itviewer
(Jack Ma)
September 27, 2024, 3:07pm
1
Similar to docker
-v /var/run/docker.sock:/var/run/docker.sock,
So I can calling the Incus daemon API inside the container.
I tried the following command
incus config device add ubuntu2204 unix-socket unix-char source=/var/lib/incus/unix.socket path=/var/lib/incus/unix.socket
it said Invalid value for device option “source”: Path needs to be in /dev
simos
(Simos Xenitellis)
September 27, 2024, 4:16pm
2
Yes, it is. We are using in this example an Incus proxy device , to connect a Unix socket with a Unix socket . (unix<->unix).
$ incus launch images:ubuntu/24.04/cloud management
Launching management
$ incus config device add management incussocket proxy connect=unix:/var/lib/incus/unix.socket listen=unix:/var/lib/incus/unix.socket bind=container uid=0 gid=147 mode=0660 security.uid=65534 security.gid=147
Error: Failed to start device "incussocket": Error occurred when starting proxy device: Error: Failed to listen on /var/lib/incus/unix.socket: listen unix /var/lib/incus/unix.socket: bind: no such file or directory
$ incus exec management -- mkdir -p /var/lib/incus/
Device incussocket added to management
$ incus shell management
root@management:~# apt install incus-client
root@management:~# incus version
Client version: 6.0.0
Server version: 6.5
root@management:~# logout
147 is the ID of incus-admin in my case.
itviewer
(Jack Ma)
September 28, 2024, 3:29am
3
Thanks, I tested it successfully using the following command, and the user group in my container is 1000
incus exec ubuntu2204 -- mkdir -p /var/lib/incus/
incus config device add ubuntu2204 incus-socket proxy \
bind=instance mode=0660 gid=1000 \
listen=unix:/var/lib/incus/unix.socket connect=unix:/var/lib/incus/unix.socket
abiosoft
(Abiola Ibrahim)
September 30, 2024, 5:50am
4
Also bear in mind the security implications of this.
jarrodu
(Jarrod Urban)
September 30, 2024, 7:23am
5
This is how I solve the same problem.
By default, Incus can be used only by local users through a Unix socket and is not accessible over the network. To expose Incus to the network, you must configure it to listen to addresses other th...
