I have two servers, each running LXD 3.0.1 from the snap 3.0/stable channel.
I attempted to move a running server between them, and lxd complained CRIU isn’t installed on the source server. Which it was.
Then from Error in live migration I see that CRIU is included in the snap, but needs to be enabled. So I enabled it on both servers with sudo snap set lxd criu.enable=true.
But it is still complaining of CRIU not being installed on the source server.
Looking through these topics, I can see that it has been disabled (November), and that it doesn’t work migrating between hosts in a cluster, but I can’t see for sure if it should work, from a snap install, between two non-clustered servers.
Any information on this gratefully received. Thanks!
Ed
