I managed to get my hands on one of the new NVIDIA dev boards - the jetson orin nano. I set it up with an sdcard as its main os disk, and a 4tb nvme drive as its heavy-lifting storage drive.
I would like to deploy a bunch of incus OCI images to it (jellyfin, sickchill), and I’ve added the requisite apt repositories so that I could get a base install of incus on it. Currently, the newest version of incus I can fetch out of apt appears to be 6.0.3. My objective is to see if I can get somethinglike jellyfin to take advantage of the onboard gpu cores!
Whats the best way to upgrade to the newest avaialble version (6.10, i think, since its the one with OCI support?) so that I do not step on myself in the future? I snooped around but was unable to find just a .deb file I could get, and the files on github are xz archives, so I wasn’t sure which way to go
any guidance here would be awesome!
