Setting up a Incus VM running RedHat 8 is possible by using a qcow2 that RedHat supplies. You then need to setup cloud-init to get a user, a password and a SSH key installed at startup.
The normal Incus way is to have a profile with agent:config and a config with cloud-init.user-data. Unfortunately that doesn’t work with with RedHat 8
What I have working right now is to create an ISO with meta-data and user-data, [1]. The ISO is attached to the VM. This works, but I wish to do it via a incus profile.
If I understand it correctly then I first need an (Incus) agent in the VM, right? But how do I do that? Or do I need to use distrobuilder? Again, how would I use that to get an Incus-friendly image?
