Instance shows some cpu cores as offline
I’ve got quite old IBM server m3450 m4
It has 192Gb RAM and two CPU E5-2630, summary 24 cores
I installed lxd on the server and started several instances(linux containers) with limits.cpu = 8, but instances shows some cores as offline(in htop) for example 4 active and 4 offline, or 2 active and 6 offline. Number of offline cores different after instance reboot.
But the most interesting is the problem affects only instances with redhat 9 clones(almalinux 9, rockylinux 9, oracle 9).
With ubuntu instances I haven’t have such problem.
I’ve tried different OS for host system(server) ubuntu 22.04 and rocky linux 9, result is the same: instances with redhat 9 clones show some cpu cores as offline(see screenshot).
But inside instance I can see all 8 cores:
# cat /sys/devices/system/cpu/online
1,5,8,13-16,20
Is it a bug?
I’ve noticed if I remove limits.cpu: “8” from profile all 24 cores become available in instance and no one offline, so bug is in option limits.cpu ?
Can you show the output of lscpu on the host and in the container?
I’ve started instance with limits.cpu: “16” and it has 5 offline cores, lscpu on the instance:
# lscpu
Architecture:            x86_64
  CPU op-mode(s):        32-bit, 64-bit
  Address sizes:         46 bits physical, 48 bits virtual
  Byte Order:            Little Endian
CPU(s):                  24
  On-line CPU(s) list:   0-2,4-6,9-11,14,17-22
  Off-line CPU(s) list:  3,7,8,12,13,15,16,23
Vendor ID:               GenuineIntel
  Model name:            Intel(R) Xeon(R) CPU E5-2630 0 @ 2.30GHz
    CPU family:          6
    Model:               45
    Thread(s) per core:  2
    Core(s) per socket:  6
    Socket(s):           2
    Stepping:            7
    CPU max MHz:         2800.0000
    CPU min MHz:         1200.0000
    BogoMIPS:            4600.05
    Flags:               fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon pebs bts re
                         p_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 cx16 xtpr pdcm pcid dca sse4_1 sse4_2 x2apic popcnt tsc_deadline_timer aes xs
                         ave avx lahf_lm epb pti ssbd ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid xsaveopt dtherm ida arat pln pts md_clear flush_l1d
Virtualization features:
  Virtualization:        VT-x
Caches (sum of all):
  L1d:                   384 KiB (12 instances)
  L1i:                   384 KiB (12 instances)
  L2:                    3 MiB (12 instances)
  L3:                    30 MiB (2 instances)
NUMA:
  NUMA node(s):          2
  NUMA node0 CPU(s):     0-5,12-17
  NUMA node1 CPU(s):     6-11,18-23
Vulnerabilities:
  Itlb multihit:         KVM: Mitigation: VMX disabled
  L1tf:                  Mitigation; PTE Inversion; VMX conditional cache flushes, SMT vulnerable
  Mds:                   Mitigation; Clear CPU buffers; SMT vulnerable
  Meltdown:              Mitigation; PTI
  Mmio stale data:       Unknown: No mitigations
  Retbleed:              Not affected
  Spec store bypass:     Mitigation; Speculative Store Bypass disabled via prctl and seccomp
  Spectre v1:            Mitigation; usercopy/swapgs barriers and __user pointer sanitization
  Spectre v2:            Mitigation; Retpolines, IBPB conditional, IBRS_FW, STIBP conditional, RSB filling, PBRSB-eIBRS Not affected
  Srbds:                 Not affected
  Tsx async abort:       Not affected
and htop screenshot
lspu on the host:
# lscpu
CPU(s):                  24
  On-line CPU(s) list:   0-23
    CPU family:          6
    Model:               45
    Socket(s):           2
    Stepping:            7
    BogoMIPS:            4600.05
NUMA:
  NUMA node(s):          2
Vulnerabilities:
  Srbds:                 Not affected
I’ve noticed the same problem on second server.
Second server has Ubuntu 22.04 host system and here is lscpu:
# lscpu
  Address sizes:         40 bits physical, 48 bits virtual
CPU(s):                  8
  On-line CPU(s) list:   0-7
  Model name:            Intel(R) Xeon(R) CPU           E5506  @ 2.13GHz
    CPU family:          6
    Model:               26
    Thread(s) per core:  1
    Core(s) per socket:  4
    Socket(s):           2
    Stepping:            5
    CPU max MHz:         2128,0000
    CPU min MHz:         1596,0000
    BogoMIPS:            4266.84
    Flags:               fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ht tm pbe syscall nx rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl
                          xtopology nonstop_tsc cpuid aperfmperf pni dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm dca sse4_1 sse4_2 popcnt lahf_lm pti ssbd ibrs ibpb stibp tpr_shadow vnmi flexpriority
                         ept vpid dtherm flush_l1d
  L1d:                   256 KiB (8 instances)
  L1i:                   256 KiB (8 instances)
  L2:                    2 MiB (8 instances)
  L3:                    8 MiB (2 instances)
NUMA:
  NUMA node(s):          2
  NUMA node0 CPU(s):     0,2,4,6
  NUMA node1 CPU(s):     1,3,5,7
Vulnerabilities:
  L1tf:                  Mitigation; PTE Inversion; VMX conditional cache flushes, SMT disabled
  Mds:                   Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
  Spectre v2:            Mitigation; Retpolines, IBPB conditional, IBRS_FW, STIBP disabled, RSB filling, PBRSB-eIBRS Not affected
  Srbds:                 Not affected
I created 3 containers(oracle 9) with limits.cpu: “6” and one of two containers has 2 offline cores out of six. Here lscpu for that container:
# lxc exec c3 lscpu
CPU(s):                  8
  On-line CPU(s) list:   0,1,4-7
  Off-line CPU(s) list:  2,3
    CPU family:          6
    Model:               26
    Socket(s):           2
    Stepping:            5
    CPU max MHz:         2128.0000
    CPU min MHz:         1596.0000
    BogoMIPS:            4266.84
NUMA:
  NUMA node(s):          2
Vulnerabilities:
  Srbds:                 Not affected
Any idea?
I figured it out, it looks like a bug in htop utility in redhat clones. When instance loaded 100%, on host system I can see all instance cores(16) are loded 100%. More over, running mpstat -P ALL 1 inside instance shows all cores corretly
Affected htop version is 3.2.2
We see this issue on Alpine linux as well. Htop 3.2.2 so unrelated to redhat but htop in general.
