I would like to allow a connection from the internet to port 10022 (host) → 22 SSH to my container. The port from the internet should be 10022 because my host already uses tcp port 22 for ssh.
My current config for iptables is:
iptables -S
-P INPUT DROP
-P FORWARD DROP
-P OUTPUT DROP
-N f2b-sshd
-A INPUT -i lxdbr0 -p tcp -m tcp --dport 53 -m comment --comment "generated for LXD network lxdbr0" -j ACCEPT
-A INPUT -i lxdbr0 -p udp -m udp --dport 53 -m comment --comment "generated for LXD network lxdbr0" -j ACCEPT
-A INPUT -i lxdbr0 -p udp -m udp --dport 67 -m comment --comment "generated for LXD network lxdbr0" -j ACCEPT
-A INPUT -p tcp -m multiport --dports 22 -j f2b-sshd
-A INPUT -i lo -j ACCEPT
-A INPUT -s 127.0.0.0/8 -j DROP
-A INPUT -p tcp -m state --state ESTABLISHED -j ACCEPT
-A INPUT -p udp -m state --state ESTABLISHED -j ACCEPT
-A INPUT -p icmp -m state --state ESTABLISHED -j ACCEPT
-A INPUT -p tcp -m tcp --dport 22 -m state --state NEW -m set --match-set ipset_subnet-de src -j ACCEPT
-A INPUT -p tcp -m tcp --dport 22 -m state --state NEW -m set --match-set ipset_subnet-at src -j ACCEPT
-A INPUT -p tcp -m tcp --dport 22 -m state --state NEW -m set --match-set ipset_subnet-ch src -j ACCEPT
-A FORWARD -o lxdbr0 -m comment --comment "generated for LXD network lxdbr0" -j ACCEPT
-A FORWARD -i lxdbr0 -m comment --comment "generated for LXD network lxdbr0" -j ACCEPT
-A OUTPUT -o lxdbr0 -p tcp -m tcp --sport 53 -m comment --comment "generated for LXD network lxdbr0" -j ACCEPT
-A OUTPUT -o lxdbr0 -p udp -m udp --sport 53 -m comment --comment "generated for LXD network lxdbr0" -j ACCEPT
-A OUTPUT -o lxdbr0 -p udp -m udp --sport 67 -m comment --comment "generated for LXD network lxdbr0" -j ACCEPT
-A OUTPUT -o lo -j ACCEPT
-A OUTPUT -p tcp -m state --state NEW,ESTABLISHED -j ACCEPT
-A OUTPUT -p udp -m state --state NEW,ESTABLISHED -j ACCEPT
-A OUTPUT -p icmp -m state --state NEW,ESTABLISHED -j ACCEPT
-A f2b-sshd -j RETURN
Unfortunately I was not able to find an article that describes my requirement, especially not with the pre-defined rules "script comment generated for LXD network lxdbr0.
Before I create a mess and build a security hole I would like to ask if the rules for my requirements are correct ?
iptables -A FORWARD -i enp4s0 -d <container-ip> -p tcp --dport 22 -j ACCEPT
iptables -A FORWARD -i enp4s0 -j DROP
iptables -A FORWARD -i lxdbr0 -m state --state NEW,INVALID -j DROP
iptables -t nat -A PREROUTING -p tcp --dport 10022 -j DNAT --to <container-ip>:22
Is this correct or did I something completely stupid ?
What would be the correct way if I need fail2ban for port 10022 ?
Unfortunately I am completely lost. After hours and hours of testing, trying to narrow down the issue setting up things, reverting it I am not able to allow a connection. Even when I set a simple python webserver within the container listen on simple TCP 8080.
I found out that after I added the following line I am able to reach the webserver from the host to the container
Hi Marc,
If I catch the post correctly, you need to make a NAT connection on the host side with the iptable rules and make a proxy connection on the related container. On the container, lxc config device add container1 test10022 proxy listen=tcp:0.0.0.0:10022 connect=tcp:0.0.0.0:22
may work. But be sure, on the container you listen 0.0.0.0 not 127.0.0.1 on the ssh port.
I hope, that might give an idea.
Regards.
I mean, if you are behind the firewall/router then you just need to port forwarding to your host and then in the host just define the proxy could be enough. No need to NAT on the host again.
You can test flushing the iptables rules with the sudo iptables -F command on the host.
Regards.
If I understand you correct I don’t need a NAT rule if I use the "lxc config device add " command. I just need to allow iptables to allow connection to the host. Am I correct ?
Do I need to allow the connection to the host via INPUT or via FORWARD chain ?
Yes thats correct, first you can flush all the iptable rules (iptables -F) to make sure on the host then on the container define the proxy rule with the following command. lxc config device add container1 test10022 proxy listen=tcp:0.0.0.0:10022 connect=tcp:0.0.0.0:22
You dont need to do that rule/rules, just flush all the iptable rules and test it then you can make your firewall rules more persistent.
If I flush the rules I would have (depending on the default chain settings for input, output and forward) no iptables rule at all which means no service would be blocked or am I wrong ?
You can change chain policy from DROP to ACCEPT and test it with that state, but as I mentioned before you forward your port traffic from your router to host first.
Regards.
You need to make sure you don’t have a firewall on the host blocking inbound connections to port 1022 and that you have an SSH service listening on the 127.0.0.1 port 22 address inside the container.
This will use a separate proxy process to forwarding connections from the host to the container, and will allow it to listen on the wildcard (0.0.0.0) address on the host and connect to the loopback (127.0.0.1) address inside the container.
The downside of this approach is that your application will not see the remote IP that is connecting.
See Instances | LXD
The alternative is to use NAT mode by adding nat=true to the command above, which will then use iptables/nftables DNAT rules to, but this will require your instance’s NIC has a static IP, by setting ipv4.address on it, and you will need to specify a specific listen address rather than 0.0.0.0.
