I’m trying to get started with LXD and want to use an existing ZFS pool for these purposes. It’s located on a different disk than my host.
sudo lxd init
Do you want to configure a new storage pool (yes/no) [default=yes]?
Name of the storage backend to use (dir, zfs) [default=zfs]:
Create a new ZFS pool (yes/no) [default=yes]? no
Name of the existing ZFS pool or dataset: /mypool
Would you like LXD to be available over the network (yes/no) [default=no]?
Would you like stale cached images to be updated automatically (yes/no) [default=yes]?
Would you like to create a new network bridge (yes/no) [default=yes]? no
error: custom loop file locations are not supported
Any idea how to accomplish this? I also tried answering the first question with no, but then it doesn’t even query me about any existing ZFS pools.
Thanks! I’ve now given it the name (without leading /) and that worked. However, I had to empty the pool of any existing filesystems (which is fine, since I hadn’t started using them yet).
Can LXD Storage coexist with ZFS datasets I create myself in the root? e.g.:
mypool 2.02M 57.6G 192K none
// LXD
mypool/containers 192K 57.6G 192K none
mypool/custom 192K 57.6G 192K none
mypool/deleted 192K 57.6G 192K none
mypool/images 192K 57.6G 192K none
mypool/snapshots 192K 57.6G 192K none
// Would these be ok?
mypool/apples …
mypool/oranges …
