xlmnxp
(Salem AlSaiari)
April 27, 2026, 8:09am
1
I have an Incus cluster where all nodes receive IPv6 via DHCPv6 Prefix Delegation (PD /96) on the default incusbr0 bridge. The problem is that each node gets a different /96 prefix from the DHCPv6 server, which causes two issues:
Instances on different nodes cannot reach each other directly over IPv6
I cannot live migrate instances between nodes since the IPv6 addressing changes
What is the best approach to solve this in an Incus cluster setup?
jochumdev
(René Jochum)
April 27, 2026, 8:52am
2
xlmnxp:
Are you sure about the server assigning prefixes?
Do you setup the node with incus admin init? If so you could paste a yaml (you can generate one with that) to have the same prefix on all nodes.
xlmnxp
(Salem AlSaiari)
April 30, 2026, 2:04pm
3
cluster.https_address: 192.168.0.101:8443
core.https_address: 192.168.0.101:8443
core.https_trusted_proxy: 127.0.0.1,192.168.0.101,192.168.0.3
oidc.audience: account
oidc.claim: email
oidc.client.id: incus
oidc.issuer: https://auth.sy.sa/realms/master
oidc.scopes: openid,profile,email
user.ui.sso_only: "true"
user.ui.title: Salem Infra
networks:
- config:
ipv4.address: 10.88.223.1/24
ipv4.nat: "true"
ipv6.address: 2001:678:1120:0:1:100:0:1/96
ipv6.dhcp: "true"
ipv6.dhcp.stateful: "true"
ipv6.nat: "false"
type: bridge
project: default
- config: {}
type: macvlan
project: default
storage_pools:
- config: {}
driver: dir
storage_volumes: []
- config: {}
network: macvlan
pool: local
project: ""
projects:
- config:
features.images: "true"
features.profiles: "true"
features.storage.buckets: "true"
features.storage.volumes: "true"
- config:
features.networks: "true"
features.networks.zones: "true"
description: Default Incus project
certificates: []
cluster_groups: []
nodes subnets are:
nodes1: 2001:678:1120:0:1:100::/96
nodes2: 2001:678:1120:0:1:102::/96
nodes3: 2001:678:1120:0:1:103::/96
nodes4: 2001:678:1120:0:1:104::/96
and container ipv6 is 2001:678:1120:0:1:100:cd75:c19b
xlmnxp
(Salem AlSaiari)
July 2, 2026, 7:35pm
4
Resolved by setup ND (neighbor discovery) in my router then automatically incus instances get /128 from DHCPv6 server with correct routes using macvlan on host network
