Forbinn
(Leroy Vincent)
July 18, 2019, 8:37am
1
I have a little issue with Internet access inside a LXC container on a brand new server. Basically inside the container I can ping the host through the bridge but I cannot ping any external URL (e.g. 8.8.8.8). Also DNS name resolution works perfectly fine.
By using tcpdump I saw that the following output:
09:59:59.154470 IP 192.168.100.78 > 8.8.8.8: ICMP echo request, id 649, seq 0, length 64
10:00:00.155576 IP 192.168.100.78 > 8.8.8.8: ICMP echo request, id 649, seq 1, length 64
Has you can see the source IP is the address of the container not my public IP and I don’t know why.
I have the ip_forward flag enable (cat /proc/sys/net/ipv4/ip_forward → 1) and I have the MASQUERADE rule created by lxc-net.
# Generated by xtables-save v1.8.3 on Thu Jul 18 10:36:10 2019
*nat
:PREROUTING ACCEPT [0:0]
:INPUT ACCEPT [0:0]
:POSTROUTING ACCEPT [0:0]
:OUTPUT ACCEPT [0:0]
-A POSTROUTING -s 192.168.100.0/24 ! -d 192.168.100.0/24 -j MASQUERADE
COMMIT
# Completed on Thu Jul 18 10:36:10 2019
So if you have any idea about how I can resolve this issue, please tell me.
PS: I’m using lxc version 3.0.3 on a Debian 9 (and container is Debian 10)
tomp
(Thomas Parrott)
July 18, 2019, 11:20am
2
Which interface did you run tcpdump on?
Forbinn
(Leroy Vincent)
July 18, 2019, 11:42am
3
I run it on the public interface of my server (eno1). Here is the full command line used: tcpdump -i eno1 -n icmp
tomp
(Thomas Parrott)
July 18, 2019, 12:23pm
4
Can you paste the output of
iptables -L -v -n -t nat
Forbinn
(Leroy Vincent)
July 18, 2019, 12:25pm
5
Chain PREROUTING (policy ACCEPT 0 packets, 0 bytes)
pkts bytes target prot opt in out source destination
Chain INPUT (policy ACCEPT 0 packets, 0 bytes)
Chain POSTROUTING (policy ACCEPT 0 packets, 0 bytes)
0 0 MASQUERADE all -- * * 192.168.100.0/24 !192.168.100.0/24
Chain OUTPUT (policy ACCEPT 0 packets, 0 bytes)
# Warning: iptables-legacy tables present, use iptables-legacy to see them
tomp
(Thomas Parrott)
July 18, 2019, 12:29pm
6
@Forbinn thanks, all the packet counts are zero, have you recently reloaded them, can you try running your ping test again please.
Forbinn
(Leroy Vincent)
July 18, 2019, 12:31pm
7
Non I haven’t reloaded them. And even after running about 10 ping the result is still the same.
tomp
(Thomas Parrott)
July 18, 2019, 12:33pm
8
@Forbinn ok so thats pretty weird, seems like iptables isnt working correctly.
Can you show the output of iptables -L -v -n -t filter please.
tomp
(Thomas Parrott)
July 18, 2019, 12:34pm
9
Also, have you looked at the iptables-legacy comment at the bottom, could it be that this actual ruleset isnt being used?
Forbinn
(Leroy Vincent)
July 18, 2019, 12:36pm
10
Chain INPUT (policy ACCEPT 294K packets, 1082M bytes)
0 0 ACCEPT tcp -- lxc-bridge-nat * 0.0.0.0/0 0.0.0.0/0 tcp dpt:53
0 0 ACCEPT udp -- lxc-bridge-nat * 0.0.0.0/0 0.0.0.0/0 udp dpt:53
0 0 ACCEPT tcp -- lxc-bridge-nat * 0.0.0.0/0 0.0.0.0/0 tcp dpt:67
68 22352 ACCEPT udp -- lxc-bridge-nat * 0.0.0.0/0 0.0.0.0/0 udp dpt:67
237K 1079M f2b-recidive tcp -- * * 0.0.0.0/0 0.0.0.0/0
227K 1047M f2b-sshd tcp -- * * 0.0.0.0/0 0.0.0.0/0 multiport dports 22
Chain FORWARD (policy ACCEPT 0 packets, 0 bytes)
0 0 ACCEPT all -- * lxc-bridge-nat 0.0.0.0/0 0.0.0.0/0
94 7896 ACCEPT all -- lxc-bridge-nat * 0.0.0.0/0 0.0.0.0/0
0 0 f2b-recidive tcp -- * * 0.0.0.0/0 0.0.0.0/0
Chain OUTPUT (policy ACCEPT 271K packets, 23M bytes)
Chain f2b-sshd (1 references)
225K 1047M RETURN all -- * * 0.0.0.0/0 0.0.0.0/0
Chain f2b-recidive (2 references)
51 3060 REJECT all -- * * 51.77.254.207 0.0.0.0/0 reject-with icmp-port-unreachable
874 52624 REJECT all -- * * 106.75.71.124 0.0.0.0/0 reject-with icmp-port-unreachable
246 14760 REJECT all -- * * 51.75.23.87 0.0.0.0/0 reject-with icmp-port-unreachable
236K 1079M RETURN all -- * * 0.0.0.0/0 0.0.0.0/0
For the iptables-legacy I have looked at them (both filter and nat) and there are all empty.
iptables-legacy -L -v -n -t filter
Chain INPUT (policy ACCEPT 296K packets, 1082M bytes)
Chain FORWARD (policy ACCEPT 642 packets, 48504 bytes)
iptables-legacy -L -v -n -t nat
Chain PREROUTING (policy ACCEPT 61645 packets, 2302K bytes)
Chain INPUT (policy ACCEPT 59092 packets, 2146K bytes)
Chain OUTPUT (policy ACCEPT 3021 packets, 216K bytes)
Chain POSTROUTING (policy ACCEPT 3173 packets, 226K bytes)
Forbinn
(Leroy Vincent)
July 18, 2019, 1:04pm
11
Ho, I’m misread your comment on iptables-legacy. After adding the MASQUERADE rule using the iptables-legacy and not the actual iptable the system works perfectly fine. So thank you for your help.
However why is this the case ? And how can I make this work using the non-legacy system ?
tomp
(Thomas Parrott)
July 18, 2019, 3:50pm
12
@Forbinn Great!
Can I confirm that the original MASQUERADE rule was added by LXD and not yourself?
Forbinn
(Leroy Vincent)
July 18, 2019, 4:31pm
13
@tomp I confirm that the MASQUERADE rule is added by the lxc-net service. To be precise it is added by the script /usr/lib/x86_64-linux-gnu/lxc/lxc-net at line 110. BTW the problem also exists with IPv6 and can be resolved with the same technique.
tomp
(Thomas Parrott)
July 18, 2019, 4:54pm
14
@Forbinn OK so LXC is adding the rule using the correct iptables tool, which is then using iptables-nft , however your system still seems to be using the legacy iptables tables.
I would try moving all of your rules over to iptables-nft tables and then removing the old iptables-legacy tables (possibly unloading the modules too).
tomp
(Thomas Parrott)
July 18, 2019, 5:00pm
15
Forbinn
(Leroy Vincent)
July 20, 2019, 8:05am
16
Sorry for the late reply, I had quite a few issues with the module unloading. But after doing so, it now works perfectly. So thanks again @tomp
r1ckdu
(Rick)
June 12, 2023, 7:18pm
17
Maybe not the right place but I searched and found this. I also have the same issue - dns lookup works but i cannot ping anything outside.
The container uses a network called lxdbr0.
My container is setup to work in an ubuntu environment and has docker also installed.
What i can see in iptables with :
$ sudo iptables -L -v -n -t nat
52376 3420K DOCKER all -- * * 0.0.0.0/0 0.0.0.0/0 ADDRTYPE match dst-type LOCAL
26076 2634K DOCKER all -- * * 0.0.0.0/0 !127.0.0.0/8 ADDRTYPE match dst-type LOCAL
31 2014 MASQUERADE all -- * !docker0 172.17.0.0/16 0.0.0.0/0
0 0 MASQUERADE all -- * !br-e3bc089bb3d9 172.19.0.0/16 0.0.0.0/0
0 0 MASQUERADE all -- * !br-0b908a7dd82f 172.20.0.0/16 0.0.0.0/0
0 0 MASQUERADE all -- * !br-05a0c150a474 172.18.0.0/16 0.0.0.0/0
Chain DOCKER (2 references)
0 0 RETURN all -- docker0 * 0.0.0.0/0 0.0.0.0/0
0 0 RETURN all -- br-e3bc089bb3d9 * 0.0.0.0/0 0.0.0.0/0
0 0 RETURN all -- br-0b908a7dd82f * 0.0.0.0/0 0.0.0.0/0
0 0 RETURN all -- br-05a0c150a474 * 0.0.0.0/0 0.0.0.0/0
And iptables-legacy:
$ sudo iptables-legacy -L -v -n -t nat
Chain PREROUTING (policy ACCEPT 2718 packets, 302K bytes)
Chain INPUT (policy ACCEPT 1146 packets, 220K bytes)
Chain OUTPUT (policy ACCEPT 1567 packets, 145K bytes)
Chain POSTROUTING (policy ACCEPT 1557 packets, 141K bytes)
Interestingly lxdbr0 does not appear anywhere?
In lxc the network is setup like this:
$ lxc network show lxdbr0
ipv4.address: 10.187.231.1/24
ipv4.firewall: "false"
ipv4.nat: "true"
ipv6.address: none
ipv6.nat: "true"
type: bridge
- /1.0/instances/ncp-backup
- /1.0/profiles/default
managed: true
status: Created
locations:
- none
What do i need to do to get this to work? I did not find the command @Forbinn used to add MASQUERADE rule to his things… would be real nice to have some input on this! Also maybe @tomp might have an idea?
Thanks y’all!!!
r1ckdu
(Rick)
June 12, 2023, 7:40pm
18
Maybe this helps - i looked into this other issue here
and ran the grep suggestion
$ ps aux | grep dnsmasq
lxd 452486 0.0 0.0 7208 3632 ? Ss 18:34 0:00 dnsmasq --keep-in-foreground --strict-order --bind-interfaces --except-interface=lo --pid-file= --no-ping --interface=lxdbr0 --dhcp-rapid-commit --quiet-dhcp --quiet-dhcp6 --quiet-ra --listen-address=10.187.231.1 --dhcp-no-override --dhcp-authoritative --dhcp-leasefile=/var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.leases --dhcp-hostsfile=/var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.hosts --dhcp-range 10.187.231.2,10.187.231.254,1h -s lxd --interface-name _gateway.lxd,lxdbr0 -S /lxd/ --conf-file=/var/snap/lxd/common/lxd/networks/lxdbr0/dnsmasq.raw -u lxd -g lxd
The container has an ip and I can ping the host internally:
ping 10.187.231.1 takes like 0.01ms
also for ping 192.168.1.98 (external host ip)
pinging the router 192.168.1.1 of course does not work…
tomp
(Thomas Parrott)
June 13, 2023, 7:35am
19
