hachi
(Hamza)
April 3, 2022, 1:09pm
1
I am using Golang client to create LXD profiles which some of them contain cloud-init settings. The once without cloud-init work flawlessly but with cloud-init not.
Here is a simple cloud-init conf:
user.user-data:
#cloud-config
ssh_pwauth: yes
users:
- name: deployer
plain_text_passwd: "**********"
lock_passwd: false
groups: sudo
shell: /bin/bash
sudo: ALL=(ALL) NOPASSWD:ALL
I also tried with cloud-init.user-data
but to no avail.
Here is the error message LXD version 4.24 is complaining about:
panic: runtime error: invalid memory address or nil pointer dereference
[signal SIGSEGV: segmentation violation code=0x1 addr=0x0 pc=0x868f54]
goroutine 1 [running]:
github.com/hamzaachi/lxd-compose/config.(*LXD).NewConn(0x978821)
/home/hachi/MyDATA/eadn/Projects/Programming/Go/lxd-compose/config/config.go:46 +0x14
main.main()
/home/hachi/MyDATA/eadn/Projects/Programming/Go/lxd-compose/main.go:89 +0x94
exit status 2
Any clue?
tomp
(Thomas Parrott)
April 4, 2022, 10:53am
2
Looks like you’ve not initialized the config
variable perhaps.
hachi
(Hamza)
April 4, 2022, 9:24pm
3
Thank you for your reply. Here is my config.yaml
and config.go
which consumes and decodes config.yaml:
snap_local:
socket: "/var/snap/lxd/common/lxd/unix.socket"
payaraGo:
user.user-data:
#cloud-config
ssh_pwauth: yes
users:
- name: deployer
plain_text_passwd: "********"
lock_passwd: false
groups: sudo
shell: /bin/bash
source: cloud-init:config
nictype: bridged
parent: lxdbr0
pool: default
description: Payara specific configuration
instances:
- name: test-ct
profiles: [PayaraGO]
source:
type: image
alias: ubuntu-ct-20
type: container
- name: test-vm
source:
type: image
alias: ubuntu-vm-20
type: virtual-machine
operations:
test-vm:
nictype: bridged
parent: lxdbr0
ipv4.address: 10.232.131.222
type: "nic"
config.go:
package config
import (
"fmt"
"os"
lxd "github.com/lxc/lxd/client"
"github.com/lxc/lxd/shared/api"
yaml "gopkg.in/yaml.v3"
type LXD struct {
Snap_local Snap `yaml:"snap_local"`
Profiles map[string]api.ProfilesPost `yaml:"profiles"`
Instances []api.InstancesPost `yaml:"instances"`
Operations map[string]Devices `yaml:"operations"`
type Devices struct {
Devs map[string]map[string]string `yaml:"devices"`
type Snap struct {
Socket string `yaml:"socket"`
func NewConfig(path string) (conf *LXD, err error) {
conf = &LXD{}
yamlReader, err := os.Open(path)
if err != nil {
return nil, fmt.Errorf("error reading config file: %s", err)
defer yamlReader.Close()
decoder := yaml.NewDecoder(yamlReader)
if err = decoder.Decode(conf); err != nil {
return conf, nil
func (c *LXD) NewConn() (connection lxd.InstanceServer, err error) {
connection, err = lxd.ConnectLXDUnix(c.Snap_local.Socket, nil)
if err != nil {
return nil, err
return connection, nil
I don’t really see where to initialize these variables if any
tomp
(Thomas Parrott)
April 5, 2022, 8:22am
4
Check that this var isn’t nil:
hachi:
c.Snap_local
hachi
(Hamza)
April 5, 2022, 9:16am
5
I think i figured out the root cause of the issue, If i set cloud-init conf in the Profiles definition i cannot get any variables wihether c.Snap_local or others.
It seems Golang client cannot decode and render any YAML data with cloud-init, isn’t it because cloud-init is more complicated and cannot fit into Config map[string]string
json:“config” yaml:“config” ` defined in ProfilePut here
// swagger:model
type ProfilePost struct {
// The new name for the profile
// Example: bar
Name string `json:"name" yaml:"name"`
// ProfilePut represents the modifiable fields of a LXD profile
// swagger:model
type ProfilePut struct {
// Instance configuration map (refer to doc/instances.md)
// Example: {"limits.cpu": "4", "limits.memory": "4GiB"}
Config map[string]string `json:"config" yaml:"config"`
// Description of the profile
// Example: Medium size instances
Description string `json:"description" yaml:"description"`
// List of devices
// Example: {"root": {"type": "disk", "pool": "default", "path": "/"}, "eth0": {"type": "nic", "network": "lxdbr0", "name": "eth0"}}
tomp
(Thomas Parrott)
April 5, 2022, 9:20am
6
The cloud-init config is expected to be a string of yaml in the config value field, not embedded yaml.
hachi
(Hamza)
April 5, 2022, 9:31am
7
I see, this is my problem then. Thanks @tomp i will see how to inject it as a string
olmax99
(Olmax99)
June 15, 2022, 9:44am
8
I am also using the Golang client and trying to start a container instance with a custom cloud-init or any possible InstanceUpdate() for that matter. I believe this Topic kind of relates closest by avoiding to create an entirely new topic for my question.
I’ve created a test case:
userdata := api.InstancePut{
Config: map[string]string{"limits.cpu": "4",},
if _, etag, err := c.GetInstance(expected); err != nil {
t.Fatal(err)
} else {
op, err := c.UpdateInstance(expected, userdata, etag)
if err != nil {
t.Fatal(err)
err = op.Wait()
if err != nil {
t.Fatal(err)
Myunderstanding of how idmaps work in LXC is most certainly lacking, so please forgive if I am missing the obvious here. The following error is thrown (./lxd/instance/drivers/driver_lxc.go:4190):
lxc_test.go:148: Volatile idmap keys can't be deleted by the user
This is happening for cloud-init (“user.vendor-data”) or any Config, Profile, etc change.
There is no problem whatsoever using the standard cli method:
lxc config set test-container limits.cpu=2
Help appreciated.
tomp
(Thomas Parrott)
June 15, 2022, 9:47am
9
This is a recent change to detect and prevent making the error that your program is making, which is to attempt to replace (PUT) the instance’s config without reading the instance’s current config and merging it with your desired changes first.
The volatile idmap keys are created by LXD on instance creation, and you are effectively requesting they be removed via your UpdateInstance
request, which would render the container unusable.
olmax99
(Olmax99)
June 15, 2022, 9:49am
10
Actually, that makes a lot of sense. Thx a lot.
For the sake of completeness, I want to leave the implementation:
ic, etag, err := client.GetInstance(expected)
if err != nil {
t.Error(err)
o := NewConfigRead(ic)
o.Read() // initializes all functions from ConfigReader interface (see below)
o.ILocConf["limits.cpu"] = "4" // add new config entry
req := api.InstancePut{
Architecture: o.ILocConf["image.architecture"],
Config: o.ILocConf,
Devices: o.ICurr.ExpandedDevices,
Ephemeral: false,
Profiles: []string{"default"},
Stateful: false,
Description: "updated instance",
op, err := c.UpdateInstance(o.ICurr.Name, req, etag)
if err != nil {
t.Fatal(err)
err = op.Wait()
if err != nil {
t.Fatal(err)
ConfigRead fulfills the ConfigReader interface:
type ConfigReader interface {
Project() string
Type() instancetype.Type
Architecture() int
ExpandedConfig() map[string]string
ExpandedDevices() deviceConfig.Devices
LocalConfig() map[string]string
LocalDevices() deviceConfig.Devices
corresponding an example struct:
type ConfigRead struct {
ICurr *api.Instance
IProject string
IType api.InstanceType
IArch int
IExpConf map[string]string
IExpDevs deviceConfig.Devices
ILocConf map[string]string
ILocDevs deviceConfig.Devices
func NewConfigRead(obj *api.Instance) *ConfigRead {
ins := &ConfigRead{}
ins.ICurr = obj
return ins
func (ic *ConfigRead) Read() ConfigRead {..}
