IncusOS Starting, suddenly reboot
IncusOS resets right after “IncusOS is starting…” on ASUS RS500-E9-RS4 (Intel VMD + LSI SAS3008)
Hi everyone,
I’m trying to install IncusOS on an ASUS RS500-E9-RS4 server. Secure Boot and TPM are now configured correctly, but the system always resets shortly after showing IncusOS is starting..., before the installer gets anywhere. The same hardware has been running VMware ESXi without issues.
Any pointers on how to debug this further would be much appreciated.
Hardware
Component Details
Server ASUS RS500-E9-RS4 (motherboard Z11PR-D16-DC)
BIOS 6803 (latest, updated from 6701)
BMC ASMB9-iKVM 1.15.5 (latest)
CPU Intel Xeon Silver 4208 (Cascade Lake) × <1 or 2>
RAM 256 GB DDR4-2400
NVMe 2× TEAM TM8FPK002T 2 TB, in the onboard NVMe bays, behind Intel VMD (VMD0, CPU0, ports 1C/1D)
SAS/SATA ASUS PIKE II SAS3008 (Avago), firmware 16.00.13.00-IR, 2× Samsung PM893 480 GB (MZ7L3480)
NICs 2× Intel X722 1GbE (onboard), 2× Intel 82599 10GbE dual-port
TPM TPM 2.0, enabled <cleared before install: yes/no>
About VMD: The BIOS does not offer any option to disable Intel VMD (checked under Socket Configuration → IIO Configuration on both BIOS 6701 and 6803). The NVMe drives only show up under Advanced → Intel Virtual RAID on CPU as Non-RAID Physical Disks, and the regular NVMe Configuration page says No NVMe Device Found. No VROC RAID volume exists.
About the LSI controller: The two Samsung SSDs were in an IR RAID 1 volume used by ESXi. <Status: the RAID 1 volume has been deleted / still exists>.
  • IncusOS_202610202006 (USB image), written directly with dd (no Ventoy)
  • Target disk: <Samsung PM893 on the SAS3008 / not specified>
Firmware settings
  • CSM disabled, UEFI boot only
  • PCH SATA and sSATA set to AHCI
  • TPM 2.0 enabled
  • Secure Boot: Custom policy, User mode
    • PK: <IncusOS PK R1 / ASUS factory PK>
    • KEK: IncusOS KEK R1
    • db: IncusOS DB 2025 R1 + DB 2026 R1, plus Microsoft UEFI CA 2011 / 2023 (kept for the SAS3008 UEFI option ROM)
What happened along the way
  1. Setup Mode auto-enrollment did not happen. With the firmware in Setup Mode, IncusOS skipped key enrollment and printed SecureBoot is disabled. IncusOS will attempt to fall back to a less-secure boot logic.
  2. Manual enrollment: the AMI file browser only listed .efi files, so the keys were enrolled <via KeyTool.efi with .esl files / via BIOS with .cer files>.
  3. Before both DB keys were enrolled, systemd-boot failed with:
    Error loading EFI binary \EFI\Linux\IncusOS_202610202006.efi: Access denied
    This went away after enrolling KEK and both DB keys.
  4. Now the boot gets past systemd-boot, shows IncusOS is starting..., and then the machine resets after about <N> seconds. This happens every time, at the same point, before any installer output.
Tests done (all still reset)
  • Hid the NVMe root ports 1C/1D (Hide Port = Yes). Note that the VMD controller itself stays enabled.
  • Disabled VT-d.
  • Updated BIOS from 6701 to 6803.
BMC event log
No new SEL entries are logged at the time of the resets. There is one earlier CPU_CATERR sensor of type processor logged a IERR entry at <date/time>, which <does / does not> line up with an IncusOS boot attempt.
Questions
  1. Does the IncusOS initrd include the vmd driver? The NVMe drives are behind VMD and VMD can’t be turned off on this platform. I’m also planning to use these NVMe drives as Ceph OSDs, so IncusOS will need to see them.
  2. Is mpt3sas (LSI SAS3008, IR firmware) included and expected to work during early boot?
  3. Is there a way to get more verbose early-boot output (a debug image, serial console, or similar) so I can see why the system resets?
  4. Are there any known issues with Xeon Scalable (Purley / Cascade Lake) platforms with VMD enabled?
Thanks in advance!
202610202006 is from the daily channel, and as such is automatically published without any human checking of the resulting artifacts. Please re-try with the latest stable release, currently 202610161222.
More generally, it’s good that you’re getting to the “IncusOS is starting…” message, because that indicates you’ve at least got the basics covered. My first guess would be an incomplete or corrupted install media. Enough was written to start booting, but then during early boot an error occurs causing a kernel panic or something similar. So try re-writing your USB stick and see if that works.
If IncusOS itself encounters an error during early boot, after a 10 minute delay it will show a rotation of information about the system to assist with debugging.
Less likely is some sort of hardware issue. I will note that it looks like your CPU doesn’t support x86_64 v3, which is a baseline requirement for IncusOS. I don’t think we’ve yet switched over to a kernel that fully utilizes the extended architecture support, but that will be happening in the near future, too.
