While setting the IOPS to a container running with the DIR backend, the IOPS restrictions seem to work.
Without IOPS config (DIR backend)
fio Disk Speed Tests (Mixed R/W 50/50):
Block Size | 4k (IOPS) | 64k (IOPS)
Read | 145.56 MB/s (36.3k) | 1.41 GB/s (22.1k)
Write | 145.94 MB/s (36.4k) | 1.42 GB/s (22.2k)
Total | 291.51 MB/s (72.8k) | 2.84 GB/s (44.4k)
Block Size | 512k (IOPS) | 1m (IOPS)
Read | 2.19 GB/s (4.2k) | 2.24 GB/s (2.1k)
Write | 2.31 GB/s (4.5k) | 2.39 GB/s (2.3k)
Total | 4.51 GB/s (8.8k) | 4.64 GB/s (4.5k)
DIR backend (with r/w IOPS set to 100)
Read | 378.00 KB/s (94) | 6.04 MB/s (94)
Write | 400.00 KB/s (100) | 6.40 MB/s (100)
Total | 778.00 KB/s (194) | 12.44 MB/s (194)
Read | 48.46 MB/s (94) | 69.72 MB/s (68)
Write | 51.32 MB/s (100) | 74.36 MB/s (72)
Total | 99.78 MB/s (194) | 144.08 MB/s (140)
DIR backend (with r/w IOPS set to 300)
Read | 1.16 MB/s (291) | 18.62 MB/s (291)
Write | 1.20 MB/s (300) | 19.20 MB/s (300)
Total | 2.36 MB/s (591) | 37.83 MB/s (591)
Read | 145.86 MB/s (284) | 161.23 MB/s (157)
Write | 153.61 MB/s (300) | 171.96 MB/s (167)
Total | 299.48 MB/s (584) | 333.19 MB/s (324)
As you can see, the results are satisfactory.
However, with ZFS as the backend the IOPS are very much identical no matter how low the IOPS limits are set to.
Without IOPS limit (ZFS backend)
Read | 95.29 MB/s (23.8k) | 448.65 MB/s (7.0k)
Write | 95.54 MB/s (23.8k) | 451.02 MB/s (7.0k)
Total | 190.83 MB/s (47.7k) | 899.67 MB/s (14.0k)
Read | 2.50 GB/s (4.9k) | 2.49 GB/s (2.4k)
Write | 2.64 GB/s (5.1k) | 2.65 GB/s (2.5k)
Total | 5.15 GB/s (10.0k) | 5.14 GB/s (5.0k)
ZFS backend r/w IOPS: 50/50
Read | 100.25 MB/s (25.0k) | 630.58 MB/s (9.8k)
Write | 100.52 MB/s (25.1k) | 633.90 MB/s (9.9k)
Total | 200.77 MB/s (50.1k) | 1.26 GB/s (19.7k)
Read | 2.64 GB/s (5.1k) | 2.39 GB/s (2.3k)
Write | 2.78 GB/s (5.4k) | 2.55 GB/s (2.4k)
Total | 5.42 GB/s (10.5k) | 4.94 GB/s (4.8k)
ZFS backend r/w IOPS: 100/100
Read | 100.36 MB/s (25.0k) | 398.71 MB/s (6.2k)
Write | 100.62 MB/s (25.1k) | 400.81 MB/s (6.2k)
Total | 200.99 MB/s (50.2k) | 799.52 MB/s (12.4k)
Read | 703.95 MB/s (1.3k) | 2.65 GB/s (2.5k)
Write | 741.35 MB/s (1.4k) | 2.83 GB/s (2.7k)
Total | 1.44 GB/s (2.8k) | 5.48 GB/s (5.3k)
Not sure why for ZFS it didn’t work. Any input?
