Installing BigBlueButton with LXD
Table of Contents
- 1. Intro
- 2. Preparing the host
- 3. Creating the container
- 4. Networking
- 5. Installing BBB inside the container
- 6. Appendices
1. Intro
I have a Dedicated Server on hetzner.com and I want to install BigBlueButton. The latest stable release of BBB requires ubuntu:20.04, but I have installed on the server ubuntu:22.04 (the latest LTS release), because I want to install there some other applications as well (with docker). So, I’d like to use an LXC container for installing BBB.
For ease of installation, the script bbb-install.sh is recommended, and it seems to work well with a NAT-ed system too. So I don’t need to purchase an extra IP for the BBB container. The case with an extra IP is covered in this (deprecated) article.
The script that we use also installs a TURN server inside the BBB container itself, so we don’t need to install a TURN server on a separate container or machine (as we have done previously).
As mentioned in the introduction, we need to have a freshly installed ubuntu:22.04 on this machine.
2.1. Secure the server
I also install firewalld and fail2ban to protect the server from the attacks:
# install firewalld
apt install --yes firewalld
firewall-cmd --list-all
# firewall-cmd --permanent --zone=public --set-target=DROP
# firewall-cmd --reload
# install fail2ban
apt install --yes fail2ban
fail2ban-client status
fail2ban-client status sshd
Their default configuration is usually fine, so for the time being we don’t need to change anything.
2.2. Install LXD
To manage the LXC containers I use LXD. I install it like this:
apt install snapd
snap install lxd --channel=latest/stable
snap refresh lxd --channel=latest
snap list
lxc list
lxd init
The output from the last command looks like this:
Would you like to use LXD clustering? (yes/no) [default=no]:
Name of the storage backend to use (btrfs, dir, lvm, zfs, ceph) [default=zfs]: btrfs
Create a new BTRFS pool? (yes/no) [default=yes]:
Would you like to use an existing empty block device (e.g. a disk or partition)? (yes/no) [default=no]:
Size in GB of the new loop device (1GB minimum) [default=30GB]: 70
Would you like to create a new local network bridge? (yes/no) [default=yes]:
What should the new bridge be called? [default=lxdbr0]:
Would you like the LXD server to be available over the network? (yes/no) [default=no]:
Would you like stale cached images to be updated automatically? (yes/no) [default=yes]
Would you like a YAML "lxd init" preseed to be printed? (yes/no) [default=no]:
Almost all the answers here are the default ones. One of the answers that is different is this:
Name of the storage backend to use (btrfs, dir, lvm, zfs, ceph) [default=zfs]:btrfsI am using btrfs for the storage backend, because the BBB installation script needs to install Docker inside the container, and only this filesystem supports it efficiently.
2.3. Fix the firewall
For more details about this look at the corresponding appendix.
Any interface that is not explicitly added to a zone, is added to the default zone, which is the zone public. This zone is meant for the interfaces that are facing the public internet, so it is restricted. For example DHCP requests are blocked, and the containers cannot get an IP.
To fix this, we can add the bridge interface to the trusted zone, where everything is allowed:
firewall-cmd --zone=trusted --list-all
firewall-cmd --permanent --zone=trusted --add-interface=lxdbr0
We should also make sure that forwarding is enabled:
firewall-cmd --permanent --direct --add-rule \
ipv4 filter FORWARD 0 -j ACCEPT
firewall-cmd --direct --get-all-rules
The latest stable version of BBB requires ubuntu:20.04.
lxc launch images:ubuntu/20.04 bbb \
-c security.nesting=true \
-c security.syscalls.intercept.mknod=true \
-c security.syscalls.intercept.setxattr=true
lxc list
lxc list -c ns4t
lxc info bbb
lxc config show bbb
The configuration -c security.nesting=true is needed in order to run docker inside the container. However if the container is unprivileged it does not really have any security implications.
Similarly, the other two configuration options are needed so that docker can handle images efficiently.
4. Networking
The connection of our container to the network goes through the host, which serves as a gateway. So, the BigBlueButton server is behind NAT. In this case we should follow the instructions at: https://docs.bigbluebutton.org/admin/configure-firewall.html
In particular, we need to forward the UDP ports 16384-32768 (for FreeSWITCH) from the host to the bbb container, and the TCP ports 80 and 443. For the TURN server, we should also forward the UDP ports 32769-65535, as well as the ports 3478/tcp and 3478/udp.
This is easier if the container has a fixed IP (rather then a dynamic one, obtained from DHCP). So, first of all, let’s limit the range of DHCP for the lxdbr0 bridge, and then change the network configuration inside the container so that it has a fixed IP that is outside the DHCP range.
4.1. Limit the DHCP range
lxc network set lxdbr0 \
ipv4.dhcp.ranges 10.210.64.2-10.210.64.200
lxc network show lxdbr0
4.2. Set a fixed IP
Network configuration on ubuntu is managed by netplan.
lxc exec bbb -- bash
ip address
ip route
rm /etc/netplan/*.yaml
cat <<EOF > /etc/netplan/01-netcfg.yaml
network:
version: 2
ethernets:
dhcp4: no
addresses:
- 10.210.64.201/8
nameservers:
addresses: [8.8.8.8, 8.8.4.4]
routes:
- to: default
via: 10.210.64.1
EOF
netplan apply
ip address
ip route
ping 8.8.8.8
4.3. Forward ports
We can use the command lxc network forward to forward these ports to the internal IP of the BBB container:
HOST_IP=10.11.12.13 # the public IP of the host
CONTAINER_IP=10.210.64.201
lxc network forward create lxdbr0 $HOST_IP
lxc network forward port add lxdbr0 $HOST_IP tcp 3478 $CONTAINER_IP
lxc network forward port add lxdbr0 $HOST_IP udp 3478 $CONTAINER_IP
lxc network forward port add lxdbr0 $HOST_IP udp 16384-65535 $CONTAINER_IP
lxc network forward list lxdbr0
lxc network forward show lxdbr0 $HOST_IP
We can use netcat to test that ports are forwarded correctly. On the server run:
lxc exec bbb -- nc -u -l 17000
Outside the server run:
nc bbb.example.org 17000
We are assuming that
bbb.example.orgis resolved to the external IP of the server.
Every line that is typed outside the server should be displayed inside the server.
4.4. Forward the TCP ports 80 and 443
Forwarding these two ports is a bit more complex and cannot be done with the same method that was used above for the UDP ports. This is because these ports need to be used by other applications as well, beside BBB. We need to forward these ports to different applications or containers, based on the domain that is being used. We can use sniproxy for this.
apt install -y sniproxy
vim /etc/sniproxy.conf
killall sniproxy
service start sniproxy
ps ax | sniproxy
Make sure that the configuration file /etc/sniproxy.conf looks like this:
user daemon
pidfile /var/run/sniproxy.pid
error_log {
syslog daemon
priority notice
access_log {
filename /var/log/sniproxy/access.log
priority notice
listen 80 {
proto http
fallback localhost:8080
listen 443 {
proto tls
table {
bbb.example.org 10.210.64.201
We are using 10.210.64.201, which is the fixed IP of the bbb container.
If you want to install sniproxy in a docker container instead, see the corresponding appendix. I install it in a docker container because I usually install some other dockerized web applications in the same server.
5.1. Run the installation script
As recommended on the docs, before running the installation script, add first this line at /etc/hosts:
10.11.12.13 bbb.example.org
10.11.12.13is the external/public IP of the server.
echo "10.11.12.13 bbb.example.org" >> /etc/hosts
apt install -y wget gnupg2
wget http://ubuntu.bigbluebutton.org/repo/bigbluebutton.asc -O- | apt-key add -
wget -q https://ubuntu.bigbluebutton.org/bbb-install-2.6-turn.sh
chmod +x bbb-install-2.6-turn.sh
./bbb-install-2.6-turn.sh
./bbb-install-2.6-turn.sh -v focal-260 \
-s bbb.example.org -e info@example.org -g
5.2. Fix the services
If you run bbb-conf --status you will notice that bbb-html5-* services are not working. They can be fixed like this:
# Override /lib/systemd/system/freeswitch.service
mkdir /etc/systemd/system/freeswitch.service.d
cat <<EOF | tee /etc/systemd/system/freeswitch.service.d/override.conf
[Service]
CPUSchedulingPolicy=other
EOF
# override /usr/lib/systemd/system/bbb-html5-frontend@.service
mkdir /etc/systemd/system/bbb-html5-frontend@.service.d
cat <<EOF | tee /etc/systemd/system/bbb-html5-frontend@.service.d/override.conf
[Service]
EOF
# override /usr/lib/systemd/system/bbb-html5-backend@.service
mkdir /etc/systemd/system/bbb-html5-backend@.service.d
cat <<EOF | tee /etc/systemd/system/bbb-html5-backend@.service.d/override.conf
[Service]
EOF
systemctl daemon-reload
bbb-conf --restart
bbb-conf --status
(Thanks to this post.)
5.3. Add admins and users
docker exec greenlight-v2 \
bundle exec rake \
admin:create["Full Name 1","email1@example.org","Pass-123","username1"]
bundle exec rake \
user:create["Full Name 2","email2@example.org","Pass-234","username2"]
5.4. Updating
To update the system, create a script update.sh with a content like this:
#!/bin/bash -x
apt update
apt -y upgrade
cd $(dirname $0)
#wget -q https://ubuntu.bigbluebutton.org/bbb-install-2.6-turn.sh
#chmod +x bbb-install-2.6-turn.sh
./bbb-install-2.6-turn.sh -g \
-v focal-260 \
-s bbb.example.org \
-e info@example.org
6. Appendices
6.1. Fixing the firewall
If we create a test container, we will notice that the network in the container is not working:
lxc launch images:ubuntu/22.04 u22
lxc ls
lxc exec u22 -- ip addr
The container did not get an IP, as it normally should.
However, if you stop firewalld and restart the container, everything works fine.
systemctl status firewalld
systemctl stop firewalld
lxc restart u22
lxc ls
lxc exec u22 -- ping 8.8.8.8
systemctl start firewalld
By the way, IP forwarding should already be enabled in the kernel of the host:
sysctl net.ipv4.ip_forward cat /proc/sys/net/ipv4/ip_forwardIf it is not, enable it like this:
echo 'net.ipv4.ip_forward = 1' >> /etc/sysctl.conf sysctl -p
So the problem is that the firewall is not configured properly. Let’s fix it.
6.1.1. Add the bridge interface to the trusted zone
Let’s check that it is working:
lxc restart u22
lxc ls
6.1.2. Fix the FORWARD chain
If the ping is still not working, usually the problem is that forwarding is blocked. If you try iptables-save | head and see something like this: :FORWARD DROP [4:2508], it means that the policy for the FORWARD chain is DROP. Maybe it is set by Docker, if you have installed it.
You can make the default policy ACCEPT, like this: iptables -P FORWARD ACCEPT. However, the next time that the server will be rebooted, or firewalld restarted, you may loose this configuration.
A better way is to add a direct (explicit) rule with firewall-cmd, like this:
This will enable (ACCEPT) forwarding for all the interfaces, the current ones and the ones that will be created in the future. If this is not what you want, you can use more specific rules, like these:
firewall-cmd --permanent --direct --remove-rule \
ipv4 filter -i lxdbr0 FORWARD 0 -j ACCEPT
ipv4 filter -o lxdbr0 FORWARD 0 -j ACCEPT
6.1.3. Cleanup
Let’s test again and then remove the test container:
lxc stop u22
lxc rm u22
lxc ls
6.2. Installing sniproxy in a Docker container
Install Docker (if not already installed):
curl -fsSL https://get.docker.com -o get-docker.sh DRY_RUN=1 sh ./get-docker.sh sh ./get-docker.sh rm get-docker.sh -
Install docker-scripts:
apt install git make m4 highlight git clone \ https://gitlab.com/docker-scripts/ds \ /opt/docker-scripts/ds cd /opt/docker-scripts/ds/ make install -
Install sniproxy:
ds pull sniproxy ds init sniproxy @sniproxy cd /var/ds/sniproxy/ ds make -
Edit
etc/sniproxy.confand add a line like this on the default table:# if no table specified the default 'default' table is defined table { # . . . . . bbb.example.org 10.210.64.201 # . . . . . }We are using 10.210.64.201, which is the fixed IP of the bbb container.
Make sure that the lines
#table http_hostsand#table https_hostsare commented, so that the default table is used in both cases. -
We should also restart
sniproxyin order to reload the configuration file:cd /var/ds/sniproxy/ ds restart
