generic,aesni_intel
crypto_simd 16384 1 aesni_intel
cryptd 28672 2 crypto_simd,ghash_clmulni_intel
snd_hda_core 151552 8 snd_hda_codec_generic,snd_soc_avs,snd_hda_codec_hdmi,snd_soc_hda_codec,snd_hda_intel,snd_hda_ext_core,snd_hda_codec,snd_hda_codec_realtek
vfat 24576 1
rapl 20480 0
fat 114688 1 vfat
snd_hwdep 20480 1 snd_hda_codec
sd_mod 86016 0
snd_pcm 196608 8 snd_soc_avs,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_compress,snd_soc_core,snd_hda_core,snd_pcm_dmaengine
e1000e 385024 0
intel_cstate 20480 0
ptp 49152 1 e1000e
intel_uncore 270336 0
snd_timer 53248 1 snd_pcm
snd 159744 10 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_compress,snd_soc_core,snd_pcm
drm_buddy 28672 1 i915
i2c_i801 45056 0
i2c_smbus 20480 1 i2c_i801
ttm 110592 1 i915
parport_pc 49152 0
input_leds 12288 0
pps_core 32768 1 ptp
i2c_mux 16384 1 i2c_i801
soundcore 16384 1 snd
uas 36864 0
thermal 28672 0
fan 28672 0
parport 53248 2 parport_pc,ppdev
rtc_cmos 28672 1
drm_display_helper 294912 1 i915
led_class 20480 2 snd_hda_codec_generic,input_leds
mousedev 24576 0
zfs 6692864 6
joydev 28672 0
intel_pmc_core 126976 0
cec 81920 2 drm_display_helper,i915
evdev 28672 14
mac_hid 12288 0
intel_gtt 28672 1 i915
intel_vsec 20480 1 intel_pmc_core
i2c_algo_bit 24576 1 i915
tpm_crb 28672 0
pmt_telemetry 16384 1 intel_pmc_core
tpm_tis 16384 0
tiny_power_button 12288 0
video 81920 1 i915
pmt_class 16384 1 pmt_telemetry
acpi_pad 24576 0
tpm_tis_core 36864 1 tpm_tis
mei_me 57344 2
button 28672 0
wmi 32768 2 video,intel_wmi_thunderbolt
mei 208896 5 mei_hdcp,mei_pxp,mei_me
edac_core 114688 0
spl 155648 1 zfs
xt_nat 12288 4
vhost_vsock 24576 0
vmw_vsock_virtio_transport_common 57344 1 vhost_vsock
vhost 69632 2 vhost_vsock,vhost_net
vhost_iotlb 16384 1 vhost
vsock 61440 4 vmw_vsock_virtio_transport_common,vhost_vsock
xt_MASQUERADE 16384 2
nf_nat 65536 3 xt_nat,nft_chain_nat,xt_MASQUERADE
nf_conntrack 204800 5 xt_conntrack,nf_nat,nft_ct,xt_nat,xt_MASQUERADE
nf_defrag_ipv6 24576 1 nf_conntrack
nf_defrag_ipv4 12288 1 nf_conntrack
libcrc32c 12288 3 nf_conntrack,nf_nat,nf_tables
xt_CHECKSUM 12288 0
xt_comment 12288 0
x_tables 57344 8 xt_conntrack,nft_compat,xt_tcpudp,xt_addrtype,xt_CHECKSUM,xt_nat,xt_comment,xt_MASQUERADE
veth 40960 0
br_netfilter 36864 0
tun 69632 1 vhost_net
tap 32768 1 vhost_net
macvlan 36864 0
bridge 413696 1 br_netfilter
stp 12288 1 bridge
llc 16384 2 bridge,stp
kvm_intel 438272 0
kvm 1388544 1 kvm_intel
irqbypass 12288 1 kvm
fuse 229376 5
efi_pstore 12288 0
configfs 69632 1
nfnetlink 20480 4 nft_compat,nf_tables
efivarfs 32768 1
tpm 122880 3 tpm_tis,tpm_crb,tpm_tis_core
rng_core 20480 1 tpm
dmi_sysfs 28672 0
autofs4 65536 0
ext4 1167360 1
crc32c_generic 12288 0
crc16 12288 1 ext4
mbcache 16384 1 ext4
jbd2 208896 1 ext4
usb_storage 94208 1 uas
hid_generic 12288 0
usbhid 90112 0
hid 274432 2 usbhid,hid_generic
ahci 57344 0
libahci 69632 1 ahci
nvme 73728 3
libata 495616 2 libahci,ahci
xhci_pci 24576 0
nvme_core 253952 4 nvme
xhci_hcd 401408 1 xhci_pci
scsi_mod 344064 4 sd_mod,usb_storage,uas,libata
crc32c_intel 16384 3
nvme_auth 24576 1 nvme_core
scsi_common 16384 5 scsi_mod,sd_mod,usb_storage,uas,libata
dm_mod 225280 0
dax 53248 1 dm_mod
ls -lh /sys/class/block/*/device/device/driver
lrwxrwxrwx 1 root root 0 18. Nov 16:51 /sys/class/block/nvme0n1/device/device/driver -> ../../../../bus/pci/drivers/nvme
$ sudo dmesg | grep -i tpm
[sudo] password for alangeb:
[ 0.000000] efi: TPMFinalLog=0xba776000 ACPI 2.0=0xba3c7000 ACPI=0xba3c7000 SMBIOS=0xbadce000 SMBIOS 3.0=0xbadcd000 ESRT=0xb868bc58 RNG=0xb9f84018 INITRD=0xb1cffad8 TPMEventLog=0xb9f81018
[ 0.009899] ACPI: TPM2 0x00000000BA3FCC58 000034 (v03 ALASKA A M I 00000001 AMI 00000000)
[ 0.009918] ACPI: Reserving TPM2 table memory at [mem 0xba3fcc58-0xba3fcc8b]
[ 2.348817] systemd[1]: systemd 257.10 running in system mode (+PAM +AUDIT -SELINUX +APPARMOR +IMA +IPE +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK -BTF -XKBCOMMON +UTMP -SYSVINIT +LIBARCHIVE)
[ 2.886714] systemd[1]: Expecting device /dev/tpmrm0...
[ 3.379603] tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xfed40000-0xfed4087f flags 0x200] vs fed40080 f80
[ 3.380146] tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xfed40000-0xfed4087f flags 0x200] vs fed40080 f80
(not sure how bad above warning/error is)
Any thoughts on what I should/could do here?
Highly apreciate all your input…
Did you check if there’s any kind of RAID mode in the BIOS?
That’s been the most common issue with NVME drives on Intel systems.
No kind of RAID in my BIOS - went through the entire BIOS settings.
I got my system to boot by dd-ing the IncusOS image to a SATA SSD, and booting from installer from SSD! Obviously I don’t have any logs, but it feels like there is some kind of issue with USB controller on my B150 mainboard (I did try multiple different USB sticks).
@k-bx I think the title could be re-worded to make it more visible.
Could you please edit the thread title to something like IncusOS got stuck while booting?
Please create a new topic and stop hijacking my question!
Really hate to do this to after your post but it seems redundant to make a new thread when I can add 1 correlation post…. Sorry.
Similar issue to above (hang on Incus is starting then Emergency Mode press Enter loop), thing in common was using a USB key (this time a proper USB key, a Swissbit U-50n rather than a SSD in an enclosure) to run IncusOS.
Tried disabling my HBA (a Broadcom 9600-24i) without effect. All onboard storage controllers set to AHCI (ASUS x670e Proart, 9950X). Only thing I didnt do was remove attached drives (4xNVMe drives, 4xSATA SSD’s) and the GPU (9070XT).
So you got the USB image, did you get the installation or operation image?
If installation, did the installation go through and then the installed system isn’t booting or is it the USB install media itself that’s not booting?
@gibmat can we easily add logic to this path in the initrd so we can dump all the block devices (probably cat /proc/partitions and also list all the USB devices)?
Operation image
I’ve opened:
Which may help us get a better idea of what’s going on on boot failure.
Combined with:
Which will give us a good idea of what can actually be used in early boot and let us tweak that list to handle new use cases as we see them.
In your case, can you easily boot your system onto a regular Linux OS?
If so, please provide:
dmesg(soon after boot)lspci -kls -lh /sys/class/block/*/device/driver /sys/class/block/*/device/device/driver
I looked at a few AMD systems here and they’re all on the built-in USB controller, but maybe your system is different somehow and needs extra drivers for USB devices to be accessible.
Yeah, it hopefully won’t be too hard to add some sort of service that executes as part of systemd’s emergency.target logic.
DMESG
[ 0.555921] pci 0000:07:04.0: bridge window [io 0x1000-0x2fff]
[ 0.555925] pci 0000:07:04.0: bridge window [mem 0x80a00000-0x810fffff]
[ 0.555928] pci 0000:07:04.0: bridge window [mem 0xfc80000000-0xfcd51fffff 64bit pref]
[ 0.555933] pci 0000:66:00.0: BAR 0 [mem 0x81100000-0x81103fff 64bit]: assigned
[ 0.555943] pci 0000:07:08.0: PCI bridge to [bus 66]
[ 0.555947] pci 0000:07:08.0: bridge window [mem 0x81100000-0x811fffff]
[ 0.555954] pci 0000:67:00.0: BAR 0 [mem 0x81200000-0x81207fff 64bit]: assigned
[ 0.555962] pci 0000:07:0c.0: PCI bridge to [bus 67]
[ 0.555965] pci 0000:07:0c.0: bridge window [mem 0x81200000-0x812fffff]
[ 0.555972] pci 0000:68:00.0: ROM [mem 0x81300000-0x8137ffff pref]: assigned
[ 0.555973] pci 0000:68:00.0: BAR 5 [mem 0x81380000-0x813803ff]: assigned
[ 0.555976] pci 0000:07:0d.0: PCI bridge to [bus 68]
[ 0.555980] pci 0000:07:0d.0: bridge window [mem 0x81300000-0x813fffff]
[ 0.555986] pci 0000:06:00.0: PCI bridge to [bus 07-68]
[ 0.555988] pci 0000:06:00.0: bridge window [io 0x1000-0x2fff]
[ 0.555992] pci 0000:06:00.0: bridge window [mem 0x80100000-0x813fffff]
[ 0.555995] pci 0000:06:00.0: bridge window [mem 0xfc80000000-0xfcd53fffff 64bit pref]
[ 0.555999] pci 0000:04:08.0: PCI bridge to [bus 06-68]
[ 0.556001] pci 0000:04:08.0: bridge window [io 0x1000-0x2fff]
[ 0.556003] pci 0000:04:08.0: bridge window [mem 0x80100000-0x813fffff]
[ 0.556005] pci 0000:04:08.0: bridge window [mem 0xfc80000000-0xfcd53fffff 64bit pref]
[ 0.556009] pci 0000:69:00.0: BAR 0 [mem 0x81400000-0x81407fff 64bit]: assigned
[ 0.556014] pci 0000:04:0c.0: PCI bridge to [bus 69]
[ 0.556016] pci 0000:04:0c.0: bridge window [mem 0x81400000-0x814fffff]
[ 0.556021] pci 0000:6a:00.0: ROM [mem 0x81500000-0x8157ffff pref]: assigned
[ 0.556022] pci 0000:6a:00.0: BAR 5 [mem 0x81580000-0x815803ff]: assigned
[ 0.556024] pci 0000:04:0d.0: PCI bridge to [bus 6a]
[ 0.556026] pci 0000:04:0d.0: bridge window [mem 0x81500000-0x815fffff]
[ 0.556031] pci 0000:03:00.0: PCI bridge to [bus 04-6a]
[ 0.556032] pci 0000:03:00.0: bridge window [io 0x1000-0x2fff]
[ 0.556035] pci 0000:03:00.0: bridge window [mem 0x80000000-0x815fffff]
[ 0.556037] pci 0000:03:00.0: bridge window [mem 0xfc80000000-0xfcd53fffff 64bit pref]
[ 0.556040] pci 0000:00:02.1: PCI bridge to [bus 03-6a]
[ 0.556041] pci 0000:00:02.1: bridge window [io 0x1000-0x3fff]
[ 0.556043] pci 0000:00:02.1: bridge window [mem 0x80000000-0x815fffff]
[ 0.556045] pci 0000:00:02.1: bridge window [mem 0xfc80000000-0xfcd53fffff 64bit pref]
[ 0.556054] pci 0000:00:02.2: PCI bridge to [bus 6b]
[ 0.556056] pci 0000:00:02.2: bridge window [mem 0xddd00000-0xdddfffff]
[ 0.556067] pci 0000:00:08.1: PCI bridge to [bus 6c]
[ 0.556072] pci 0000:00:08.1: bridge window [io 0xf000-0xffff]
[ 0.556074] pci 0000:00:08.1: bridge window [mem 0xdd600000-0xddbfffff]
[ 0.556075] pci 0000:00:08.1: bridge window [mem 0xfce0000000-0xfcefffffff 64bit pref]
[ 0.556077] pci 0000:00:08.3: PCI bridge to [bus 6d]
[ 0.556079] pci 0000:00:08.3: bridge window [mem 0xddc00000-0xddcfffff]
[ 0.556082] pci_bus 0000:00: resource 4 [io 0x0000-0x03af window]
[ 0.556083] pci_bus 0000:00: resource 5 [io 0x03e0-0x0cf7 window]
[ 0.556084] pci_bus 0000:00: resource 6 [io 0x03b0-0x03df window]
[ 0.556085] pci_bus 0000:00: resource 7 [io 0x0d00-0xffff window]
[ 0.556086] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000dffff window]
[ 0.556087] pci_bus 0000:00: resource 9 [mem 0x80000000-0xdfffffff window]
[ 0.556088] pci_bus 0000:00: resource 10 [mem 0x2080000000-0xfcffffffff window]
[ 0.556089] pci_bus 0000:01: resource 1 [mem 0xddf00000-0xddffffff]
[ 0.556090] pci_bus 0000:02: resource 1 [mem 0xdde00000-0xddefffff]
[ 0.556091] pci_bus 0000:02: resource 2 [mem 0xfcf0000000-0xfcf00fffff 64bit pref]
[ 0.556092] pci_bus 0000:03: resource 0 [io 0x1000-0x3fff]
[ 0.556092] pci_bus 0000:03: resource 1 [mem 0x80000000-0x815fffff]
[ 0.556093] pci_bus 0000:03: resource 2 [mem 0xfc80000000-0xfcd53fffff 64bit pref]
[ 0.556094] pci_bus 0000:04: resource 0 [io 0x1000-0x2fff]
[ 0.556095] pci_bus 0000:04: resource 1 [mem 0x80000000-0x815fffff]
[ 0.556096] pci_bus 0000:04: resource 2 [mem 0xfc80000000-0xfcd53fffff 64bit pref]
[ 0.556097] pci_bus 0000:05: resource 1 [mem 0x80000000-0x800fffff]
[ 0.556098] pci_bus 0000:06: resource 0 [io 0x1000-0x2fff]
[ 0.556098] pci_bus 0000:06: resource 1 [mem 0x80100000-0x813fffff]
[ 0.556099] pci_bus 0000:06: resource 2 [mem 0xfc80000000-0xfcd53fffff 64bit pref]
[ 0.556100] pci_bus 0000:07: resource 0 [io 0x1000-0x2fff]
[ 0.556101] pci_bus 0000:07: resource 1 [mem 0x80100000-0x813fffff]
[ 0.556102] pci_bus 0000:07: resource 2 [mem 0xfc80000000-0xfcd53fffff 64bit pref]
[ 0.556103] pci_bus 0000:08: resource 1 [mem 0x80100000-0x801fffff]
[ 0.556104] pci_bus 0000:08: resource 2 [mem 0xfcd5300000-0xfcd53fffff 64bit pref]
[ 0.556105] pci_bus 0000:09: resource 1 [mem 0x80800000-0x809fffff]
[ 0.556105] pci_bus 0000:0a: resource 1 [mem 0x80200000-0x807fffff]
[ 0.556106] pci_bus 0000:0c: resource 0 [io 0x1000-0x2fff]
[ 0.556107] pci_bus 0000:0c: resource 1 [mem 0x80a00000-0x810fffff]
[ 0.556108] pci_bus 0000:0c: resource 2 [mem 0xfc80000000-0xfcd51fffff 64bit pref]
[ 0.556109] pci_bus 0000:0d: resource 0 [io 0x1000-0x2fff]
[ 0.556110] pci_bus 0000:0d: resource 1 [mem 0x80a00000-0x810fffff]
[ 0.556110] pci_bus 0000:0d: resource 2 [mem 0xfc80000000-0xfcd51fffff 64bit pref]
[ 0.556111] pci_bus 0000:0e: resource 2 [mem 0xfcd5100000-0xfcd51fffff 64bit pref]
[ 0.556112] pci_bus 0000:0f: resource 0 [io 0x1000-0x1fff]
[ 0.556113] pci_bus 0000:0f: resource 1 [mem 0x80a00000-0x80bfffff]
[ 0.556114] pci_bus 0000:0f: resource 2 [mem 0xfcb0000000-0xfcd4ffffff 64bit pref]
[ 0.556115] pci_bus 0000:3a: resource 1 [mem 0x80c00000-0x80cfffff]
[ 0.556115] pci_bus 0000:3b: resource 0 [io 0x2000-0x2fff]
[ 0.556116] pci_bus 0000:3b: resource 1 [mem 0x80d00000-0x80efffff]
[ 0.556117] pci_bus 0000:3b: resource 2 [mem 0xfc80000000-0xfca4ffffff 64bit pref]
[ 0.556118] pci_bus 0000:66: resource 1 [mem 0x81100000-0x811fffff]
[ 0.556119] pci_bus 0000:67: resource 1 [mem 0x81200000-0x812fffff]
[ 0.556120] pci_bus 0000:68: resource 1 [mem 0x81300000-0x813fffff]
[ 0.556120] pci_bus 0000:69: resource 1 [mem 0x81400000-0x814fffff]
[ 0.556121] pci_bus 0000:6a: resource 1 [mem 0x81500000-0x815fffff]
[ 0.556122] pci_bus 0000:6b: resource 1 [mem 0xddd00000-0xdddfffff]
[ 0.556123] pci_bus 0000:6c: resource 0 [io 0xf000-0xffff]
[ 0.556123] pci_bus 0000:6c: resource 1 [mem 0xdd600000-0xddbfffff]
[ 0.556124] pci_bus 0000:6c: resource 2 [mem 0xfce0000000-0xfcefffffff 64bit pref]
[ 0.556125] pci_bus 0000:6d: resource 1 [mem 0xddc00000-0xddcfffff]
[ 0.556594] pci 0000:0c:00.0: CLS mismatch (64 != 128), using 64 bytes
[ 0.556807] pci 0000:6c:00.1: D0 power state depends on 0000:6c:00.0
[ 0.556949] pci 0000:00:00.2: AMD-Vi: IOMMU performance counters supported
[ 0.556969] Unpacking initramfs…
[ 0.556980] pci 0000:00:01.0: Adding to iommu group 0
[ 0.556990] pci 0000:00:01.2: Adding to iommu group 1
[ 0.557000] pci 0000:00:01.3: Adding to iommu group 2
[ 0.557013] pci 0000:00:02.0: Adding to iommu group 3
[ 0.557021] pci 0000:00:02.1: Adding to iommu group 4
[ 0.557030] pci 0000:00:02.2: Adding to iommu group 5
[ 0.557039] pci 0000:00:03.0: Adding to iommu group 6
[ 0.557049] pci 0000:00:04.0: Adding to iommu group 7
[ 0.557062] pci 0000:00:08.0: Adding to iommu group 8
[ 0.557069] pci 0000:00:08.1: Adding to iommu group 9
[ 0.557076] pci 0000:00:08.3: Adding to iommu group 10
[ 0.557090] pci 0000:00:14.0: Adding to iommu group 11
[ 0.557097] pci 0000:00:14.3: Adding to iommu group 11
[ 0.557132] pci 0000:00:18.0: Adding to iommu group 12
[ 0.557139] pci 0000:00:18.1: Adding to iommu group 12
[ 0.557145] pci 0000:00:18.2: Adding to iommu group 12
[ 0.557152] pci 0000:00:18.3: Adding to iommu group 12
[ 0.557158] pci 0000:00:18.4: Adding to iommu group 12
[ 0.557165] pci 0000:00:18.5: Adding to iommu group 12
[ 0.557171] pci 0000:00:18.6: Adding to iommu group 12
[ 0.557179] pci 0000:00:18.7: Adding to iommu group 12
[ 0.557187] pci 0000:01:00.0: Adding to iommu group 13
[ 0.557197] pci 0000:02:00.0: Adding to iommu group 14
[ 0.557206] pci 0000:03:00.0: Adding to iommu group 15
[ 0.557222] pci 0000:04:00.0: Adding to iommu group 16
[ 0.557234] pci 0000:04:08.0: Adding to iommu group 17
[ 0.557246] pci 0000:04:0c.0: Adding to iommu group 18
[ 0.557258] pci 0000:04:0d.0: Adding to iommu group 19
[ 0.557264] pci 0000:05:00.0: Adding to iommu group 16
[ 0.557269] pci 0000:06:00.0: Adding to iommu group 17
[ 0.557281] pci 0000:07:00.0: Adding to iommu group 17
[ 0.557293] pci 0000:07:01.0: Adding to iommu group 17
[ 0.557304] pci 0000:07:02.0: Adding to iommu group 17
[ 0.557316] pci 0000:07:03.0: Adding to iommu group 17
[ 0.557328] pci 0000:07:04.0: Adding to iommu group 17
[ 0.557340] pci 0000:07:08.0: Adding to iommu group 17
[ 0.557353] pci 0000:07:0c.0: Adding to iommu group 17
[ 0.557366] pci 0000:07:0d.0: Adding to iommu group 17
[ 0.557374] pci 0000:08:00.0: Adding to iommu group 17
[ 0.557381] pci 0000:09:00.0: Adding to iommu group 17
[ 0.557389] pci 0000:0a:00.0: Adding to iommu group 17
[ 0.557397] pci 0000:0c:00.0: Adding to iommu group 17
[ 0.557420] pci 0000:0d:00.0: Adding to iommu group 17
[ 0.557442] pci 0000:0d:01.0: Adding to iommu group 17
[ 0.557465] pci 0000:0d:02.0: Adding to iommu group 17
[ 0.557487] pci 0000:0d:03.0: Adding to iommu group 17
[ 0.557523] pci 0000:0e:00.0: Adding to iommu group 17
[ 0.557558] pci 0000:3a:00.0: Adding to iommu group 17
[ 0.557565] pci 0000:66:00.0: Adding to iommu group 17
[ 0.557569] pci 0000:67:00.0: Adding to iommu group 17
[ 0.557572] pci 0000:68:00.0: Adding to iommu group 17
[ 0.557575] pci 0000:69:00.0: Adding to iommu group 18
[ 0.557578] pci 0000:6a:00.0: Adding to iommu group 19
[ 0.557586] pci 0000:6b:00.0: Adding to iommu group 20
[ 0.557606] pci 0000:6c:00.0: Adding to iommu group 21
[ 0.557614] pci 0000:6c:00.1: Adding to iommu group 22
[ 0.557624] pci 0000:6c:00.2: Adding to iommu group 23
[ 0.557632] pci 0000:6c:00.3: Adding to iommu group 24
[ 0.557642] pci 0000:6c:00.4: Adding to iommu group 25
[ 0.557649] pci 0000:6d:00.0: Adding to iommu group 26
[ 0.557961] AMD-Vi: Extended features (0x246577efa2254afa, 0x0): PPR NX GT [5] IA GA PC GA_vAPIC
[ 0.557966] AMD-Vi: Interrupt remapping enabled
[ 0.829481] AMD-Vi: Virtual APIC enabled
[ 0.829490] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.829502] software IO TLB: mapped [mem 0x000000005d100000-0x0000000061100000] (64MB)
[ 0.829527] LVT offset 0 assigned for vector 0x400
[ 0.830453] perf: AMD IBS detected (0x00081bff)
[ 0.833515] amd_uncore: 16 amd_df counters detected
[ 0.833521] amd_uncore: 6 amd_l3 counters detected
[ 0.833526] amd_uncore: 4 amd_umc_0 counters detected
[ 0.833529] amd_uncore: 4 amd_umc_1 counters detected
[ 0.836470] perf/amd_iommu: Detected AMD IOMMU #0 (2 banks, 4 counters/bank).
[ 0.840948] Initialise system trusted keyrings
[ 0.840969] workingset: timestamp_bits=40 max_order=25 bucket_order=0
[ 0.840997] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.841000] fuse: init (API version 7.41)
[ 0.841046] SGI XFS with ACLs, security attributes, no debug enabled
[ 0.844668] xor: automatically using best checksumming function avx
[ 0.844670] Key type asymmetric registered
[ 0.844671] Asymmetric key parser ‘x509’ registered
[ 0.844679] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.844693] io scheduler mq-deadline registered
[ 0.844695] io scheduler kyber registered
[ 0.844698] io scheduler bfq registered
[ 0.845534] pcieport 0000:00:01.2: PME: Signaling with IRQ 28
[ 0.845657] pcieport 0000:00:01.3: PME: Signaling with IRQ 29
[ 0.845774] pcieport 0000:00:02.1: PME: Signaling with IRQ 30
[ 0.845877] pcieport 0000:00:02.2: PME: Signaling with IRQ 31
[ 0.845976] pcieport 0000:00:08.1: PME: Signaling with IRQ 32
[ 0.846060] pcieport 0000:00:08.3: PME: Signaling with IRQ 33
[ 0.848211] IPMI message handler: version 39.2
[ 0.848549] Monitor-Mwait will be used to enter C-1 state
[ 0.849987] Estimated ratio of average max frequency by base frequency (times 1024): 1197
[ 0.850036] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.850153] 00:04: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 1.441029] Freeing initrd memory: 37232K
[ 1.442306] lp: driver loaded but no devices found
[ 1.442427] Hangcheck: starting hangcheck timer 0.9.1 (tick is 180 seconds, margin is 60 seconds).
[ 1.443657] Floppy drive(s): fd0 is unknown type 15 (usb?), fd1 is unknown type 15 (usb?)
[ 1.444335] loop: module loaded
[ 1.444344] mtip32xx Version 1.3.1
[ 1.444393] zram: Added device: zram0
[ 1.444547] nvme nvme0: pci function 0000:01:00.0
[ 1.444550] nvme nvme1: pci function 0000:05:00.0
[ 1.444555] nvme nvme3: pci function 0000:6b:00.0
[ 1.444556] nvme nvme2: pci function 0000:66:00.0
[ 1.444638] ahci 0000:68:00.0: version 3.0
[ 1.451900] ahci 0000:68:00.0: SSS flag set, parallel bus scan disabled
[ 1.455258] ahci 0000:68:00.0: AHCI vers 0001.0301, 32 command slots, 6 Gbps, SATA mode
[ 1.455261] ahci 0000:68:00.0: 4/6 ports implemented (port mask 0xf)
[ 1.455263] ahci 0000:68:00.0: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part sxs deso sadm sds apst
[ 1.459211] scsi host0: ahci
[ 1.459270] scsi host1: ahci
[ 1.459327] scsi host2: ahci
[ 1.459410] scsi host3: ahci
[ 1.459466] scsi host4: ahci
[ 1.459521] scsi host5: ahci
[ 1.459547] ata1: SATA max UDMA/133 abar m1024@0x81380000 port 0x81380100 irq 51 lpm-pol 0
[ 1.459745] ata2: SATA max UDMA/133 abar m1024@0x81380000 port 0x81380180 irq 51 lpm-pol 0
[ 1.459903] ata3: SATA max UDMA/133 abar m1024@0x81380000 port 0x81380200 irq 51 lpm-pol 0
[ 1.460095] ata4: SATA max UDMA/133 abar m1024@0x81380000 port 0x81380280 irq 51 lpm-pol 0
[ 1.460097] ata5: DUMMY
[ 1.460097] ata6: DUMMY
[ 1.471385] ahci 0000:6a:00.0: SSS flag set, parallel bus scan disabled
[ 1.472016] ahci 0000:6a:00.0: AHCI vers 0001.0301, 32 command slots, 6 Gbps, SATA mode
[ 1.472017] ahci 0000:6a:00.0: 4/6 ports implemented (port mask 0xf)
[ 1.472018] ahci 0000:6a:00.0: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part sxs deso sadm sds apst
[ 1.472192] scsi host6: ahci
[ 1.472235] scsi host7: ahci
[ 1.472289] scsi host8: ahci
[ 1.472328] scsi host9: ahci
[ 1.472428] scsi host10: ahci
[ 1.472470] scsi host11: ahci
[ 1.472489] ata7: SATA max UDMA/133 abar m1024@0x81580000 port 0x81580100 irq 54 lpm-pol 0
[ 1.472491] ata8: SATA max UDMA/133 abar m1024@0x81580000 port 0x81580180 irq 54 lpm-pol 0
[ 1.472492] ata9: SATA max UDMA/133 abar m1024@0x81580000 port 0x81580200 irq 54 lpm-pol 0
[ 1.472494] ata10: SATA max UDMA/133 abar m1024@0x81580000 port 0x81580280 irq 54 lpm-pol 0
[ 1.472495] ata11: DUMMY
[ 1.472496] ata12: DUMMY
[ 1.472541] Rounding down aligned max_sectors from 4294967295 to 4294967288
[ 1.472556] db_root: cannot open: /etc/target
[ 1.472636] VFIO - User Level meta-driver version: 0.3
[ 1.472692] xhci_hcd 0000:3a:00.0: xHCI Host Controller
[ 1.472696] xhci_hcd 0000:3a:00.0: new USB bus registered, assigned bus number 1
[ 1.473819] xhci_hcd 0000:3a:00.0: hcc params 0x20007fc1 hci version 0x110 quirks 0x0000000200009810
[ 1.474164] xhci_hcd 0000:3a:00.0: xHCI Host Controller
[ 1.474165] xhci_hcd 0000:3a:00.0: new USB bus registered, assigned bus number 2
[ 1.474167] xhci_hcd 0000:3a:00.0: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.474238] hub 1-0:1.0: USB hub found
[ 1.474249] hub 1-0:1.0: 2 ports detected
[ 1.474363] hub 2-0:1.0: USB hub found
[ 1.474370] hub 2-0:1.0: 2 ports detected
[ 1.474531] xhci_hcd 0000:67:00.0: xHCI Host Controller
[ 1.474534] xhci_hcd 0000:67:00.0: new USB bus registered, assigned bus number 3
[ 1.477474] nvme nvme3: D3 entry latency set to 10 seconds
[ 1.477485] nvme nvme0: D3 entry latency set to 10 seconds
[ 1.479907] nvme nvme0: 32/0/0 default/read/poll queues
[ 1.480348] nvme nvme3: 32/0/0 default/read/poll queues
[ 1.487863] nvme nvme1: 8/0/0 default/read/poll queues
[ 1.491714] nvme nvme2: 8/0/0 default/read/poll queues
[ 1.494222] nvme1n1: p1
[ 1.498011] nvme2n1: p1
[ 1.530508] xhci_hcd 0000:67:00.0: hcc params 0x0200ef81 hci version 0x110 quirks 0x0000000200000010
[ 1.530780] xhci_hcd 0000:67:00.0: xHCI Host Controller
[ 1.530783] xhci_hcd 0000:67:00.0: new USB bus registered, assigned bus number 4
[ 1.530785] xhci_hcd 0000:67:00.0: Host supports USB 3.2 Enhanced SuperSpeed
[ 1.531553] hub 3-0:1.0: USB hub found
[ 1.531568] hub 3-0:1.0: 12 ports detected
[ 1.532266] usb usb4: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.532313] hub 4-0:1.0: USB hub found
[ 1.532326] hub 4-0:1.0: 5 ports detected
[ 1.532653] xhci_hcd 0000:69:00.0: xHCI Host Controller
[ 1.532655] xhci_hcd 0000:69:00.0: new USB bus registered, assigned bus number 5
[ 1.588675] xhci_hcd 0000:69:00.0: hcc params 0x0200ef81 hci version 0x110 quirks 0x0000000200000010
[ 1.588903] xhci_hcd 0000:69:00.0: xHCI Host Controller
[ 1.588904] xhci_hcd 0000:69:00.0: new USB bus registered, assigned bus number 6
[ 1.588906] xhci_hcd 0000:69:00.0: Host supports USB 3.2 Enhanced SuperSpeed
[ 1.589726] hub 5-0:1.0: USB hub found
[ 1.589735] hub 5-0:1.0: 12 ports detected
[ 1.590410] usb usb6: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.590460] hub 6-0:1.0: USB hub found
[ 1.590470] hub 6-0:1.0: 5 ports detected
[ 1.590786] xhci_hcd 0000:6c:00.3: xHCI Host Controller
[ 1.590788] xhci_hcd 0000:6c:00.3: new USB bus registered, assigned bus number 7
[ 1.591134] xhci_hcd 0000:6c:00.3: hcc params 0x0120ffc5 hci version 0x120 quirks 0x0000000200000010
[ 1.591301] xhci_hcd 0000:6c:00.3: xHCI Host Controller
[ 1.591302] xhci_hcd 0000:6c:00.3: new USB bus registered, assigned bus number 8
[ 1.591303] xhci_hcd 0000:6c:00.3: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.591365] hub 7-0:1.0: USB hub found
[ 1.591369] hub 7-0:1.0: 2 ports detected
[ 1.591498] usb usb8: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.591547] hub 8-0:1.0: USB hub found
[ 1.591554] hub 8-0:1.0: 2 ports detected
[ 1.591691] xhci_hcd 0000:6c:00.4: xHCI Host Controller
[ 1.591693] xhci_hcd 0000:6c:00.4: new USB bus registered, assigned bus number 9
[ 1.592029] xhci_hcd 0000:6c:00.4: hcc params 0x0120ffc5 hci version 0x120 quirks 0x0000000200000010
[ 1.592198] xhci_hcd 0000:6c:00.4: xHCI Host Controller
[ 1.592199] xhci_hcd 0000:6c:00.4: new USB bus registered, assigned bus number 10
[ 1.592201] xhci_hcd 0000:6c:00.4: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.592256] hub 9-0:1.0: USB hub found
[ 1.592263] hub 9-0:1.0: 2 ports detected
[ 1.592394] usb usb10: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.592434] hub 10-0:1.0: USB hub found
[ 1.592442] hub 10-0:1.0: 2 ports detected
[ 1.592573] xhci_hcd 0000:6d:00.0: xHCI Host Controller
[ 1.592576] xhci_hcd 0000:6d:00.0: new USB bus registered, assigned bus number 11
[ 1.593838] xhci_hcd 0000:6d:00.0: USB3 root hub has no ports
[ 1.593840] xhci_hcd 0000:6d:00.0: hcc params 0x0110ffc5 hci version 0x120 quirks 0x0000000200000010
[ 1.594022] xhci_hcd 0000:6d:00.0: xHCI Host Controller
[ 1.594024] xhci_hcd 0000:6d:00.0: new USB bus registered, assigned bus number 12
[ 1.594026] xhci_hcd 0000:6d:00.0: Host supports USB 3.0 SuperSpeed
[ 1.594067] hub 11-0:1.0: USB hub found
[ 1.594078] hub 11-0:1.0: 1 port detected
[ 1.594145] usb usb12: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.594180] hub 12-0:1.0: USB hub found
[ 1.594182] hub 12-0:1.0: config failed, hub doesn’t have any ports! (err -19)
[ 1.594250] usbcore: registered new interface driver uas
[ 1.594264] usbcore: registered new interface driver usb-storage
[ 1.594279] i8042: PNP: No PS/2 controller found.
[ 1.594293] mousedev: PS/2 mouse device common for all mice
[ 1.594313] usbcore: registered new interface driver synaptics_usb
[ 1.594332] input: PC Speaker as /devices/platform/pcspkr/input/input0
[ 1.594354] rtc_cmos 00:02: RTC can wake from S4
[ 1.594501] rtc_cmos 00:02: registered as rtc0
[ 1.594535] rtc_cmos 00:02: setting system clock to 2025-11-20T04:08:24 UTC (1763611704)
[ 1.594552] rtc_cmos 00:02: alarms up to one month, y3k, 114 bytes nvram
[ 1.595884] efifb: probing for efifb
[ 1.595904] efifb: framebuffer at 0xfce0000000, using 3072k, total 3072k
[ 1.595905] efifb: mode is 1024x768x32, linelength=4096, pages=1
[ 1.595907] efifb: scrolling: redraw
[ 1.595907] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 1.596138] Console: switching to colour frame buffer device 128x48
[ 1.596323] fb0: EFI VGA frame buffer device
[ 1.596342] pstore: Using crash dump compression: deflate
[ 1.596354] pstore: Registered efi_pstore as persistent store backend
[ 1.596372] hid: raw HID events driver (C) Jiri Kosina
[ 1.596520] usbcore: registered new interface driver usbhid
[ 1.596532] usbhid: USB HID core driver
[ 1.596587] ipip: IPv4 and MPLS over IPv4 tunneling driver
[ 1.596679] NET: Registered PF_INET6 protocol family
[ 1.598725] Segment Routing with IPv6
[ 1.598746] RPL Segment Routing with IPv6
[ 1.598753] In-situ OAM (IOAM) with IPv6
[ 1.598788] 9pnet: Installing 9P2000 support
[ 1.599715] microcode: Current revision: 0x0b404032
[ 1.599937] IPI shorthand broadcast: enabled
[ 1.600832] sched_clock: Marking stable (1599026233, 1349151)->(1608243482, -7868098)
[ 1.600964] registered taskstats version 1
[ 1.601027] Loading compiled-in X.509 certificates
[ 1.601726] Demotion targets for Node 0: null
[ 1.601865] Btrfs loaded, zoned=no, fsverity=no
[ 1.602078] clk: Disabling unused clocks
[ 1.764395] ata1: SATA link down (SStatus 0 SControl 330)
[ 1.827630] usb 3-7: new full-speed USB device number 2 using xhci_hcd
[ 1.870388] tsc: Refined TSC clocksource calibration: 4291.916 MHz
[ 1.870543] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x3ddd8f89348, max_idle_ns: 440795423566 ns
[ 1.870725] clocksource: Switched to clocksource tsc
[ 1.891417] usb 5-4: new high-speed USB device number 2 using xhci_hcd
[ 1.934398] ata7: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.936451] ata7.00: Model ‘Samsung SSD 860 PRO 2TB’, rev ‘RVM01B6Q’, applying quirks: noncqtrim zeroaftertrim noncqonati nolpmonati
[ 1.936680] ata7.00: supports DRM functions and may not be fully accessible
[ 1.936838] ata7.00: ATA-11: Samsung SSD 860 PRO 2TB, RVM01B6Q, max UDMA/133
[ 1.937754] ata7.00: 4000797360 sectors, multi 1: LBA48 NCQ (depth 32), AA
[ 1.944063] ata7.00: Features: Trust Dev-Sleep NCQ-sndrcv
[ 1.944505] ata7.00: supports DRM functions and may not be fully accessible
[ 1.951910] ata7.00: configured for UDMA/133
[ 2.119545] hub 5-4:1.0: USB hub found
[ 2.123443] hub 5-4:1.0: 4 ports detected
[ 2.182807] usb 3-7: config 1 has an invalid interface number: 2 but max is 1
[ 2.182971] usb 3-7: config 1 has no interface number 1
[ 2.204114] usb 6-2: new SuperSpeed USB device number 2 using xhci_hcd
[ 2.208661] hid-generic 0003:0B05:19AF.0001: hiddev96,hidraw0: USB HID v1.11 Device [AsusTek Computer Inc. AURA LED Controller] on usb-0000:67:00.0-7/input2
[ 2.227878] usb-storage 6-2:1.0: USB Mass Storage device detected
[ 2.228075] scsi host12: usb-storage 6-2:1.0
[ 2.341452] usb 6-4: new SuperSpeed USB device number 3 using xhci_hcd
[ 2.368452] hub 6-4:1.0: USB hub found
[ 2.369346] hub 6-4:1.0: 4 ports detected
[ 2.476622] usb 5-4.2: new full-speed USB device number 3 using xhci_hcd
[ 2.844569] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:02.1/0000:03:00.0/0000:04:0c.0/0000:69:00.0/usb5/5-4/5-4.2/5-4.2:1.0/0003:046D:C545.0002/input/input1
[ 2.845027] hid-generic 0003:046D:C545.0002: input,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:69:00.0-4.2/input0
[ 2.858534] input: Logitech USB Receiver Keyboard as /devices/pci0000:00/0000:00:02.1/0000:03:00.0/0000:04:0c.0/0000:69:00.0/usb5/5-4/5-4.2/5-4.2:1.1/0003:046D:C545.0003/input/input2
[ 2.909436] hid-generic 0003:046D:C545.0003: input,hidraw2: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:69:00.0-4.2/input1
[ 2.919481] hid-generic 0003:046D:C545.0004: hiddev97,hidraw3: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:69:00.0-4.2/input2
[ 3.022645] usb 5-4.4: new full-speed USB device number 4 using xhci_hcd
[ 3.278876] scsi 12:0:0:0: Direct-Access Swissbit USB Flash Drive 0100 PQ: 0 ANSI: 6
[ 3.279217] sd 12:0:0:0: Attached scsi generic sg0 type 0
[ 3.279702] sd 12:0:0:0: [sda] 62533296 512-byte logical blocks: (32.0 GB/29.8 GiB)
[ 3.287150] sd 12:0:0:0: [sda] Write Protect is off
[ 3.287293] sd 12:0:0:0: [sda] Mode Sense: 4b 00 10 08
[ 3.287813] sd 12:0:0:0: [sda] Write cache: disabled, read cache: enabled, supports DPO and FUA
[ 3.321003] sda: sda1
[ 3.321156] sd 12:0:0:0: [sda] Attached SCSI removable disk
[ 3.390464] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:02.1/0000:03:00.0/0000:04:0c.0/0000:69:00.0/usb5/5-4/5-4.4/5-4.4:1.0/0003:046D:C547.0005/input/input3
[ 3.390971] hid-generic 0003:046D:C547.0005: input,hidraw4: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:69:00.0-4.4/input0
[ 3.404547] input: Logitech USB Receiver Keyboard as /devices/pci0000:00/0000:00:02.1/0000:03:00.0/0000:04:0c.0/0000:69:00.0/usb5/5-4/5-4.4/5-4.4:1.1/0003:046D:C547.0006/input/input4
[ 3.455423] hid-generic 0003:046D:C547.0006: input,hidraw5: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:69:00.0-4.4/input1
[ 3.465452] hid-generic 0003:046D:C547.0007: hiddev98,hidraw6: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:69:00.0-4.4/input2
[ 4.494638] floppy0: no floppy controllers found
[ 4.803888] ata2: SATA link down (SStatus 0 SControl 330)
[ 5.108096] ata3: SATA link down (SStatus 0 SControl 330)
[ 5.412036] ata4: SATA link down (SStatus 0 SControl 330)
[ 5.412506] scsi 6:0:0:0: Direct-Access ATA Samsung SSD 860 1B6Q PQ: 0 ANSI: 5
[ 5.412932] ata7.00: Enabling discard_zeroes_data
[ 5.412942] sd 6:0:0:0: Attached scsi generic sg1 type 0
[ 5.413212] sd 6:0:0:0: [sdb] 4000797360 512-byte logical blocks: (2.05 TB/1.86 TiB)
[ 5.413777] sd 6:0:0:0: [sdb] Write Protect is off
[ 5.414040] sd 6:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 5.414051] sd 6:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 5.414345] sd 6:0:0:0: [sdb] Preferred minimum I/O size 512 bytes
[ 5.414876] ata7.00: Enabling discard_zeroes_data
[ 5.434418] sdb: sdb1
[ 5.434749] sd 6:0:0:0: [sdb] Attached SCSI disk
[ 5.878631] ata8: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 5.880959] ata8.00: Model ‘Samsung SSD 860 PRO 2TB’, rev ‘RVM01B6Q’, applying quirks: noncqtrim zeroaftertrim noncqonati nolpmonati
[ 5.881253] ata8.00: supports DRM functions and may not be fully accessible
[ 5.881491] ata8.00: ATA-11: Samsung SSD 860 PRO 2TB, RVM01B6Q, max UDMA/133
[ 5.882497] ata8.00: 4000797360 sectors, multi 1: LBA48 NCQ (depth 32), AA
[ 5.888925] ata8.00: Features: Trust Dev-Sleep NCQ-sndrcv
[ 5.889422] ata8.00: supports DRM functions and may not be fully accessible
[ 5.896875] ata8.00: configured for UDMA/133
[ 5.897180] scsi 7:0:0:0: Direct-Access ATA Samsung SSD 860 1B6Q PQ: 0 ANSI: 5
[ 5.897719] ata8.00: Enabling discard_zeroes_data
[ 5.897740] sd 7:0:0:0: Attached scsi generic sg2 type 0
[ 5.898001] sd 7:0:0:0: [sdc] 4000797360 512-byte logical blocks: (2.05 TB/1.86 TiB)
[ 5.898532] sd 7:0:0:0: [sdc] Write Protect is off
[ 5.898778] sd 7:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[ 5.898782] sd 7:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 5.898925] sd 7:0:0:0: [sdc] Preferred minimum I/O size 512 bytes
[ 5.899316] ata8.00: Enabling discard_zeroes_data
[ 5.912520] sdc: sdc1
[ 5.912779] sd 7:0:0:0: [sdc] Attached SCSI disk
[ 6.358586] ata9: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 6.360962] ata9.00: Model ‘Samsung SSD 860 PRO 2TB’, rev ‘RVM01B6Q’, applying quirks: noncqtrim zeroaftertrim noncqonati nolpmonati
[ 6.361236] ata9.00: supports DRM functions and may not be fully accessible
[ 6.361445] ata9.00: ATA-11: Samsung SSD 860 PRO 2TB, RVM01B6Q, max UDMA/133
[ 6.362441] ata9.00: 4000797360 sectors, multi 1: LBA48 NCQ (depth 32), AA
[ 6.368930] ata9.00: Features: Trust Dev-Sleep NCQ-sndrcv
[ 6.369416] ata9.00: supports DRM functions and may not be fully accessible
[ 6.376942] ata9.00: configured for UDMA/133
[ 6.377217] scsi 8:0:0:0: Direct-Access ATA Samsung SSD 860 1B6Q PQ: 0 ANSI: 5
[ 6.377717] ata9.00: Enabling discard_zeroes_data
[ 6.377756] sd 8:0:0:0: Attached scsi generic sg3 type 0
[ 6.377862] sd 8:0:0:0: [sdd] 4000797360 512-byte logical blocks: (2.05 TB/1.86 TiB)
[ 6.378101] sd 8:0:0:0: [sdd] Write Protect is off
[ 6.378220] sd 8:0:0:0: [sdd] Mode Sense: 00 3a 00 00
[ 6.378224] sd 8:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 6.378360] sd 8:0:0:0: [sdd] Preferred minimum I/O size 512 bytes
[ 6.378621] ata9.00: Enabling discard_zeroes_data
[ 6.386473] sdd: sdd1
[ 6.386623] sd 8:0:0:0: [sdd] Attached SCSI disk
[ 6.838619] ata10: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 6.840841] ata10.00: Model ‘Samsung SSD 860 PRO 2TB’, rev ‘RVM01B6Q’, applying quirks: noncqtrim zeroaftertrim noncqonati nolpmonati
[ 6.841089] ata10.00: supports DRM functions and may not be fully accessible
[ 6.841267] ata10.00: ATA-11: Samsung SSD 860 PRO 2TB, RVM01B6Q, max UDMA/133
[ 6.842240] ata10.00: 4000797360 sectors, multi 1: LBA48 NCQ (depth 32), AA
[ 6.848699] ata10.00: Features: Trust Dev-Sleep NCQ-sndrcv
[ 6.849162] ata10.00: supports DRM functions and may not be fully accessible
[ 6.856718] ata10.00: configured for UDMA/133
[ 6.856997] scsi 9:0:0:0: Direct-Access ATA Samsung SSD 860 1B6Q PQ: 0 ANSI: 5
[ 6.857421] sd 9:0:0:0: Attached scsi generic sg4 type 0
[ 6.857426] ata10.00: Enabling discard_zeroes_data
[ 6.857864] sd 9:0:0:0: [sde] 4000797360 512-byte logical blocks: (2.05 TB/1.86 TiB)
[ 6.858100] sd 9:0:0:0: [sde] Write Protect is off
[ 6.858327] sd 9:0:0:0: [sde] Mode Sense: 00 3a 00 00
[ 6.858333] sd 9:0:0:0: [sde] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 6.858578] sd 9:0:0:0: [sde] Preferred minimum I/O size 512 bytes
[ 6.858850] ata10.00: Enabling discard_zeroes_data
[ 6.874474] sde: sde1
[ 6.874617] sd 9:0:0:0: [sde] Attached SCSI disk
[ 6.875211] Freeing unused kernel image (initmem) memory: 3112K
[ 6.875329] Write protecting the kernel read-only data: 22528k
[ 6.875703] Freeing unused kernel image (rodata/data gap) memory: 1976K
[ 6.875829] rodata_test: all tests were successful
[ 6.875940] Run /init as init process
[ 6.876047] with arguments:
[ 6.876048] /init
[ 6.876048] with environment:
[ 6.876048] HOME=/
[ 6.876049] TERM=linux
[ 12.513740] loop0: detected capacity change from 0 to 1333928
[ 12.515685] loop1: detected capacity change from 0 to 355176
[ 12.646796] udevd[1762]: starting eudev-3.2.14
[ 12.655356] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input5
[ 12.655500] ACPI: button: Power Button [PWRB]
[ 12.655610] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input6
[ 12.659302] ACPI: video: Video Device [VGA] (multi-head: yes rom: no post: no)
[ 12.659404] ACPI: button: Power Button [PWRF]
[ 12.659624] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:20/LNXVIDEO:00/input/input7
[ 12.663722] Intel(R) 2.5G Ethernet Linux Driver
[ 12.663826] Copyright(c) 2018 Intel Corporation.
[ 12.663968] igc 0000:09:00.0: PCIe PTM not supported by PCIe bus/controller
[ 12.665707] BTRFS: device label pool-compute devid 1 transid 22 /dev/nvme0n1 (259:0) scanned by udevd (1788)
[ 12.666544] spl: loading out-of-tree module taints kernel.
[ 12.666980] Loading mpi3mr version 8.12.0.0.50
[ 12.667401] mpi3mr0: mpi3mr_probe :host protection capabilities enabled DIF1 DIF2 DIF3
[ 12.672736] BTRFS: device label pool-compute devid 2 transid 22 /dev/nvme3n1 (259:1) scanned by udevd (1782)
[ 12.674521] mpi3mr0: iomem(0x000000fcf0000000), mapped(0x00000000d9154efa), size(16384)
[ 12.674637] mpi3mr0: Number of MSI-X vectors found in capabilities: (128)
[ 12.674977] mpi3mr0: ioc_status(0x00000011), ioc_config(0x00470001), ioc_info(0x00000000ff000000) at the bringup
[ 12.675315] mpi3mr0: ready timeout: 510 seconds
[ 12.675657] mpi3mr0: controller is in ready state during detection
[ 12.676001] mpi3mr0: issuing message unit reset (MUR) to bring to reset state
[ 12.676116] mpi3mr0: Issuing Message unit Reset(MUR)
[ 12.676142] ACPI: bus type thunderbolt registered
[ 12.676643] ccp 0000:6c:00.2: enabling device (0000 → 0002)
[ 12.677998] ccp 0000:6c:00.2: tee enabled
[ 12.678263] ccp 0000:6c:00.2: psp enabled
[ 12.680160] Linux agpgart interface v0.103
[ 12.691655] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0
[ 12.691751] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 12.691755] piix4_smbus 0000:00:14.0: Using register 0x02 for SMBus port selection
[ 12.692407] i2c i2c-0: Successfully instantiated SPD at 0x50
[ 12.693098] i2c i2c-0: Successfully instantiated SPD at 0x51
[ 12.693153] Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 12.693388] Loaded X.509 cert ‘wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600’
[ 12.693788] i2c i2c-0: Successfully instantiated SPD at 0x52
[ 12.694398] i2c i2c-0: Successfully instantiated SPD at 0x53
[ 12.694518] piix4_smbus 0000:00:14.0: Auxiliary SMBus Host Controller at 0xb20
[ 12.705180] atlantic: Detect ATL2FW 1030018
[ 12.705843] RAPL PMU: API unit is 2^-32 Joules, 1 fixed counters, 163840 ms ovfl timer
[ 12.705952] RAPL PMU: hw unit of domain package 2^-16 Joules
[ 12.714431] ACPI: bus type drm_connector registered
[ 12.714900] asus-ec-sensors asus-ec-sensors: board has 5 EC sensors that span 5 registers
[ 12.715327] cryptd: max_cpu_qlen set to 1000
[ 12.719154] AES CTR mode by8 optimization enabled
[ 12.726682] igc 0000:09:00.0 (unnamed net_device) (uninitialized): PHC added
[ 12.729379] tpm_crb MSFT0101:00: Disabling hwrng
[ 12.743151] mt7921e 0000:08:00.0: enabling device (0000 → 0002)
[ 12.753492] igc 0000:09:00.0: 4.000 Gb/s available PCIe bandwidth (5.0 GT/s PCIe x1 link)
[ 12.753613] igc 0000:09:00.0 eth1: MAC: e8:9c:25:79:14:b7
[ 12.754369] mt7921e 0000:08:00.0: ASIC revision: 79220010
[ 12.782584] mpi3mr0: Base IOC Sts/Config after successful MUR is (0x10)/(0x470000)
[ 12.782946] mpi3mr0: bringing controller to ready state
[ 12.782968] zfs: module license ‘CDDL’ taints kernel.
[ 12.783166] Disabling lock debugging due to kernel taint
[ 12.783274] zfs: module license taints kernel.
[ 12.786292] kvm_amd: TSC scaling supported
[ 12.786411] kvm_amd: Nested Virtualization enabled
[ 12.786506] kvm_amd: Nested Paging enabled
[ 12.786598] kvm_amd: LBR virtualization supported
[ 12.786693] kvm_amd: Virtual VMLOAD VMSAVE supported
[ 12.786783] kvm_amd: Virtual GIF supported
[ 12.786870] kvm_amd: Virtual NMI enabled
[ 12.828644] mt7921e 0000:08:00.0: HW/SW Version: 0x8a108a10, Build Time: 20251020143135a
[ 12.842675] mt7921e 0000:08:00.0: WM Firmware Version: ____000000, Build Time: 20251020143225
[ 12.886593] mpi3mr0: successfully transitioned to ready state
[ 12.889032] mpi3mr0: IOCFactsdata length mismatch driver_sz(112) firmware_sz(104)
[ 12.889317] mpi3mr0: ioc_num(0), maxopQ(127), maxopRepQ(127), maxdh(1023),
[ 12.889318] mpi3mr0: maxreqs(8192), mindh(1) maxvectors(128) maxperids(1024)
[ 12.889516] mpi3mr0: SGEModMask 0x80 SGEModVal 0x80 SGEModShift 0x18
[ 12.889517] mpi3mr0: DMA mask 63 InitialPE status 0x20 max_data_len (1048576)
[ 12.889697] mpi3mr0: max_dev_per_throttle_group(0), max_throttle_groups(0)
[ 12.889788] mpi3mr0: io_throttle_data_len(0KiB), io_throttle_high(0MiB), io_throttle_low(0MiB)
[ 12.889883] mpi3mr0: Changing DMA mask from 0xffffffffffffffff to 0x7fffffffffffffff
[ 12.890522] mpi3mr0: Running in Enhanced HBA Personality
[ 12.890523] mpi3mr0: FW version(8.1.1.0.0.1)
[ 12.890745] mpi3mr0: Protocol=(Initiator,NVMe attachment), Capabilities=(RAID,MultiPath)
[ 12.897037] mpi3mr0: number of sgl entries=256 chain buffer size=4KB
[ 12.897735] mpi3mr0: reply buf pool(0x000000008bbcf49e): depth(8256), frame_size(128), pool_size(1032 kB), reply_dma(0x15c800000)
[ 12.897862] mpi3mr0: reply_free_q pool(0x00000000c19ff262): depth(8257), frame_size(8), pool_size(64 kB), reply_dma(0x15bfe0000)
[ 12.897962] mpi3mr0: sense_buf pool(0x00000000ff7dce2e): depth(2730), frame_size(256), pool_size(682 kB), sense_dma(0x15cc00000)
[ 12.898074] mpi3mr0: sense_buf_q pool(0x00000000b8744e03): depth(2731), frame_size(8), pool_size(21 kB), sense_dma(0x15bd60000)
[ 12.901013] mpi3mr0: firmware package version(8.1.1.0.00000-00001)
[ 12.901940] mpi3mr0: MSI-X vectors supported: 128, no of cores: 32,
[ 12.901941] mpi3mr0: MSI-x vectors requested: 33 poll_queues 0
[ 12.920496] mpi3mr0: trying to create 32 operational queue pairs
[ 12.920614] mpi3mr0: allocating operational queues through segmented queues
[ 12.950054] mpi3mr0: successfully created 32 operational queue pairs(default/polled) queue = (32/0)
[ 12.951899] mpi3mr0: controller initialization completed successfully
[ 12.952027] scsi host13: MPI3 Storage Controller
[ 12.952598] mpi3mr0: mpi3mr_scan_start :Issuing Port Enable
[ 12.988363] mpi3mr0: port enable is successfully completed
[ 13.014237] scsi 13:0:35:0: Direct-Access ATA WDC WUH722222AL W730 PQ: 0 ANSI: 7
[ 13.113953] scsi 13:0:35:0: Power-on or device reset occurred
[ 13.143953] ZFS: Loaded module v2.3.4-1, ZFS pool version 5000, ZFS filesystem version 5
[ 13.162928] sd 13:0:35:0: Attached scsi generic sg5 type 0
[ 13.167838] sd 13:0:35:0: [sdf] 42970644480 512-byte logical blocks: (22.0 TB/20.0 TiB)
[ 13.168059] sd 13:0:35:0: [sdf] 4096-byte physical blocks
[ 13.177020] sd 13:0:35:0: [sdf] Write Protect is off
[ 13.177256] sd 13:0:35:0: [sdf] Mode Sense: 6b 00 10 08
[ 13.185800] sd 13:0:35:0: [sdf] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 13.249313] scsi 13:0:36:0: Direct-Access ATA WDC WUH722222AL W730 PQ: 0 ANSI: 7
[ 13.350237] scsi 13:0:36:0: Power-on or device reset occurred
[ 13.352168] sd 13:0:36:0: Attached scsi generic sg6 type 0
[ 13.356829] sd 13:0:36:0: [sdg] 42970644480 512-byte logical blocks: (22.0 TB/20.0 TiB)
[ 13.356961] sd 13:0:36:0: [sdg] 4096-byte physical blocks
[ 13.366616] sd 13:0:36:0: [sdg] Write Protect is off
[ 13.366745] sd 13:0:36:0: [sdg] Mode Sense: 6b 00 10 08
[ 13.375117] sd 13:0:36:0: [sdg] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 13.382012] scsi 13:0:37:0: Direct-Access ATA WDC WUH722222AL W730 PQ: 0 ANSI: 7
[ 13.481089] scsi 13:0:37:0: Power-on or device reset occurred
[ 13.530516] sd 13:0:37:0: Attached scsi generic sg7 type 0
[ 13.535145] sd 13:0:37:0: [sdh] 42970644480 512-byte logical blocks: (22.0 TB/20.0 TiB)
[ 13.535277] sd 13:0:37:0: [sdh] 4096-byte physical blocks
[ 13.539532] scsi 13:0:38:0: Direct-Access ATA WDC WUH722222AL W730 PQ: 0 ANSI: 7
[ 13.544155] sd 13:0:37:0: [sdh] Write Protect is off
[ 13.544286] sd 13:0:37:0: [sdh] Mode Sense: 6b 00 10 08
[ 13.552539] sd 13:0:37:0: [sdh] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 13.637478] scsi 13:0:38:0: Power-on or device reset occurred
[ 13.639376] sd 13:0:38:0: Attached scsi generic sg8 type 0
[ 13.643991] sd 13:0:38:0: [sdi] 42970644480 512-byte logical blocks: (22.0 TB/20.0 TiB)
[ 13.644128] sd 13:0:38:0: [sdi] 4096-byte physical blocks
[ 13.648491] scsi 13:0:34:0: Direct-Access ATA WDC WUH722222AL W730 PQ: 0 ANSI: 7
[ 13.652933] sd 13:0:38:0: [sdi] Write Protect is off
[ 13.653066] sd 13:0:38:0: [sdi] Mode Sense: 6b 00 10 08
[ 13.661300] sd 13:0:38:0: [sdi] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 13.747678] scsi 13:0:34:0: Power-on or device reset occurred
[ 13.749310] sd 13:0:34:0: Attached scsi generic sg9 type 0
[ 13.753998] sd 13:0:34:0: [sdj] 42970644480 512-byte logical blocks: (22.0 TB/20.0 TiB)
[ 13.754157] sd 13:0:34:0: [sdj] 4096-byte physical blocks
[ 13.758387] scsi 13:0:33:0: Direct-Access ATA WDC WUH722222AL W730 PQ: 0 ANSI: 7
[ 13.762948] sd 13:0:34:0: [sdj] Write Protect is off
[ 13.763098] sd 13:0:34:0: [sdj] Mode Sense: 6b 00 10 08
[ 13.771322] sd 13:0:34:0: [sdj] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 13.856662] scsi 13:0:33:0: Power-on or device reset occurred
[ 13.858270] sd 13:0:33:0: Attached scsi generic sg10 type 0
[ 13.862838] sd 13:0:33:0: [sdk] 42970644480 512-byte logical blocks: (22.0 TB/20.0 TiB)
[ 13.862957] sd 13:0:33:0: [sdk] 4096-byte physical blocks
[ 13.867293] scsi 13:0:32:0: Direct-Access ATA WDC WUH722222AL W730 PQ: 0 ANSI: 7
[ 13.871792] sd 13:0:33:0: [sdk] Write Protect is off
[ 13.871923] sd 13:0:33:0: [sdk] Mode Sense: 6b 00 10 08
[ 13.880123] sd 13:0:33:0: [sdk] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 13.914345] intel_rapl_common: Found RAPL domain package
[ 13.914468] intel_rapl_common: Found RAPL domain core
[ 13.914646] [drm] amdgpu kernel modesetting enabled.
[ 13.915389] EDAC MC: Ver: 3.0.0
[ 13.917231] amdgpu: Virtual CRAT table created for CPU
[ 13.917382] amdgpu: Topology: Add CPU node
[ 13.917591] amdgpu 0000:6c:00.0: enabling device (0006 → 0007)
[ 13.917721] [drm] initializing kernel modesetting (IP DISCOVERY 0x1002:0x13C0 0x1043:0x8877 0xC1).
[ 13.917869] [drm] register mmio base: 0xDDB00000
[ 13.918009] [drm] register mmio size: 524288
[ 13.919639] [drm] add ip block number 0 <nv_common>
[ 13.919757] [drm] add ip block number 1 <gmc_v10_0>
[ 13.919866] [drm] add ip block number 2 <navi10_ih>
[ 13.919972] [drm] add ip block number 3
[ 13.920076] [drm] add ip block number 4
[ 13.920178] [drm] add ip block number 5
[ 13.920278] [drm] add ip block number 6 <gfx_v10_0>
[ 13.920381] [drm] add ip block number 7 <sdma_v5_2>
[ 13.920479] [drm] add ip block number 8 <vcn_v3_0>
[ 13.920575] [drm] add ip block number 9 <jpeg_v3_0>
[ 13.920674] amdgpu 0000:6c:00.0: amdgpu: Fetched VBIOS from VFCT
[ 13.920777] amdgpu: ATOM BIOS: 102-RAPHAEL-008
[ 13.953581] Console: switching to colour dummy device 80x25
[ 13.953609] amdgpu 0000:6c:00.0: vgaarb: deactivate vga console
[ 13.953612] amdgpu 0000:6c:00.0: amdgpu: Trusted Memory Zone (TMZ) feature disabled as experimental (default)
[ 13.953635] [drm] vm size is 262144 GB, 4 levels, block size is 9-bit, fragment size is 9-bit
[ 13.953639] amdgpu 0000:6c:00.0: amdgpu: VRAM: 2048M 0x000000F400000000 - 0x000000F47FFFFFFF (2048M used)
[ 13.953641] amdgpu 0000:6c:00.0: amdgpu: GART: 1024M 0x0000000000000000 - 0x000000003FFFFFFF
[ 13.953647] [drm] Detected VRAM RAM=2048M, BAR=2048M
[ 13.953648] [drm] RAM width 128bits DDR5
[ 13.953742] [drm] amdgpu: 2048M of VRAM memory ready
[ 13.953744] [drm] amdgpu: 63223M of GTT memory ready.
[ 13.953756] [drm] GART: num cpu pages 262144, num gpu pages 262144
[ 13.953846] [drm] PCIE GART of 1024M enabled (table at 0x000000F47FC00000).
[ 13.954048] [drm] Loading DMUB firmware via PSP: version=0x05002C00
[ 13.954227] [drm] use_doorbell being set to: [true]
[ 13.954237] [drm] Found VCN firmware Version ENC: 1.33 DEC: 4 VEP: 0 Revision: 13
[ 13.967184] scsi 13:0:32:0: Power-on or device reset occurred
[ 13.968727] sd 13:0:32:0: Attached scsi generic sg11 type 0
[ 13.973408] sd 13:0:32:0: [sdl] 42970644480 512-byte logical blocks: (22.0 TB/20.0 TiB)
[ 13.973410] sd 13:0:32:0: [sdl] 4096-byte physical blocks
[ 13.976038] sdh: sdh1
[ 13.976066] sd 13:0:37:0: [sdh] Attached SCSI disk
[ 13.976265] amdgpu 0000:6c:00.0: amdgpu: reserve 0xa00000 from 0xf47e000000 for PSP TMR
[ 13.977981] scsi 13:0:31:0: Direct-Access ATA WDC WUH722222AL W730 PQ: 0 ANSI: 7
[ 13.978290] sdi: sdi1
[ 13.978321] sd 13:0:38:0: [sdi] Attached SCSI disk
[ 13.979163] sdf: sdf1
[ 13.979195] sd 13:0:35:0: [sdf] Attached SCSI disk
[ 13.979485] sdj: sdj1
[ 13.979509] sd 13:0:34:0: [sdj] Attached SCSI disk
[ 13.982318] sd 13:0:32:0: [sdl] Write Protect is off
[ 13.982320] sd 13:0:32:0: [sdl] Mode Sense: 6b 00 10 08
[ 13.984296] sdk: sdk1
[ 13.984322] sd 13:0:33:0: [sdk] Attached SCSI disk
[ 13.990399] sd 13:0:32:0: [sdl] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 13.994457] sdg: sdg1
[ 13.994488] sd 13:0:36:0: [sdg] Attached SCSI disk
[ 14.038454] amdgpu 0000:6c:00.0: amdgpu: RAS: optional ras ta ucode is not available
[ 14.044352] amdgpu 0000:6c:00.0: amdgpu: RAP: optional rap ta ucode is not available
[ 14.044354] amdgpu 0000:6c:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
[ 14.045799] amdgpu 0000:6c:00.0: amdgpu: SMU is initialized successfully!
[ 14.045801] [drm] Seamless boot condition check passed
[ 14.046775] [drm] Display Core v3.2.301 initialized on DCN 3.1.5
[ 14.046777] [drm] DP-HDMI FRL PCON supported
[ 14.047539] [drm] DMUB hardware initialized: version=0x05002C00
[ 14.076829] [drm] kiq ring mec 2 pipe 1 q 0
[ 14.079681] scsi 13:0:31:0: Power-on or device reset occurred
[ 14.079848] kfd kfd: amdgpu: Allocated 3969056 bytes on gart
[ 14.079855] kfd kfd: amdgpu: Total number of KFD nodes to be created: 1
[ 14.079987] amdgpu: Virtual CRAT table created for GPU
[ 14.080707] amdgpu: Topology: Add dGPU node [0x13c0:0x1002]
[ 14.080709] kfd kfd: amdgpu: added device 1002:13c0
[ 14.080716] amdgpu 0000:6c:00.0: amdgpu: SE 1, SH per SE 1, CU per SH 2, active_cu_number 2
[ 14.080718] amdgpu 0000:6c:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
[ 14.080720] amdgpu 0000:6c:00.0: amdgpu: ring gfx_0.1.0 uses VM inv eng 1 on hub 0
[ 14.080721] amdgpu 0000:6c:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 4 on hub 0
[ 14.080721] amdgpu 0000:6c:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 5 on hub 0
[ 14.080722] amdgpu 0000:6c:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 6 on hub 0
[ 14.080723] amdgpu 0000:6c:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 7 on hub 0
[ 14.080724] amdgpu 0000:6c:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 8 on hub 0
[ 14.080725] amdgpu 0000:6c:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 9 on hub 0
[ 14.080725] amdgpu 0000:6c:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 10 on hub 0
[ 14.080726] amdgpu 0000:6c:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 11 on hub 0
[ 14.080727] amdgpu 0000:6c:00.0: amdgpu: ring kiq_0.2.1.0 uses VM inv eng 12 on hub 0
[ 14.080728] amdgpu 0000:6c:00.0: amdgpu: ring sdma0 uses VM inv eng 13 on hub 0
[ 14.080729] amdgpu 0000:6c:00.0: amdgpu: ring vcn_dec_0 uses VM inv eng 0 on hub 8
[ 14.080730] amdgpu 0000:6c:00.0: amdgpu: ring vcn_enc_0.0 uses VM inv eng 1 on hub 8
[ 14.080731] amdgpu 0000:6c:00.0: amdgpu: ring vcn_enc_0.1 uses VM inv eng 4 on hub 8
[ 14.080731] amdgpu 0000:6c:00.0: amdgpu: ring jpeg_dec uses VM inv eng 5 on hub 8
[ 14.080908] amdgpu 0000:6c:00.0: amdgpu: Runtime PM not available
[ 14.081020] [drm] Initialized amdgpu 3.61.0 for 0000:6c:00.0 on minor 0
[ 14.081503] sd 13:0:31:0: Attached scsi generic sg12 type 0
[ 14.086046] sd 13:0:31:0: [sdm] 42970644480 512-byte logical blocks: (22.0 TB/20.0 TiB)
[ 14.086051] sd 13:0:31:0: [sdm] 4096-byte physical blocks
[ 14.086990] fbcon: amdgpudrmfb (fb0) is primary device
[ 14.087129] [drm] pre_validate_dsc:1622 MST_DSC dsc precompute is not needed
[ 14.090712] scsi 13:0:30:0: Direct-Access ATA WDC WUH722222AL W730 PQ: 0 ANSI: 7
[ 14.094775] sd 13:0:31:0: [sdm] Write Protect is off
[ 14.094777] sd 13:0:31:0: [sdm] Mode Sense: 6b 00 10 08
[ 14.095378] sdl: sdl1
[ 14.095402] sd 13:0:32:0: [sdl] Attached SCSI disk
[ 14.102929] sd 13:0:31:0: [sdm] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 14.190489] scsi 13:0:30:0: Power-on or device reset occurred
[ 14.192364] sd 13:0:30:0: Attached scsi generic sg13 type 0
[ 14.196926] sd 13:0:30:0: [sdn] 42970644480 512-byte logical blocks: (22.0 TB/20.0 TiB)
[ 14.196928] sd 13:0:30:0: [sdn] 4096-byte physical blocks
[ 14.196932] sdm: sdm1
[ 14.196954] sd 13:0:31:0: [sdm] Attached SCSI disk
[ 14.201243] scsi 13:0:29:0: Direct-Access ATA WDC WUH722222AL W730 PQ: 0 ANSI: 7
[ 14.205665] sd 13:0:30:0: [sdn] Write Protect is off
[ 14.205666] sd 13:0:30:0: [sdn] Mode Sense: 6b 00 10 08
[ 14.214027] sd 13:0:30:0: [sdn] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 14.302191] sdn: sdn1
[ 14.302249] sd 13:0:30:0: [sdn] Attached SCSI disk
[ 14.303193] MCE: In-kernel MCE decoding enabled.
[ 14.303724] scsi 13:0:29:0: Power-on or device reset occurred
[ 14.304401] EDAC MC0: Giving out device to module amd64_edac controller F1Ah_M40h: DEV 0000:00:18.3 (INTERRUPT)
[ 14.304403] EDAC amd64: F1Ah_M40h detected (node 0).
[ 14.304403] EDAC MC: UMC0 chip selects:
[ 14.304403] EDAC amd64: MC: 0: 16384MB 1: 16384MB
[ 14.304404] EDAC amd64: MC: 2: 16384MB 3: 16384MB
[ 14.304405] EDAC MC: UMC1 chip selects:
[ 14.304405] EDAC amd64: MC: 0: 16384MB 1: 16384MB
[ 14.304405] EDAC amd64: MC: 2: 16384MB 3: 16384MB
[ 14.305553] sd 13:0:29:0: Attached scsi generic sg14 type 0
[ 14.310446] sd 13:0:29:0: [sdo] 42970644480 512-byte logical blocks: (22.0 TB/20.0 TiB)
[ 14.310448] sd 13:0:29:0: [sdo] 4096-byte physical blocks
[ 14.314518] scsi 13:0:28:0: Direct-Access ATA WDC WUH722222AL W730 PQ: 0 ANSI: 7
[ 14.319232] sd 13:0:29:0: [sdo] Write Protect is off
[ 14.319233] sd 13:0:29:0: [sdo] Mode Sense: 6b 00 10 08
[ 14.324771] amdgpu 0000:6c:00.0: [drm] REG_WAIT timeout 1us * 100000 tries - optc31_disable_crtc line:145
[ 14.327567] sd 13:0:29:0: [sdo] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 14.407278] Console: switching to colour frame buffer device 480x135
[ 14.414270] scsi 13:0:28:0: Power-on or device reset occurred
[ 14.415186] sdo: sdo1
[ 14.415249] sd 13:0:29:0: [sdo] Attached SCSI disk
[ 14.416132] sd 13:0:28:0: Attached scsi generic sg15 type 0
[ 14.420862] sd 13:0:28:0: [sdp] 42970644480 512-byte logical blocks: (22.0 TB/20.0 TiB)
[ 14.420863] sd 13:0:28:0: [sdp] 4096-byte physical blocks
[ 14.425269] scsi 13:0:27:0: Direct-Access ATA WDC WUH722222AL W730 PQ: 0 ANSI: 7
[ 14.429323] sd 13:0:28:0: [sdp] Write Protect is off
[ 14.429324] sd 13:0:28:0: [sdp] Mode Sense: 6b 00 10 08
[ 14.437318] amdgpu 0000:6c:00.0: [drm] fb0: amdgpudrmfb frame buffer device
[ 14.437386] sd 13:0:28:0: [sdp] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 14.525929] scsi 13:0:27:0: Power-on or device reset occurred
[ 14.527828] sd 13:0:27:0: Attached scsi generic sg16 type 0
[ 14.531587] scsi 13:0:51:0: Enclosure BROADCOM VirtualSES 01 PQ: 0 ANSI: 7
[ 14.533852] sd 13:0:27:0: [sdq] 42970644480 512-byte logical blocks: (22.0 TB/20.0 TiB)
[ 14.533887] sd 13:0:27:0: [sdq] 4096-byte physical blocks
[ 14.535285] sdp: sdp1
[ 14.535326] sd 13:0:28:0: [sdp] Attached SCSI disk
[ 15.199748] sd 13:0:27:0: [sdq] Write Protect is off
[ 15.199780] sd 13:0:27:0: [sdq] Mode Sense: 6b 00 10 08
[ 15.344947] sd 13:0:27:0: [sdq] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 15.348992] scsi 13:0:51:0: Attached scsi generic sg17 type 13
[ 15.441626] sdq: sdq1
[ 15.441797] sd 13:0:27:0: [sdq] Attached SCSI disk
[ 15.459649] ses 13:0:51:0: Attached Enclosure device
[ 16.559704] igc 0000:09:00.0 eth1: PHC removed
[ 16.712279] atlantic: Detect ATL2FW 1030018
[ 16.716469] Intel(R) 2.5G Ethernet Linux Driver
[ 16.716471] Copyright(c) 2018 Intel Corporation.
[ 16.716524] igc 0000:09:00.0: PCIe PTM not supported by PCIe bus/controller
[ 16.744750] igc 0000:09:00.0 (unnamed net_device) (uninitialized): PHC added
[ 16.772143] igc 0000:09:00.0: 4.000 Gb/s available PCIe bandwidth (5.0 GT/s PCIe x1 link)
[ 16.772148] igc 0000:09:00.0 eth1: MAC: e8:9c:25:79:14:b7
[ 17.042363] MII link monitoring set to 100 ms
[ 17.142815] bond0: (slave eth0): Enslaving as a backup interface with a down link
[ 17.212056] bond0: (slave eth1): Enslaving as a backup interface with a down link
[ 17.228299] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 17.232302] br0: port 1(bond0) entered blocking state
[ 17.232307] br0: port 1(bond0) entered disabled state
[ 17.232310] bond0: entered allmulticast mode
[ 17.274962] bond0: entered promiscuous mode
[ 23.438718] atlantic 0000:0a:00.0 eth0: atlantic: link change old 0 new 1000
[ 23.470659] bond0: (slave eth0): link status definitely up, 1000 Mbps full duplex
[ 23.470668] bond0: (slave eth0): making interface the new active one
[ 23.470670] atlantic 0000:0a:00.0 eth0: entered promiscuous mode
[ 23.470747] atlantic 0000:0a:00.0 eth0: entered allmulticast mode
[ 23.470965] bond0: active interface up!
[ 23.471007] br0: port 1(bond0) entered blocking state
[ 23.471013] br0: port 1(bond0) entered forwarding state
[ 24.298274] 8021q: 802.1Q VLAN Support v1.8
[ 24.298285] 8021q: adding VLAN 0 to HW filter on device eth0
[ 24.298398] 8021q: adding VLAN 0 to HW filter on device bond0
[ 26.132282] NET: Registered PF_PACKET protocol family
[ 34.646529] md: unRAID driver 2.9.35 installed
[ 34.748474] mdcmd (1): import 0
[ 34.748481] mdcmd (2): import 29
[ 34.748485] mdcmd (3): import 1
[ 34.748488] mdcmd (4): import 2
[ 34.748492] mdcmd (5): import 3
[ 34.748495] mdcmd (6): import 4
[ 34.748498] mdcmd (7): import 5
[ 34.748501] mdcmd (8): import 6
[ 34.748504] mdcmd (9): import 7
[ 34.748507] mdcmd (10): import 8
[ 34.748511] mdcmd (11): import 9
[ 34.748514] mdcmd (12): import 10
[ 34.748518] mdcmd (13): import 11
[ 34.748521] mdcmd (14): import 12
[ 34.748562] mdcmd (15): import 13
[ 34.748564] mdcmd (16): import 14
[ 34.748567] mdcmd (17): import 15
[ 34.748569] mdcmd (18): import 16
[ 34.748572] mdcmd (19): import 17
[ 34.748574] mdcmd (20): import 18
[ 34.748577] mdcmd (21): import 19
[ 34.748579] mdcmd (22): import 20
[ 34.748582] mdcmd (23): import 21
[ 34.748584] mdcmd (24): import 22
[ 34.748587] mdcmd (25): import 23
[ 34.748589] mdcmd (26): import 24
[ 34.748592] mdcmd (27): import 25
[ 34.748595] mdcmd (28): import 26
[ 34.748597] mdcmd (29): import 27
[ 34.748600] mdcmd (30): import 28
[ 34.931344] nvme nvme1: using unchecked data buffer
lspci -k
root@MOUSEION:~# lspci -k
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Root Complex
Subsystem: ASUSTeK Computer Inc. Device 8877
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge IOMMU
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Dummy Host Bridge
00:01.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge GPP Bridge
Kernel driver in use: pcieport
00:01.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge GPP Bridge
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Dummy Host Bridge
00:02.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge GPP Bridge
00:02.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge GPP Bridge
00:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Dummy Host Bridge
00:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Dummy Host Bridge
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Internal GPP Bridge to Bus [C:A]
00:08.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Internal GPP Bridge to Bus [C:A]
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 71)
Kernel driver in use: piix4_smbus
Kernel modules: i2c_piix4
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Data Fabric; Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Data Fabric; Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Data Fabric; Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Data Fabric; Function 3
Kernel driver in use: k10temp
Kernel modules: k10temp
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Data Fabric; Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Data Fabric; Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Data Fabric; Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge Data Fabric; Function 7
01:00.0 Non-Volatile memory controller: Kingston Technology Company, Inc. KC3000/FURY Renegade NVMe SSD [E18] (rev 01)
Subsystem: Kingston Technology Company, Inc. KC3000/FURY Renegade NVMe SSD [E18]
Kernel driver in use: nvme
02:00.0 RAID bus controller: Broadcom / LSI Fusion-MPT 24GSAS/PCIe SAS40xx/41xx (rev 01)
Subsystem: Broadcom / LSI eHBA 9600-24i Tri-Mode Storage Adapter
Kernel driver in use: mpi3mr
Kernel modules: mpi3mr
03:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset PCIe Switch Upstream Port (rev 01)
Subsystem: ASMedia Technology Inc. Device 3328
04:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset PCIe Switch Downstream Port (rev 01)
04:08.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset PCIe Switch Downstream Port (rev 01)
04:0c.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset PCIe Switch Downstream Port (rev 01)
04:0d.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset PCIe Switch Downstream Port (rev 01)
05:00.0 Non-Volatile memory controller: Intel Corporation Optane NVME SSD P1600X Series
Subsystem: Intel Corporation Device 380a
06:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset PCIe Switch Upstream Port (rev 01)
07:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset PCIe Switch Downstream Port (rev 01)
07:01.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset PCIe Switch Downstream Port (rev 01)
07:02.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset PCIe Switch Downstream Port (rev 01)
07:03.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset PCIe Switch Downstream Port (rev 01)
07:04.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset PCIe Switch Downstream Port (rev 01)
07:08.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset PCIe Switch Downstream Port (rev 01)
07:0c.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset PCIe Switch Downstream Port (rev 01)
07:0d.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset PCIe Switch Downstream Port (rev 01)
08:00.0 Network controller: MEDIATEK Corp. MT7922 802.11ax PCI Express Wireless Network Adapter
Subsystem: Foxconn International, Inc. Device e0cd
Kernel driver in use: mt7921e
Kernel modules: mt7921e
09:00.0 Ethernet controller: Intel Corporation Ethernet Controller I225-V (rev 03)
DeviceName: Intel I225 2.5G LAN
Subsystem: ASUSTeK Computer Inc. Device 87d2
Kernel driver in use: igc
Kernel modules: igc
0a:00.0 Ethernet controller: Aquantia Corp. AQtion AQC113CS NBase-T/IEEE 802.3an Ethernet Controller [Antigua 10G] (rev 03)
DeviceName: AQC113 10G LAN
Subsystem: ASUSTeK Computer Inc. ProArt X570-CREATOR WIFI
Kernel driver in use: atlantic
Kernel modules: atlantic
0c:00.0 PCI bridge: Intel Corporation Thunderbolt 4 Bridge [Maple Ridge 4C 2020] (rev 02)
Subsystem: Device 87f6:1043
0d:00.0 PCI bridge: Intel Corporation Thunderbolt 4 Bridge [Maple Ridge 4C 2020] (rev 02)
0d:01.0 PCI bridge: Intel Corporation Thunderbolt 4 Bridge [Maple Ridge 4C 2020] (rev 02)
0d:02.0 PCI bridge: Intel Corporation Thunderbolt 4 Bridge [Maple Ridge 4C 2020] (rev 02)
0d:03.0 PCI bridge: Intel Corporation Thunderbolt 4 Bridge [Maple Ridge 4C 2020] (rev 02)
0e:00.0 USB controller: Intel Corporation Thunderbolt 4 NHI [Maple Ridge 4C 2020]
Kernel driver in use: thunderbolt
Kernel modules: thunderbolt
3a:00.0 USB controller: Intel Corporation Thunderbolt 4 USB Controller [Maple Ridge 4C 2020]
Kernel driver in use: xhci_hcd
66:00.0 Non-Volatile memory controller: Intel Corporation Optane NVME SSD P1600X Series
67:00.0 USB controller: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset USB 3.2 Controller (rev 01)
Subsystem: ASMedia Technology Inc. Device 1142
68:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset SATA Controller (rev 01)
Subsystem: ASMedia Technology Inc. Device 1062
Kernel driver in use: ahci
69:00.0 USB controller: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset USB 3.2 Controller (rev 01)
6a:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset SATA Controller (rev 01)
DeviceName: PROM21 SATA AHCI Controller
6b:00.0 Non-Volatile memory controller: Kingston Technology Company, Inc. FURY Renegade NVMe SSD [E18] (Heatsink) (rev 01)
Subsystem: Kingston Technology Company, Inc. FURY Renegade NVMe SSD [E18] (Heatsink)
6c:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Granite Ridge [Radeon Graphics] (rev c1)
Kernel driver in use: amdgpu
Kernel modules: amdgpu
6c:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Radeon High Definition Audio Controller
6c:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 19h PSP/CCP
Kernel driver in use: ccp
Kernel modules: ccp
6c:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge USB 3.1 xHCI
6c:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge USB 3.1 xHCI
6d:00.0 USB controller: Advanced Micro Devices, Inc. [AMD] Raphael/Granite Ridge USB 2.0 xHCI
ls -lh /sys/class/block/\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\*/device/driver /sys/class/block/\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\*/device/device/driver
root@MOUSEION:~# ls -lh /sys/class/block//device/driver /sys/class/block//device/device/driver
lrwxrwxrwx 1 root root 0 Nov 19 19:39 /sys/class/block/nvme0n1/device/device/driver → ../../../../bus/pci/drivers/nvme/
lrwxrwxrwx 1 root root 0 Nov 19 19:39 /sys/class/block/nvme1n1/device/device/driver → ../../../../../../bus/pci/drivers/nvme/
lrwxrwxrwx 1 root root 0 Nov 19 19:39 /sys/class/block/nvme2n1/device/device/driver → ../../../../../../../../bus/pci/drivers/nvme/
lrwxrwxrwx 1 root root 0 Nov 19 19:39 /sys/class/block/nvme3n1/device/device/driver → ../../../../bus/pci/drivers/nvme/
lrwxrwxrwx 1 root root 0 Nov 19 19:39 /sys/class/block/sda/device/driver → ../../../../../../../../../../../../bus/scsi/drivers/sd/
lrwxrwxrwx 1 root root 0 Nov 19 19:39 /sys/class/block/sdb/device/driver → ../../../../../../../../../../bus/scsi/drivers/sd/
lrwxrwxrwx 1 root root 0 Nov 19 19:39 /sys/class/block/sdc/device/driver → ../../../../../../../../../../bus/scsi/drivers/sd/
lrwxrwxrwx 1 root root 0 Nov 19 19:39 /sys/class/block/sdd/device/driver → ../../../../../../../../../../bus/scsi/drivers/sd/
lrwxrwxrwx 1 root root 0 Nov 19 19:39 /sys/class/block/sde/device/driver → ../../../../../../../../../../bus/scsi/drivers/sd/
lrwxrwxrwx 1 root root 0 Nov 19 19:39 /sys/class/block/sdf/device/driver → ../../../../../../../bus/scsi/drivers/sd/
lrwxrwxrwx 1 root root 0 Nov 19 19:39 /sys/class/block/sdg/device/driver → ../../../../../../../bus/scsi/drivers/sd/
lrwxrwxrwx 1 root root 0 Nov 19 19:39 /sys/class/block/sdh/device/driver → ../../../../../../../bus/scsi/drivers/sd/
lrwxrwxrwx 1 root root 0 Nov 19 19:39 /sys/class/block/sdi/device/driver → ../../../../../../../bus/scsi/drivers/sd/
lrwxrwxrwx 1 root root 0 Nov 19 19:39 /sys/class/block/sdj/device/driver → ../../../../../../../bus/scsi/drivers/sd/
lrwxrwxrwx 1 root root 0 Nov 19 19:39 /sys/class/block/sdk/device/driver → ../../../../../../../bus/scsi/drivers/sd/
lrwxrwxrwx 1 root root 0 Nov 19 19:39 /sys/class/block/sdl/device/driver → ../../../../../../../bus/scsi/drivers/sd/
lrwxrwxrwx 1 root root 0 Nov 19 19:39 /sys/class/block/sdm/device/driver → ../../../../../../../bus/scsi/drivers/sd/
lrwxrwxrwx 1 root root 0 Nov 19 19:39 /sys/class/block/sdn/device/driver → ../../../../../../../bus/scsi/drivers/sd/
lrwxrwxrwx 1 root root 0 Nov 19 19:39 /sys/class/block/sdo/device/driver → ../../../../../../../bus/scsi/drivers/sd/
lrwxrwxrwx 1 root root 0 Nov 19 19:39 /sys/class/block/sdp/device/driver → ../../../../../../../bus/scsi/drivers/sd/
lrwxrwxrwx 1 root root 0 Nov 19 19:39 /sys/class/block/sdq/device/driver → ../../../../../../../bus/scsi/drivers/sd/
Find above. Do note this was taken on Unraid. If that’s problematic I’ll install Debian properly.
Your post is missing the output for dmesg and lspci -k.
Apologies. Updated.
