Consider the following setup:
I’ve a host with a directory at /data/shared that is mounted to VM1 and VM2 with this:
incus config device add VM1 shared disk source=/data/shared path=/mnt/shared shift=true
My goal is to have some system in place where if a file is written from the host on /data/shared then the VMs would pick on the changes via inotify (systemd path unit) and run some service.
I did some tests and it doesn’t seem to work at from the host to the VMs. However If I set the host to watch for file changes on the path and write something from a VM it works.
Is there any way to get inotify to work in both directions? Ideally I would even like to have VM2 write a file and have VM1 detect the change and run a service.
Thank you.
