I’ve found 11GB of data on /var/snap/lxd/common/lxd/images
Shouldn’t the images be stored on the zfs lxdpool?
And if this is the normal behavior, how can I make LXD store images on the zfs pool?
Yes it is normal.
Please see my recent post on this topic and how to specify the downloaded images are stored on a custom volume:
As @stgraber explains here:
You can create a storage volume on one of your pools with
lxc storage volume createand then assign that volume to hold the image files with:
lxc config set storage.images_volume POOLNAME/VOLUMENAME
Thank you for the clue @tomp
