I was just curious if you had to use microcloud with microovn?
If you could use regular lxd with microovn what additional steps would be required if any
Yeah, it would work. You’d mostly need to do the LXD side of the configuration, that is, set the network.ovn.northbound_connection
key to point to the various servers in the MicroOVN cluster.
