[LONG FOR CLARITY]
We’ve been using KVM libvirt to provide virtualization in our dev, tst and stg environments.
While this has proven to be very stable and has worked for a long time, we would like to improve the speed at which we can
scafold these evironemnts up and down during our development and testing cycles.
As a start, I am trying to automate install and config of lxd containers on localhost for purposes of testing.
A complete system is far to complicated for any system admin to reconfigure manually in a short space of time.
So, ansible is being used to setup, configure and manage the complexities of the whole system so that we can reproduce a consistant
and predicatable system in a very short space of time.
For clarity of the steps I will post all the steps taken below.
While many requirements specified are defined as we expect the following two are not as required:
containers not using the ipv4 address specified to them
The ip addresses must be consistant so that:
a) ansible knows where to find each host
b) services on different hosts know were to find each other (e.g clustered services such as rabbit, redis, mariadb) -
cloud-init directives not beig executed on first launch
We need to have a user account that ansible can use over ssh
Both of these challenges may be just because of my lack of understanding, but they block me anyway after many hours research and testing.
So I am hoping somebody could enlighten me
Enviroment
$ cat /etc/lsb-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=18.04
DISTRIB_CODENAME=bionic
DISTRIB_DESCRIPTION="Ubuntu 18.04 LTS"
$ uname -a
Linux sean-wks 4.15.0-24-generic #26-Ubuntu SMP Wed Jun 13 08:44:47 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
$ ansible --version
ansible 2.5.1
config file = /etc/ansible/ansible.cfg
configured module search path = [u'/home/sean/.ansible/plugins/modules', u'/usr/share/ansible/plugins/modules']
ansible python module location = /usr/lib/python2.7/dist-packages/ansible
executable location = /usr/bin/ansible
python version = 2.7.15rc1 (default, Apr 15 2018, 21:51:34) [GCC 7.3.0]
$ lxd --version
3.0.1
$ apt-cache policy lxd
lxd:
Installed: 3.0.1-0ubuntu1~18.04.1
Candidate: 3.0.1-0ubuntu1~18.04.1
Version table:
*** 3.0.1-0ubuntu1~18.04.1 500
500 http://za.archive.ubuntu.com/ubuntu bionic-updates/main amd64 Packages
100 /var/lib/dpkg/status
3.0.0-0ubuntu4 500
500 http://za.archive.ubuntu.com/ubuntu bionic/main amd64 Packages
At the end of playbook everything passes so I can say it is not an ansible problem.
PLAY RECAP *********************************************************************************************
localhost : ok=12 changed=7 unreachable=0 failed=0
And we have 10 containers created in under a minute
$ lxc list --fast
| NAME | STATE | ARCHITECTURE | CREATED AT | PROFILES | TYPE |
| lxc0 | STOPPED | x86_64 | 2018/07/21 08:47 UTC | default | PERSISTENT |
| lxc1 | STOPPED | x86_64 | 2018/07/21 08:47 UTC | default | PERSISTENT |
| lxc2 | STOPPED | x86_64 | 2018/07/21 08:48 UTC | default | PERSISTENT |
| lxc3 | STOPPED | x86_64 | 2018/07/21 08:48 UTC | default | PERSISTENT |
| lxc4 | STOPPED | x86_64 | 2018/07/21 08:48 UTC | default | PERSISTENT |
| lxc5 | STOPPED | x86_64 | 2018/07/21 08:48 UTC | default | PERSISTENT |
| lxc6 | STOPPED | x86_64 | 2018/07/21 08:48 UTC | default | PERSISTENT |
| lxc7 | STOPPED | x86_64 | 2018/07/21 08:48 UTC | default | PERSISTENT |
| lxc8 | STOPPED | x86_64 | 2018/07/21 08:48 UTC | default | PERSISTENT |
| lxc9 | STOPPED | x86_64 | 2018/07/21 08:48 UTC | default | PERSISTENT |
The resulting containers look as follows:
$ lxc config show lxc0
image.architecture: amd64
image.description: ubuntu 16.04 LTS amd64 (release) (20180703)
image.label: release
image.os: ubuntu
image.release: xenial
image.serial: "20180703"
image.version: "16.04"
user.user-data: "#cloud-config\n\n# Update apt database on first boot\n# (ie run
apt-get update)\n\npackage_update: true\n\n# Upgrade the instance on first boot\n#
(ie run apt-get upgrade)\n\npackage_upgrade: true\n\n# Add netadmin user to the
system on first boot \n\nusers:\n- name: netadmin\n groups: [adm, audio, cdrom,
dialout, floppy, video, plugdev, dip, netdev, sudo]\n sudo: ALL=(ALL) NOPASSWD:ALL\n
\ passwd: <snip>hash password</snip>.\n
\ ssh_authorized_keys: <snip>pub key</snip>\n"
volatile.apply_template: create
volatile.base_image: f2228450779fee27020d6024af587379b8f51062c32a335327f2b028c924bfa1
volatile.eth0.hwaddr: 00:16:3e:4a:83:10
volatile.eth0.name: eth0
volatile.idmap.base: "0"
volatile.idmap.next: '[{"Isuid":true,"Isgid":false,"Hostid":231072,"Nsid":0,"Maprange":65536},{"Isuid":false,"Isgid":true,"Hostid":231072,"Nsid":0,"Maprange":65536}]'
volatile.last_state.idmap: '[{"Isuid":true,"Isgid":false,"Hostid":231072,"Nsid":0,"Maprange":65536},{"Isuid":false,"Isgid":true,"Hostid":231072,"Nsid":0,"Maprange":65536}]'
ipv4.address: 10.0.3.10
nictype: bridged
parent: lxdbr0
security.mac_filtering: "true"
We start a container to check if everything is as we expect:
Expect:
- lxc0 to be 10.0.3.10
- apt update && apt upgrade to have run
- netadmin exists
Results:
- FAILED
- FAILED
- FAILED
$ lxc start lxc0
$ lxc list
| lxc0 | RUNNING | 10.0.3.249 (eth0) | | PERSISTENT | 0 |
| lxc1 | STOPPED | | | PERSISTENT | 0 |
| lxc2 | STOPPED | | | PERSISTENT | 0 |
| lxc3 | STOPPED | | | PERSISTENT | 0 |
| lxc4 | STOPPED | | | PERSISTENT | 0 |
| lxc5 | STOPPED | | | PERSISTENT | 0 |
| lxc6 | STOPPED | | | PERSISTENT | 0 |
| lxc7 | STOPPED | | | PERSISTENT | 0 |
| lxc8 | STOPPED | | | PERSISTENT | 0 |
| lxc9 | STOPPED | | | PERSISTENT | 0 |
$ lxc exec lxc0 bash
root@lxc0:~#
root@lxc0:~# ip a
inet6 ::1/128 scope host
15: eth0@if16: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 00:16:3e:4a:83:10 brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet 10.0.3.249/24 brd 10.0.3.255 scope global eth0
inet6 fe80::216:3eff:fe4a:8310/64 scope link
root@lxc0:~# tail /var/log/apt/history.log
Start-Date: 2018-07-03 08:31:33
Commandline: apt-get --purge remove --assume-yes ^linux-.* linux-base+
Purge: linux-headers-generic:amd64 (4.4.0.130.136), linux-headers-4.4.0-130:amd64 (4.4.0-130.156), linux-headers-4.4.0-130-generic:amd64 (4.4.0-130.156), linux-virtual:amd64 (4.4.0.130.136), linux-image-4.4.0-130-generic:amd64 (4.4.0-130.156), linux-headers-virtual:amd64 (4.4.0.130.136), linux-image-virtual:amd64 (4.4.0.130.136)
End-Date: 2018-07-03 08:31:36
Start-Date: 2018-07-03 08:31:38
Commandline: apt-get --purge remove --assume-yes ^grub-.*
Purge: os-prober:amd64 (1.70ubuntu3.3), grub-common:amd64 (2.02~beta2-36ubuntu3.18), grub2-common:amd64 (2.02~beta2-36ubuntu3.18), ubuntu-server:amd64 (1.361.1), grub-legacy-ec2:amd64 (18.2-4-g05926e48-0ubuntu1~16.04.2), grub-pc:amd64 (2.02~beta2-36ubuntu3.18), grub-pc-bin:amd64 (2.02~beta2-36ubuntu3.18), grub-gfxpayload-lists:amd64 (0.7)
End-Date: 2018-07-03 08:31:43
root@lxc0:~# id -u netadmin
id: ‘netadmin’: no such user
root@lxc0:~#
Ansible tasks
# tasks file for ansible-testnet
- name: install lxd
apt: name={{ item }}
with_items:
- lxd
become: yes
# at lxd install the user was added to the lxd group
# change only takes effect after reboot or newgrp lxd is run
- name: ensure user is in group lxd
command: newgrp lxd
- name: check if lxd init already done
stat: path=/var/lib/lxd/storage-pools/default
register: lxd_present
- name: copy preseed script
copy: src=preseed.sh dest=/tmp/preseed.sh mode=0755
when: lxd_present.stat.exists == False
- name: execute preseed script
shell: /tmp/preseed.sh
- name: list contianers
command: lxc list --format csv
register: containers
- name: init containers
command: lxc init {{ item.distro }}:{{ item.release }}/{{ item.arch }} {{ item.hostname }}
when: item.hostname != "" and item.hostname not in containers.stdout
with_items: "{{ testnet_hosts }}"
- name: attach containers to network
command: lxc network attach lxdbr0 {{ item.hostname }} eth0
- name: configure containers address
command: lxc config device set {{ item.hostname }} eth0 ipv4.address {{ item.network }}.{{ item.count }}
- name: configure containers hwaddr
command: lxc config set {{ item.hostname }} volatile.eth0.hwaddr {{ item.mac }}
### prevent the container from ever changing its MAC address
### or forwarding traffic for any other MAC address (such as nesting
- name: configure mac filtering on containers
command: lxc config device set {{ item.hostname }} eth0 security.mac_filtering true
### use cloud-init directives to run commands or scripts at the
### first boot cycle when launched
- name: deploy cloud-init template
template: src=config.yml.j2 dest=/tmp/config.yml mode=0755
- name: provision launch
shell: lxc config set {{ item.hostname }} user.user-data - < /tmp/config.yml
preseed.sh
#!/bin/bash
cat <<EOF | lxd init --preseed
core.https_address: '[::]:8443'
core.trust_password: "12345678"
cluster: null
networks:
- config:
ipv4.address: 10.0.3.1/24
ipv4.nat: "true"
ipv6.address: none
managed: false
type: ""
storage_pools:
- config:
driver: btrfs
- config: {}
nictype: bridged
parent: lxdbr0
pool: default
EOF
cloud-init config.yml
#cloud-config
# (ie run apt-get update)
# (ie run apt-get upgrade)
# Add netadmin user to the system on first boot
users:
- name: {{ users_admin[0].username }}
groups: [adm, audio, cdrom, dialout, floppy, video, plugdev, dip, netdev, sudo]
passwd: {{ users_admin[0].password }}
ssh_authorized_keys: {{ users_admin[0].sshkey_pub }}
