pajot
(Stephen)
April 20, 2022, 12:59pm
1
I am trying to get IPv6 working on a Gentoo container that is inside a VPS running Ubuntu 20.04.
I have the following bridge configuration on the host:
$ lxc network show lxdbr0
ipv4.address: 10.23.21.1/24
ipv4.nat: "true"
ipv6.address: fd42:774b:2bac:da6::1/64
ipv6.dhcp.stateful: "true"
ipv6.nat: "true"
type: bridge
- /1.0/instances/equal-parakeet
- /1.0/profiles/default
managed: true
status: Created
locations:
- none
The container has an IPv6 address:
equal-parakeet $ ip a show dev eth0
4: eth0@if5: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 00:16:3e:fc:a6:28 brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet 10.23.21.100/24 brd 10.23.21.255 scope global eth0
inet6 fe80::216:3eff:fefc:a628/64 scope link
But this address does not appear in ‘lxc list’ output:
$ lxc list
| equal-parakeet | RUNNING | 10.23.21.100 (eth0) | | CONTAINER | 1 |
Why might this be?
tomp
(Thomas Parrott)
April 20, 2022, 1:45pm
2
Do you have a DHCPv6 stateful client running in your container?
tomp
(Thomas Parrott)
3
Why using ipv6.dhcp.stateful: "true" btw?
pajot
(Stephen)
April 20, 2022, 2:49pm
4
The container is a Gentoo container that uses dhclient to obtain an IPv4 address.
The configuration documentation doesn’t describe a way of differentiating between IPv4 and IPv6 (see Gentoo Linux amd64 Handbook: Network configuration ).
/etc/conf.d/net (in the container) contains
$ cat /etc/conf.d/net
config_eth0="dhcp"
I don’t know why ipv6.dhcp.stateful="true" is set, I don’t remember setting it, but you’d mentioned elsewhere that it is needed for IPv6 NAT. Have I misunderstood something?
tomp
(Thomas Parrott)
April 20, 2022, 2:54pm
5
If you don’t need it, then set it to false and use SLAAC instead.
Otherwise you’re going to need to ensure that your container’s OS is performing a DHCPv6 request (and that is likely different than DHCPv4 setup).
pajot
(Stephen)
April 20, 2022, 3:06pm
6
What do I need to do on the container to use SLAAC? (A generic answer that makes use of ’ip’ would sufficient…)
tomp
(Thomas Parrott)
April 20, 2022, 3:07pm
7
Probably nothing, it usually works out of the box once ipv6.dhcp.stateful="false"
pajot
(Stephen)
April 20, 2022, 3:19pm
8
Sure enough:
$ lxc network unset lxdbr0 ipv6.dhcp.stateful
ipv4.nat: "true"
ipv6.nat: "true"
type: bridge
managed: true
status: Created
locations:
- none
$ lxc list
| equal-parakeet | RUNNING | 10.23.21.100 (eth0) | fd42:774b:2bac:da6:216:3eff:fefc:a628 (eth0) | CONTAINER | 1 |
On the container:
equal-parakeet ~ $ LANG=C ping6 -c 4 wikipedia.org
PING wikipedia.org(text-lb.esams.wikimedia.org (2620:0:862:ed1a::1)) 56 data bytes
64 bytes from text-lb.esams.wikimedia.org (2620:0:862:ed1a::1): icmp_seq=1 ttl=58 time=9.29 ms
64 bytes from text-lb.esams.wikimedia.org (2620:0:862:ed1a::1): icmp_seq=2 ttl=58 time=9.29 ms
64 bytes from text-lb.esams.wikimedia.org (2620:0:862:ed1a::1): icmp_seq=3 ttl=58 time=9.47 ms
64 bytes from text-lb.esams.wikimedia.org (2620:0:862:ed1a::1): icmp_seq=4 ttl=58 time=9.23 ms
--- wikipedia.org ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3005ms
rtt min/avg/max/mdev = 9.228/9.319/9.471/0.091 ms
Thank you!
Now, given the above, two additional questions:
How do I allow the container to use the routable external IPv6 address from the host?
Can I set up IPv6 proxy devices just like the ones I use for passing IPv4 ports through from the host to the container?
tomp
(Thomas Parrott)
April 20, 2022, 3:25pm
9
tomp
(Thomas Parrott)
April 20, 2022, 3:28pm
10
This has been discussed a number of times on this forum, but the general approach with Hetzner’s /64 subnet is to pick a single IP at the start/end of the subnet, e.g. ::1 and assign that to the LXD host’s external interface as ...::1/128, then use lxc network set lxdbr0 ipv6.address=....::2/64 ipv6.nat=false.
pajot
(Stephen)
April 20, 2022, 4:39pm
11
Yes, I saw the Hetzner example. In my case only a single IP address is provided, and with a peculiar /48 subnet.
It’s a bit ridiculous, there’s no reason to be so miserly, but I suspect IPv4 thinking is being applied here. And capitalistic thinking
I thought that there might be a simple way to pass the whole IP address through to the container.
tomp
(Thomas Parrott)
April 20, 2022, 4:46pm
12
I don’t quite follow you, but if you want you can also use routed NIC type to pass specific IPv6 addresses without needing to configure a bridge.
See How to get LXD containers get IP from the LAN with routed network
tomp
(Thomas Parrott)
April 20, 2022, 4:47pm
13
Not sure what you mean, a /48 is made of of approx 65k /64, so there’s plenty to choose from, you can then just pick a /64 for your lxdbr0 subnet.
